Turbocharged 2.4L Jeep TJ for me too!!! - JeepForum.com
post #1 of 54 Old 03-25-2014, 11:28 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
Hi All,
I was inspired by this thread from Air Sierra on Reno 4x4:
http://www.reno4x4.com/forum/showthr...Jeep-TJ-for-me!!!
I'm going to use it as a guide to do my own turbo setup on my TJ!
The cliff notes: Use the exhaust manifold and turbo from a PT Cruiser / Neon SRT4 and flip it upside down so it fits on the Jeep 2.4. Run conservative boost and the computer will adjust accordingly. (I Hope!)
Items purchased so far:
Used turbo and exhaust manifold - eBay
Air/Water Intercooler kit - Frozenboost.com
Coolant and Oil lines and fittings for Turbo - kinugawa turbo
2.5" Magnaflow Universal Spun Catalytic converter - eBay
Larger fuel injectors - fiveomotorsports
Custom adaptor plate for exhaust manifold - free (made by coworker)
Intercooler piping - Ebay
assorted exhaust and intake parts, air filter - siliconeintakes.com
spark plugs and some other small parts - rockauto.com
So far in pulling the exhaust off the jeep to get this started, I found I had a cracked exhaust manifold which would explain how loud it had been!
A big thanks for Air Sierra for being the first to do this. I will post pics as I go.
-Alex
http://www.jeepforum.com/forum/f22/turbocharged-2-4l-jeep-tj-me-too-2255329/
ALS59LTD is offline
post #2 of 54 Old 03-25-2014, 11:45 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
Just a pic of the jeep before surgery and a pic of the cracked turbo I got from eBay. The seller sent me another one to replace it but I don't trust it, I'm sending both out for rebuild.
-Alex
ALS59LTD is offline
post #3 of 54 Old 03-26-2014, 05:29 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
My adaptor plate is a little off so it needs some work but here is the exhaust manifold on the motor so I can start working on the exhaust.
-Alex
ALS59LTD is offline
post #4 of 54 Old 03-31-2014, 07:26 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
This weekends progress: I don't have A/C so I was able to tuck the heat exchange in front of the radiator nicely, I just flipped the support bar around. Working on getting the exhaust done while I wait for more parts in the mail. Finally got a tank for my baby MIG welder, it's so much better than flux core! Been doing some practice pieces so I can make up the brackets I'll need and weld the non-stainless part of my exhaust.
-Alex
ALS59LTD is offline
post #5 of 54 Old 04-30-2014, 09:27 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
Almost there!
-Alex
ALS59LTD is offline
post #6 of 54 Old 04-30-2014, 06:35 PM
1_sick_xj
Sweet setup!
1_sick_xj is offline
post #7 of 54 Old 04-30-2014, 07:20 PM
TJRUSSELL
lookin good. do you need a compressor housing? i may have one. also did you relocate your battery because you might want to put it in for mock up, i had to cut my exhaust u-bend to shorten the radius
My 2.4 turbo TJ-6 stretch build
http://www.jeepforum.com/forum/f22/my-lil-2-4-tj-build-1092494
TJRUSSELL is offline
post #8 of 54 Old 04-30-2014, 07:29 PM
TJRUSSELL
what size is the valve cover breather filter? that's the last thing i need and i keep forgetting about it
post #9 of 54 Old 05-01-2014, 09:00 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
I'm going to put an optima battery in, which isn't as long so I'm going to cut down the battery tray and it should fit.
The breather filter didn't fit at first - I had to drill out some of the rubber, but it was plenty thick rubber so I think it's fine. "Spectre Performance 3998 White Breather Filter" on amazon.
Do you mean the sheet metal cover for the turbo? Yeah, I don't have that so if you have one extra that would be great.
I'm just waiting on a 2" to 2.5" silicon reducer for the turbo outlet then I think I'll have everything I need for it to run!
-Alex
ALS59LTD is offline
post #10 of 54 Old 05-01-2014, 10:06 AM
TJRUSSELL
The heat shield I found for around 20$ from some mopar site, I'm talking about your cracked part
post #11 of 54 Old 05-01-2014, 11:48 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
Got ya - I sent the 2 turbo cores I had out for rebuild - they used the best parts from both, mainly the core from the non cracked one and the housing from the cracked one - which was in much better shape. So the turbo I have no is a fresh rebuild, too bad my engine has 140k on it! I will search for that heatshield and I need to put some header wrap on my exhaust, like you have on yours.
-Alex
ALS59LTD is offline
post #12 of 54 Old 05-08-2014, 06:38 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
She's alive! Like TJRuss said in his build thread, it sounds like a diesel, the turbo whine is awesome.... I'm dumping exhaust behind the trans skid plate until my cat-back arrives. Took it for a spin up to the gas station to get some 93 octane in the tank. I have to figure out the boost management - I think the computer doesn't like much past 10psi - a little detonation so I'll have to play nice until I get the rest of the 87oct run out of the tank and I need to finish up my air/water intercooler.
-Alex
ALS59LTD is offline
post #13 of 54 Old 05-08-2014, 10:02 AM
TJRUSSELL
How much boost are you getting? Did you put a valve in-line with the wastgate for more boost? The highest I hit was 5lbs but I'm not beating on it yet
post #14 of 54 Old 05-08-2014, 11:42 AM
JeepaholicNinja
0-60!!
2000 Cherokee Classic
3" Zone lift, THULE roof rack, Hella 500 Black Magics
JeepaholicNinja is offline
post #15 of 54 Old 05-09-2014, 09:16 AM Thread Starter
ALS59LTD
ALS59LTD's Avatar
I put a valve in line - I thought I had it pretty open to limit the boost and I'm getting near 10psi - maybe not open enough. I'm going to take the valve out and see what it does - I don't want to run 10, 8 would be the max I would like.
and 0-60 is not going to be impressive! lol I would get better numbers with my crown vic. I don't want to race the jeep I just want it to get out of it's own way.
-Alex
ALS59LTD is offline
