Ty's TJ. - Page 104 - JeepForum.com
post #1546 of 2548 Old 07-22-2013, 02:26 PM
Imped
Imped's Avatar
OK, I guess I'm just talking out of my *** then.
OlllllllO
IndyORV
Imped is offline
post #1547 of 2548 Old 07-22-2013, 02:59 PM
marcus01tj
I guess so..
#notoffroadsc
marcus01tj is offline
post #1548 of 2548 Old 07-22-2013, 03:08 PM
Imped
Imped's Avatar
Originally Posted by marcus01tj View Post
I guess so..
I'm not.
I spent a lot of time un-denting my body mount channel and lower edge of the tub to prove it. The devil is in the details and at a certain point, they will make a difference.
OlllllllO
IndyORV
Imped is offline
post #1549 of 2548 Old 07-22-2013, 03:22 PM
marcus01tj
I'm not.
Mind explaining?
#notoffroadsc
post #1550 of 2548 Old 07-22-2013, 08:56 PM
wfochris
Mind explaining?
I'll second the request as I'm about to install some myself.
Build thread:
http://www.jeepforum.com/forum/f22/3rd-times-charm-02-4-cyl-tj-1548852/
wfochris is offline
post #1551 of 2548 Old 07-22-2013, 10:23 PM
Kodiak17
Blaine has explained why preloading your sliders is important... theres a thread on slider design.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #1552 of 2548 Old 07-22-2013, 10:32 PM Thread Starter
tyvanwie
Do you have a link? I tried searching for it.
tyvanwie is offline
post #1553 of 2548 Old 07-22-2013, 10:41 PM
Kodiak17
I think its actually a picture request thread about sliders on JF.
Kodiak17 is offline
post #1554 of 2548 Old 07-23-2013, 05:56 AM
JCJeep97
Mind explaining?
I'm curious too, if you have time.
I've gathered you know a little about suspension design
My Build: http://www.jeepforum.com/forum/f22/back-black-2000-tj-build-1237980/
JCJeep97 is offline
post #1555 of 2548 Old 07-23-2013, 07:22 AM
Imped
Imped's Avatar
Sorry for the delay. You preload the sliders so that when they are exposed to the high dynamic forces of dropping off a ledge onto a rock (or similar), the fasteners don't distort. When fasteners distort, the plate moves and the tub goes with it.
Still one of the best slider design/theory threads ever: http://www.jeepforum.com/forum/f9/in...s-pics-134553/
You can see the early days of Blaine's design coming to fruition.
OlllllllO
IndyORV
Imped is offline
post #1556 of 2548 Old 07-23-2013, 07:43 AM
Kodiak17
Yup thats it. You'll also read why mounting from the bottom is important especially when you have a tube/step on the outside for leverage.
Kodiak17 is offline
post #1557 of 2548 Old 07-23-2013, 08:58 AM Thread Starter
tyvanwie
Thanks for the link man. Ill read through that today.
tyvanwie is offline
post #1558 of 2548 Old 07-23-2013, 09:31 AM Thread Starter
tyvanwie
Okay I think I understand it now. You're basically just making it so the sliders are as close to being part of the tub as possible, right? You don't want any gaps or space.
tyvanwie is offline
post #1559 of 2548 Old 07-23-2013, 10:04 AM Thread Starter
tyvanwie
So apparently my tires only measure out to ~31.5".
tyvanwie is offline
post #1560 of 2548 Old 07-23-2013, 10:13 AM
Imped
Imped's Avatar
Well, that....but you're actively forcing the two together to create a single assembly. You can install sliders to have no gap very easily without preloading at all.
Here's the best indicator for preload vs. none. If you unbolt the sliders then try to bolt them up by hand with no other force acting on them, the bolt hole in the slider and the hole in the tub will not fully line up. That also goes for nutserts. A greater force than what you can apply by hand needs to be exerted on the assembly to allow installation. In order to get that, you have to drill all holes when the slider is vertically and laterally preloaded.
OlllllllO
IndyORV
Imped is offline
nc guys
