Turbo 4.0L - JeepForum.com
post #1 of 66 Old 06-20-2010, 01:20 PM Thread Starter
SaskJeep2000
Turbo 4.0L
Used a t04b
SaskJeep2000 is offline
post #2 of 66 Old 06-21-2010, 04:11 PM
Skytard
Alright call me retarded or something but Why is your turbo connected to your intake? Turbos are off the exhaust. unless you were using the intake as a cooler?
Poor college student.
Skytard is offline
post #3 of 66 Old 06-21-2010, 04:13 PM
EugeneTheTJ
Tar Heel
EugeneTheTJ's Avatar
I think I must be retarded too b/c I thought the same thing
2016 TJ of the Year
Founder, Offroad NC
Follow our journey:
  • To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
EugeneTheTJ is offline
post #4 of 66 Old 06-21-2010, 04:16 PM
Rallysman
It's exhaust driven but what good would that do if it's not putting the air where it should be?
Sweet setup. I'd like to see some videos to hear that bad boy.
Rallysman is offline
post #5 of 66 Old 06-21-2010, 04:18 PM
Big4mike9
His set up is right. Search alittle. Assured Performance .::. How A Turbocharger Works
93 YJ.......Under Construction
Big4mike9 is offline
post #6 of 66 Old 06-21-2010, 04:19 PM
-Deepskyy-
I know the intake part of the turbo is correct, but I'm trying to follow the piping too and the thing I can't figure out is how the exhaust (drivers side) gets to the turbo. Did you pull the impeller pipe under the engine and up to the turbo?
Are you finding the Jeep Forum helpful?
"I never saw such fighting since God made me. The Americans fought like demons"
-Lt. General Charles, Earl Cornwallis after the battle of Guilford Courthouse NC
Originally Posted by Outatime05 View Post
Females are a dime-a-dozen. Jeeps are forever. Easy choice. Be indispensible or be gone. :wave:
Originally Posted by jeepdavetj View Post
We are Jeepforum. We can do the unthinkable. We are Jeep strong. And head stubborn. We are. JEEPFORUM.
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Red Jeep #543
-Deepskyy- is offline
post #7 of 66 Old 06-21-2010, 04:19 PM
SkyHigh
The turbo is fed from the exhaust gases, it uses the exhuast to spind the turbine,it then compresses the air, and forces it into the trhottle body.
wiki defintion:
A turbocharger is a small radial fan pump driven by the energy of the exhaust gases of an engine. A turbocharger consists of a turbine and a compressor on a shared shaft. The turbine converts exhaust heat and pressure to rotational force, which is in turn used to drive the compressor. The compressor draws in ambient air and pumps it in to the intake manifold at increased pressure, resulting in a greater mass of air entering the cylinders on each intake stroke.
- 97 Sahara -
- 13 Grand Cherokee Trail Hawk Hemi -
SkyHigh is offline
post #8 of 66 Old 06-21-2010, 04:19 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
o0o nice!! post them in the Turbo TJ thread
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 66 Old 06-21-2010, 04:25 PM
dand3053
It looks like the last sentence you wrote is right. There appears to be a pipe running under the oil pan up to the turbo. If you look close at the last couple of pics you can kinda see it.
dand3053 is offline
post #10 of 66 Old 06-21-2010, 04:32 PM
Skytard
Oh I never knew that the exhaust gasses were forced back into the engine. I thought that they were just forced out of the engine for getting rid of ehaust gasses faster. Wouldnt the compressed air from the turbo sent back into the throttle body be hot air? Help me out here, im just trying to figure this out.
Skytard is offline
post #11 of 66 Old 06-21-2010, 04:53 PM
arjj09
The exhAust doesn't go back into the engine. A turbo has two sides. One side is mounted to the exhaust manifold and as the engine forces the exhaust out it causes the turbine to spin and then exits through the exhaust pipe. As the turbine spins on the exhaust side it causes the intake side to spin. This causes the air intake to suck in more air and it compresses it then it usually cools it and it is pushed into the engine causing more power.
arjj09 is offline
post #12 of 66 Old 06-21-2010, 04:54 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
there are 2 turbines on a turbo, 1 for the exhaust which spins the compressor turbine for the intake side. the exhaust gas flows through the backside of the turbo which spins the pinwheel that is on a driveshaft - the intake side of the turbo sucks cold air in and compresses it and forces it into the engine at several atmospheres.
My builds:
and
or follow us on
spyder6 is offline
post #13 of 66 Old 06-21-2010, 04:56 PM
1stockjeep
1993 XJ Cherokee
The air is much hotter! That is why a intercooler is used on most applications. There is the standard air cooled intercooler or water cooled. The water cooled works great and takes up much less room but will hydro lock a engine if it begins to leak
1stockjeep is offline
post #14 of 66 Old 06-21-2010, 08:38 PM Thread Starter
SaskJeep2000
I didn't intercool it since I live in a some-what cold climate most of the year and I'm only running about 7psi boost. I do plan on intercooling it eventually for efficiency's sake but it works quite well as is.
post #15 of 66 Old 06-21-2010, 08:51 PM
Skytard
Ok tell me if this sounds about right. There are two sides to a turbo, one side to get rid of gasses faster and another side that acts as a supercharcher(my idea of a super may be wrong but i think it just forces air into the throttle body)? So if thats true, whats the point of even supercharging an enine if a turbo does exhaust and intake?
Skytard is offline
Turbo Jeep's? NYC_ZJ Jeep Picture Requests 9 06-21-2010 08:40 PM
my Turbo Diesel J53 crusher Jeep Builds 6 08-24-2004 10:42 PM
