Tomb Raider buildup #1 - Page 6 - JeepForum.com
post #76 of 145 Old 05-30-2006, 05:58 AM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by 1900WranglerEFI
did you have to regear for 2.5-4.0 swap>?
No, matter of fact the 4.10's that were stock are better than the 3.xx gears that were in the cherokee. Worked out well since I found an 8.8 axle that had 4.10's as well.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #77 of 145 Old 05-31-2006, 06:26 AM
SimonTuffGuy
[I'm That Good]
SimonTuffGuy's Avatar
You're crazy man... Just crazy. It is EVERY TIME I read one of your posts, I like your Jeep more.
SimonTuffGuy is offline
post #78 of 145 Old 06-03-2006, 07:02 AM
crb577
quick question here i am putting in my 4.0L and found my tranny has no starter on it and i can't find where it went anyway. I was told the 2.5L starter will work is this true i thought it might be different but wasn't sure.
thanks,
chris
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #79 of 145 Old 06-04-2006, 08:23 AM Thread Starter
Tomb Raider
Addicted...
thanks,
chris
When I swapped mine, the starters looked totally different. My YJ was a 95 and the XJ was a 92 in my case. Dunno about other years, but certain that at least those years don't match.
post #80 of 145 Old 06-09-2006, 07:57 PM Thread Starter
Tomb Raider
Addicted...
Just a few updates....
Finally got the nerve to hack-n-tap the transfer case.
And put on some new stainless brake lines.
Next up, driveshaft cut on monday, rear brakelines next weekend.
post #81 of 145 Old 06-10-2006, 06:06 AM
Why J?
Why J?'s Avatar
I have a hack n tap sitting inmy garage, haven't gotten the nerve to put it on there, is it bad?
New Project "Pissed Wife"
Phase II 5.3L/4L60e then NV3550
Why J? is offline
post #82 of 145 Old 06-10-2006, 08:19 AM Thread Starter
Tomb Raider
Addicted...
Nah, was easier than I thought. Took a 4 1/2" grinder with a cutoff wheel to the shaft. Then drilled and tapped it iwth the included tap and bit. Pretty easy actually. Just used lots of cutting fluid and kept backing out the tap while doing it.
post #83 of 145 Old 06-17-2006, 07:47 PM Thread Starter
Tomb Raider
Addicted...
Well.....need I say more than............
It's done.
After 3 months, I'm done. Here is what I accomplished for those just joining in on this thread.
1. Removed 4banger drivetrain. Inserted Cherokee drivetrain, including I6, AW4 tranny and the NP242 transfer case.
2. Removed Dana 35 rear axle. Inserted an 8.8 axle with disc's.
3. Went from a 4" spring under suspension to SOA with 2" skyjacker springs.
4. Installed taurus electric fan with thermostatic control.
5. Removed stock 90A alternator, installed ZJ 130A alternator.
It seems like it's been forever. But well worth it. Still have some small things to tie up, but hopefully I can take it for a good trail run next week. Anyone who may have questions about any of the above is always welcome to inquire. I'm no expert, but I can give you my experiences with these installs. Thanks for all that gave advice along the way.
post #84 of 145 Old 06-17-2006, 08:18 PM
jeepin1995
jeepin1995's Avatar
i think a round of applause is in order........ good job man, it looks awesome.
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #85 of 145 Old 06-17-2006, 09:53 PM
rbn1357
rbn1357's Avatar
Do you have a build cost tally?
Especially Soa?
What did you do for steering?
rbn1357 is offline
post #86 of 145 Old 06-17-2006, 10:18 PM
toke
I_R_Food
toke's Avatar
That YJ looks awesome
I wonder if things would match up better using a 95 YJ w/i6 donor?
found a wrecked one my minds a tickin
1995 YJ gone as well
2001 Grand RIP
2004 Rubicon RIP
toke is offline
post #87 of 145 Old 06-19-2006, 07:11 PM
crb577
jeep looks awesome man just got my 4 banger out today and the motor mounts and the SYE and clutch go in my 6 tomorrow and then the 6 goes in.
that look awesome though i plan on doing soa next year thanks for all the helpful info
chris
1993 Jeep Wrangler
crb577 is offline
post #88 of 145 Old 06-20-2006, 06:51 PM Thread Starter
Tomb Raider
Addicted...
Got the crossover steering with a custom draglink and traction bar on today. Slowly the "little things" are getting finished up.
post #89 of 145 Old 06-21-2006, 06:08 PM Thread Starter
Tomb Raider
Addicted...
Well....finished up the rear axle. New brake lines and paint job and she's ready for wheelin'.
post #90 of 145 Old 06-22-2006, 07:31 AM
boulderz
As far as how you "massaged" your skid plate, do you think that will create any problems for you in the future? I am in process of putting a 96 4.0 with AX15 from an XY into my 87 YJ and am running into the same issue of the TC being clocked at 23* instead of 13*. When the skid bolts up, the TC is sitting against it.
Has anyone seen another option than cutting the skid to make this work? Or is it not a big deal? Any writeups (I haven't found any..)
boulderz is offline
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 07:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 01:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 05:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 01:40 PM
