Tomb Raider buildup #1 - Page 5 - JeepForum.com
post #61 of 145 Old 05-13-2006, 08:09 AM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by jeepin1995
i see u cut your skid plate..... why did u have to do that? clearance problems with ur t-case?
The NP231 is clocked at 13* on YJ's. The NP242 is clocked at 23* on XJ's. So it hangs down an inch or so more. I just "massaged" the plate a bit
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #62 of 145 Old 05-13-2006, 11:21 AM
f1ipst3r
I just found this thread today, i like what you have done, keep up the good work
'93 2.5l Cooper ST 30x9.50 r15
Black Jeep Club V2.0 Member #24
f1ipst3r is offline
post #63 of 145 Old 05-13-2006, 10:39 PM Thread Starter
Tomb Raider
Addicted...
Well....it was raining the early part of my weekend (thurs/friday) so I decided to do something in the shed out of the rain. Here is what I have mocked up so far.
post #64 of 145 Old 05-14-2006, 07:06 AM
TellyDSP
Poland and PPV!!!!
Sweetness.
I need to buy a welder...I guess a garage would be good too.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #65 of 145 Old 05-14-2006, 02:12 PM
rbn1357
rbn1357's Avatar
Are going to build some tube fenders or the reinstall the stock ones?
Tube fenders look nice.
rbn1357 is offline
post #66 of 145 Old 05-14-2006, 05:29 PM Thread Starter
Tomb Raider
Addicted...
Going to reinstall the stock fenders and brushwackers. The brushwackers allow plenty of stuff room.
post #67 of 145 Old 05-19-2006, 07:52 PM
DEAN062961
Need Help With My 91 Wrangler
[IMG]i53.photobucket.com[/IMG] We Are Doing The Same Thing I Took Out My 2.5 5 Spd. And Put In A 88 Cherokee 4.0 Mtr, At Trans & Transfer, Im At The Wiring And Its A Mess, Just What Do I Need On The Cherokee And How Does It Hook Up To The Wrangler ,wires Are Going Everywhere Under The Dash , I May Be A Bit Over My Head On This , I Need A Easy Way To Be Done, (like Sprinkle Some Fariy Dust On It And It Will Be Done Lol.)
DEAN062961 is offline
post #68 of 145 Old 05-19-2006, 10:30 PM Thread Starter
Tomb Raider
Addicted...
I replied to your other post. As for your wiring....it's different than mine. Your working with the non H.O. system (renix) and mine was the H.O. motor. They changed in 91 or 92 I think. It is still pretty basic tho.
1. Ignition 12v wire
2. Ignition start/run wire
3. Ground
4. Fuel pump wire and ground
5. Neutral saftey switch wire
Work on getting those hooked up first....then track down the rest. Remember, its three things....
Fuel, Spark, Ignition
post #69 of 145 Old 05-20-2006, 12:14 AM
DEAN062961
IM MORE CONCERN WITH THE WIRES UNDER THE DASH OF THE CHEROKEE AND THE COMPUTOR FOR THE MOTOR AND THE TRANS AND DO I LEAVE MY OLD HARNESS FOR THE RELAY BOX AND COIL AND STUFF?
post #70 of 145 Old 05-25-2006, 02:02 PM Thread Starter
Tomb Raider
Addicted...
You won't have to touch either the wires in the cherokee dash, or the the wrangler dash. As for the harness, relay...etc. I took everything out of the wrangler. I then took it all out of the cherokee and transplanted it into the YJ. Try not to overanalyze it.
post #71 of 145 Old 05-25-2006, 02:03 PM Thread Starter
Tomb Raider
Addicted...
Coming soon........
post #72 of 145 Old 05-25-2006, 02:48 PM
instg8tor
Nice looking Jeep!
Jeez TombRaider that thing's looking great!
From what I've read the AW4 won't hold 1st when you have it in 1-2 position. Check out AW Shifting www.awshifting.com
I've got his kit and it allows you to manually control which gear you want and lock up the tranny in any gear. Should be just the ticket for my swap into my YJ (I don't have the TCU).
Cheers!
instg8tor is offline
post #73 of 145 Old 05-26-2006, 10:49 PM
DEAN062961
IT WORKED MY 4.0 IS RUNNING HOWEVER NO ROOM FOR FAN ( I PUT A HOLE IN THE RADAITOR OOPS AT LEAST IM PAST THE WIRING THANKS FOR THE HELP,
post #74 of 145 Old 05-29-2006, 05:19 PM
1900WranglerEFI
did you have to regear for 2.5-4.0 swap>?
1900WranglerEFI is offline
post #75 of 145 Old 05-29-2006, 11:56 PM
cody11ca
thats awesome, love to do the same.
cody11ca is offline
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 07:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 01:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 05:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 01:40 PM
