Tomb Raider buildup #1 - Page 7 - JeepForum.com
post #91 of 145 Old 06-22-2006, 09:14 AM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by boulderz
As far as how you "massaged" your skid plate, do you think that will create any problems for you in the future? I am in process of putting a 96 4.0 with AX15 from an XY into my 87 YJ and am running into the same issue of the TC being clocked at 23* instead of 13*. When the skid bolts up, the TC is sitting against it.
Has anyone seen another option than cutting the skid to make this work? Or is it not a big deal? Any writeups (I haven't found any..)
The only "problem" foreseeable is catching it on rocks. In the near future I will take a piece of plate and weld it on the skid at an angle to cover the bottom of the tcase. As for ridgidity, Your primary weightbearing load is on the middle of the skid. If you look at the cherokee skids, they are only as wide as the center reinforced area of the YJ skid. The section for and aft are only for protection, not weight bearing purposes.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #92 of 145 Old 06-22-2006, 10:40 AM
boulderz
I guess that's what I'll do too. I read somewhere the TC could be redrilled so that it aligns correct. Anyone know of this being done?
boulderz is offline
post #93 of 145 Old 06-22-2006, 12:10 PM Thread Starter
Tomb Raider
Addicted...
I found it somewhere online once. Yes, it has been done. There is nothing special that needs to be done other than drilling the holes -10 degrees of what they currently are. My only thought on this was the cost to have someone do it.
post #94 of 145 Old 07-16-2006, 05:26 PM Thread Starter
Tomb Raider
Addicted...
Well.....my first trip out post buildup. Took it fairly easy, testing the waters so to speak. Nothing fell off on the trail, so I considered it a success. The fan controller did go south on me. Fortunately it was 5min into the ride. I ended up hardwiring the fan on the trail to make it through the day. The front driveshaft rubbed the skid just a hair....nothing a grinder can't fix. I think I will go ahead and get the MORE rear upper shock relocators. Give a little more flex in the rear.Other than that....worked flawlessly. The front locker is what I was most inpressed with. Never would have imagined the increased traction. Traction bar was stellar as well. No wheel hopping, and no feeling of limitation on the rear axle. Engine ran cool, and if I must say......dayyyyyuummmmm I am glad I have an automatic. What a difference on the trail. Needless to say, my daughter and I had a good morning on the trail. Poser shots, since it was just us.
post #95 of 145 Old 07-16-2006, 05:52 PM
sandman'sjeep
this Jeep is awesome ... wished I had the $$$ to do half of the mod's on this YJ... especially like the fact his wife helps out... if only I can find the right woman who is obsessed with Jeeps like me... having fun trying to find one though...
Sandman
sandman'sjeep is offline
post #96 of 145 Old 07-22-2006, 09:37 PM
dadstoy
Ride looks awesome. Great job.
I got my 4.0 stuck in today. Would you have pictures of your tranny supports and skids? That is the next stage I am going to tackle.
Oh, and thanks for the write up.
dadstoy is offline
post #97 of 145 Old 07-22-2006, 10:56 PM Thread Starter
Tomb Raider
Addicted...
Don't have any off hand, but i'll get some for you tomorrow.
post #98 of 145 Old 07-23-2006, 11:54 AM
dadstoy
Thanks, I will be looking for it.
dadstoy is offline
post #99 of 145 Old 07-24-2006, 09:08 AM
ChevDog1
Tomb - You may want to check the supply voltage to your fan controller. I killed one also when I went to the electric fan. Found out that if you don't have a continuous solid 12v to the relay, it will eventually burn out.0
ChevDog1 is offline
post #100 of 145 Old 07-24-2006, 03:35 PM
dadstoy
Tomb, have you had a chance to snap some pics of the tranny mount and skid? Just wondering. I am going to work on mine again as soon as I get off work to see what I come up with.
Dave
dadstoy is offline
post #101 of 145 Old 07-24-2006, 05:06 PM Thread Starter
Tomb Raider
Addicted...
It's hooked directly to the battery. I think it was just a bad relay. I did notice that the new relay they gave me was of higher amperage....so I would bet it was not an isolated problem.
I did not. I went wheelin yesterday unexpectedly and got home late. I will snap some tonight when I get home. Basically, I used the stock YJ skid plate, and the XJ tranny mount. My skid mounts as usual, with a few more holes drilled for the 4 bolts that the XJ tranny bushing has. I'll get the pics tonight.
post #102 of 145 Old 07-25-2006, 04:07 AM
YJ-Mike
Dadstoy,
What tranny are you installing? Does the AX15 (assuming that is what you are installing) have a 4 bolt pattern on the bottom like the NV3550? If so, then AA makes an adapter that bolts to the bottom of the tranny, and then you bolt the YJ tranny mount to that. The part is like $40, I picked one up, and it matched up perfectly. Allowed me to use a YJ urethane tranny mount with the NV3550 and no modifications to the YJ skid needed.
HTH,
Mike
Mike
2006 TJ X (Stock - w/ Borla Cat-Back Exhaust)
Built a YJ from the ground up:
- '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors.
-----> Build thread can be read here:
YJ-Mike is offline
post #103 of 145 Old 07-25-2006, 09:49 AM
dadstoy
Yj-Mike, thanks for the reply. Unfortunately it isn't the AX-15. I think I have the mount figured out. I have 2 options. I am fabbing the donor vehicle tranny mount to match the mounting holes on my YJ frame, and I am also fabbing an adapter using the bracket that was bolted to the tranny and making it fit my Yj skid. I will know which one works this afternoon.
dadstoy is offline
post #104 of 145 Old 07-25-2006, 11:02 AM Thread Starter
Tomb Raider
Addicted...
Here are a few I snapped this morning. As you can see, I basically just cut a bit larger hole to drill the tranny mount holes.
post #105 of 145 Old 07-25-2006, 11:40 AM
dadstoy
Thanks Tomb, that helps, I think. I appreciate your help.
Later,
Dave
dadstoy is offline
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 08:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 02:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 06:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 02:40 PM
