"Trent's overly popular everlasting YJ Build" - Page 10 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > "Trent's overly popular everlasting YJ Build"
Unread 11-14-2013, 10:24 PM   #136
8pitcher
8pitcher's Avatar
Painted the front axle and got some very important kingpin rebuilders parts from 4wdfactory.com
Found out about them from the billa vista tech garage on pirate. Some amazing info there if you've never looked.
Also welded on some much needed support for the upper link mounts on the front truss.
Built Not Bought #640
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 11-16-2013, 02:18 PM   #137
8pitcher
8pitcher's Avatar
Locking hubs arrived yesterday! Should have the entire front axle in place once again really soon!
Unread 11-24-2013, 01:41 PM   #138
8pitcher
8pitcher's Avatar
Well bad news....
Dropped the frame on my dads finger and crushed the tip of it off between the rear shock and shock mount while mounting it all up.
Unread 11-24-2013, 01:43 PM   #139
AmmitOsiris
Originally Posted by 8pitcher
Well bad news.... Dropped the frame on my dads finger and crushed the tip of it off between the rear shock and shock mount while mounting it all up.
No bueno how is it? How is he?
Sent from Peggy's office
AmmitOsiris is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 02:06 PM   #140
8pitcher
8pitcher's Avatar
He's fine in pain in the er right now. Maybe might save the tip. I feel like ****ing ****.
Unread 11-24-2013, 05:14 PM   #141
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
oops but hey, no good jeep is born without a little blood spilled.
Hope they're able to get him fixed up fine. Anything that heals doesn't count in the long run.
***Chris***
JeepForum.com/IndyORV@Redbird-SRA
COTY 2009
chris87xj is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 05:35 PM   #142
8pitcher
8pitcher's Avatar
Yeah there is blood everywhere on the ground in te shop. Let my upload some pics.
Unread 11-24-2013, 05:44 PM   #143
8pitcher
8pitcher's Avatar
In case y'all were wondering you can't fit your fingers in between the shock and shock mounts it's tight. And as chris said this will have to be a great jeep haha.
They tried to sew on the tip again with 5 stitches to tack it into place. He goes back Tuesday to see about whether or not to have surgery and if the finger tip takes to the rest of the finger.
Unread 11-24-2013, 05:52 PM   #144
AmmitOsiris
In case y'all were wondering you can't fit your fingers in between the shock and shock mounts it's tight. And as chris said this will have to be a great jeep haha. They tried to sew on the tip again with 5 stitches to tack it into place. He goes back Tuesday to see about whether or not to have surgery and if the finger tip takes to the rest of the finger.
Give your dad my condolences
Unread 11-24-2013, 06:01 PM   #145
8pitcher
8pitcher's Avatar
Will do.
Unread 11-24-2013, 08:12 PM   #146
Carlos14
ouch
Luck Favours The Prepared
Carlos14 is offline   Reply With Quote Quick reply to this message
Unread 11-24-2013, 08:16 PM   #147
8pitcher
8pitcher's Avatar
He said the pain is just now coming back to him the nerve block is wearing off.
Unread 11-24-2013, 09:20 PM   #148
8pitcher
8pitcher's Avatar
The crawler looks nice with shocks on it all the way around.
And right behind where my dad had his incident there was a napkin laying on the ground with quite a bit of blood on it. (For his hand only to be pointing down for about a second or two) so I hung it up on the shop wall.
Unread 11-24-2013, 09:42 PM   #149
AmmitOsiris
The crawler looks nice with shocks on it all the way around. And right behind where my dad had his incident there was a napkin laying on the ground with quite a bit of blood on it. (For his hand only to be pointing down for about a second or two) so I hung it up on the shop wall.
Pics or it didn't happen
Unread 11-24-2013, 09:49 PM   #150
8pitcher
8pitcher's Avatar
Ill take one tomorrow I'm in doing homework.
airshocks , crawler , custom , welding , YJ
