"Trent's overly popular everlasting YJ Build" - Page 5 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > "Trent's overly popular everlasting YJ Build"
50" LED CREE Light Bar Pair With Wiring KitIntroducing MONSTALINERô UV Permanent DIY Roll On Bed LineTeraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMA
Unread 10-06-2013, 11:33 AM   #61
8pitcher
Well
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 10-06-2013, 09:17 PM   #62
freaknajeep
1971 DJ
so when you plan on having it drivable..lol ive been at that point too many times herein the last 3 years..
Be carefull while Hugging the Trees...They leave dents on your Jeep....
Shhhhhh I'm not crazy...It's just the voices in my head
freaknajeep is offline   Reply With Quote Quick reply to this message
Unread 10-06-2013, 09:24 PM   #63
8pitcher
got the entire front suspension on and burned in!!! now gotta finish gettin the 4 link front completely burned in because when i flexed the front to figure out the angles when at full stuff the tacs on one of the upper link mounts broke.
Unread 10-06-2013, 09:25 PM   #64
8pitcher
i hope to have it drivable and running down a hill in march
Unread 10-06-2013, 09:30 PM   #65
freaknajeep
1971 DJ
haha if I could find a hill big enuff I could pull that off now...lol..might have a few issues after I reach the bottom tho...
Unread 10-06-2013, 09:36 PM   #66
8pitcher
haha i could too but then it wouldnt look as perty
Unread 10-06-2013, 09:51 PM   #67
8pitcher
as you can see above i mounted the shock toward the front at the top so it will be perp with the frame at full stuff.
we made the lower mounting brackets adjustable so the angle can be changed and the ride height too slightly. but mostly for the angle at full stuff and at ride height of 10-12*
Unread 10-07-2013, 08:16 PM   #68
AmmitOsiris
Looks too low. Need moar. Bigger tires a cab and a grill and an Exo cage
Sent from Peggy's office
AmmitOsiris is offline   Reply With Quote Quick reply to this message
Unread 10-07-2013, 08:30 PM   #69
8pitcher
Well the 42's will help with that I will charge the shocks to get it a little higher I have te grill and tub gotta do tranny and finish all welds.
Unread 10-09-2013, 06:44 PM   #70
SirWinston
Trent...This is sick. If you werent rolling 42's I would say chop off some of that front bumper and make the approach angle better, but it probably wont matter once you get those one there
Colorado Jeep Club Member #265
SirWinston is offline   Reply With Quote Quick reply to this message
Unread 10-09-2013, 06:51 PM   #71
8pitcher
I don't want to modify the frame a whole lot man. The entire thing is air tight so it is a portable air tank
Unread 10-09-2013, 07:42 PM   #72
freaknajeep
1971 DJ
1 year down the road....doo de doo de doo...crusin down the trail...da de da...skeeratch kathud boom....................later that evening...." Dude!! I have no idea what happened!...I hit a bump and the whole thing just exploded!!"....this would be my luck....
Unread 10-09-2013, 07:45 PM   #73
straightsixjeep
You do solid work, I highly doubt your rigs will break that easy. Maybe if you tried though
http://www.jeepforum.com/forum/f22/98-xj-gettin-her-trail-ready-1417602/
straightsixjeep is offline   Reply With Quote Quick reply to this message
Unread 10-09-2013, 07:55 PM   #74
freaknajeep
1971 DJ
dude if you only knew...at the risk of embarrassment....I built this one Cherokee on 38's(no cutting) and I swear for the first 4 or 5 times out I came home with no available ratchet straps...once even had the wife go get me 4 extra....learned a lot about suspension design and opposing forces...with that one...
Unread 10-09-2013, 09:15 PM   #75
straightsixjeep
Is that the one I asked you to post in your dj thread? My Jeep looks up to that Jeep. Reading your planetary gear writeup, keep up the xj tech tips man!
airshocks , crawler , custom , welding , YJ
