Turbo TJ Build - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Turbo TJ Build
Offset Tie Rod Kit From RuffStuff!The Original 3/8" Ruffstuff Diff Cover!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 09-25-2013, 09:10 AM   #1
shaggylemur
Turbo TJ Build
Well I've been lurking for far too long without starting a build thread so here we go.
This started off as a straight trade for my Mazda in Easley, SC. I was happy till I realized the lack of a** on the highway; going from being able to cruise at well over 90 to being limited to 82mph top speed was a bit of an issue in Atlanta.
I started looking around to try to find a viable swap. I went through the "I want a 4bt" stage that ended quickly when I looked at the weight of one.
The 4.0 looked promising but ended up that it was going to cost much more than I wanted to spend on my motor.
Coming from the Import world where when you have a power problem you just slap a turbo on it, I made the most logical decision and decided I would go against the crowd. I bought a turbo kit. It is actually a custom kit built by a shop in Asheville. So without further delay I'll start to share as much information as I possibly can. The turbo is already mounted on the bracket as a mockup. It is a Borg Warner 53mm.
Ill even add in my suspension build as it comes to fruition.
shaggylemur is offline   Reply With Quote
Unread 09-25-2013, 09:11 AM   #2
shaggylemur
saved for pics
Unread 09-25-2013, 09:12 AM   #3
shaggylemur
saved for pic
