Tomb Raider buildup #1 - Page 4 - JeepForum.com
post #46 of 145 Old 04-23-2006, 07:59 PM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Well, I took your advice and rewired my fan. The cherokee donor actually had an auxillary fan equiped. I used that relay, traced the wires and hooked it up. Ran the engine tonight and got the engine to 200, and no fan. The relay is in the PDC and all the wires are there. I simply hooked the power and ground up. But no go. Just now typing this, I wonder if it blew the fuse when it tried to come on. Hmmm.... brb!
Nope. I guess I will have to trace the other wires to make sure they are all connected.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #47 of 145 Old 04-30-2006, 12:28 PM Thread Starter
Tomb Raider
Addicted...
It's coming along....back on her own 4 feet.
post #48 of 145 Old 04-30-2006, 01:45 PM
jeepin1995
jeepin1995's Avatar
looking good!! i started to unhook everything in my donor (89 cherokee) today..... i don't think it's gonna be as easy as i thought. there's a LOT of wires..... they all go to little connections here and there. does all this gotta be swapped??? thanks in advance!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #49 of 145 Old 04-30-2006, 06:49 PM
Ryanpowell167
.........Got enough flex room there???
Black 1992 wrangler, 40" creepy crawlers, d60/14b 350tbi/700r4/np205, spring over on 4" springs.
2011 Ford F-150 Raptor, whipple supercharged...
Ryanpowell167 is offline
post #50 of 145 Old 04-30-2006, 07:00 PM
rbn1357
rbn1357's Avatar
*chant* "Bigger Tires. Bigger Tires. Bigger Tires."
rbn1357 is offline
post #51 of 145 Old 05-01-2006, 12:56 PM Thread Starter
Tomb Raider
Addicted...
Hmmm....wires. I've seen lots of em lately...lol. Well, the ones that go into the bulkhead connector on the drivers side you can just disconnect the bulkhead. There is an 8mm hex head screw holding that on. The ones next over from that is a big bundle that is for all the dash stuff. You can just cut all those. Next over from that is a bundle of about 17 wires I think. That goes into the transmission computer. Don't cut those. If you go in under the dash on the passenger side, there is a silver box attached behind the dash. Green connector to it. It's the transmission control computer. Unhook it, then pull the wires out the firewall. I basically beat the hell outta the dash till I got all the plastic out of the way so you can pull the connector through the hole in the firewall. Hope that helps!
As for the bigger tires.....gonna have to save up for some 37" MTR's. I drive this as my daily driver, so need the radials for highway driving.
post #52 of 145 Old 05-01-2006, 05:35 PM
jeepin1995
jeepin1995's Avatar
the wires for the transmission comp..... i'm swapping in a manual trans as well. do i still need the computer????
post #53 of 145 Old 05-01-2006, 05:40 PM Thread Starter
Tomb Raider
Addicted...
Nope, but I would still not cut those wires. Much cleaner to just leave the connector there unhooked than having 17 wires to cut and stub off.
post #54 of 145 Old 05-02-2006, 04:14 AM
jeepin1995
jeepin1995's Avatar
appreciate it a lot!!! i'm sure i'll have more questions as i progress...
post #55 of 145 Old 05-06-2006, 08:18 PM Thread Starter
Tomb Raider
Addicted...
Got bored this evening, waiting on parts. Thought I would test out the springs. I stood in the pic for reference of jeep size.
post #56 of 145 Old 05-06-2006, 08:37 PM
Ryanpowell167
Holy crap that thing is massive...How much lift do those springs have? I know its SOA but wonderig how much total lift you have. Looking good man, what else you lack besides iinstalling the fenders?
post #57 of 145 Old 05-06-2006, 09:10 PM
jeepin1995
jeepin1995's Avatar
i knew my jeep had a twin out there!!!! looking good!!
post #58 of 145 Old 05-06-2006, 09:31 PM Thread Starter
Tomb Raider
Addicted...
Ditto
post #59 of 145 Old 05-12-2006, 08:38 PM Thread Starter
Tomb Raider
Addicted...
Just a slight update,
Shocks and exhaust can be crossed off the list of to do's. Look ma! No cat! Total exhaust cost....
$40 for front pipe
$70 for muffler/tailpipe combo
$3 for 2ft of straight pipe.
Welded the straight pipe myself
$113 bucks for complete exhaust from manifold back.
post #60 of 145 Old 05-13-2006, 07:23 AM
jeepin1995
jeepin1995's Avatar
i see u cut your skid plate..... why did u have to do that? clearance problems with ur t-case?
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 07:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 01:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 05:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 01:40 PM
