Tomb Raider buildup #1 - Page 3 - JeepForum.com
post #31 of 145 Old 04-18-2006, 10:46 PM
dennis690
Thanks for doing a great job documenting your swap. Your information is helping me plan my swap. I just finished getting the everything pulled out of my donor 92 Cherokee tonight. I am using the auto as well, so I pulled the complete harness including the ISS so hopefully my wiring will go as smooth. What are you planning to do for a shifter? Also I noticed the shifter marked 1/2, 3 OD. can this tranny be made to shift 1,2,3,OD?
Are you going to use the front axle out of the XJ when you do your SOA?
92 YJ on 35s
dennis690 is offline
post #32 of 145 Old 04-19-2006, 07:55 PM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Dunno if the tranny can be made to do 1,2 separate. Using the YJ d30. Your welcome for the writeup. There are many out there....this is just mine. Side note....Ordered the 8.8 install kit from M.O.R.E. Man this stuff is top notch quality. I highly recommend them if you are doing the 8.8 install.
Little more done today.
Axle mocked up.
TCM mounted
Shifter mocked up.
Started cleaning up engine bay wiring.
Tomb Raider is offline
post #33 of 145 Old 04-21-2006, 12:38 AM Thread Starter
Tomb Raider
Addicted...
Well...while swapping axles, I decided to move the axle back about an inch. Gave me a bit more wheelbase, while not having to disturb the fuel tank. In doing that, the fenders were no longer centered.....time to pull out the grinder.
Before...
After...
post #34 of 145 Old 04-22-2006, 09:04 AM Thread Starter
Tomb Raider
Addicted...
Ok, back to work. Finished up the fenders, and installed the electric fan today. Man it's a tight fit, but I think it will work out well.
post #35 of 145 Old 04-22-2006, 11:43 AM
jeepin1995
jeepin1995's Avatar
ok..... just made up my mind that i'm swapping my 4 cyl for a 4.0..... it's gonna be a stroker tho. what radiator did you use? the one from the cherokee or a different one? also, the transfer case output shaft, how much difference is it between where it is after the swap and where it was before? (further back or further forward?) and by approx. how much? thanks!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #36 of 145 Old 04-22-2006, 12:07 PM Thread Starter
Tomb Raider
Addicted...
Using the stock YJ radiator. The 4 and 6cyl radiators are the same. As for lenght, the end of the transfer case is about 1-2" farther back than stock. Any good driveline shop can cut down your driveshaft for you for around 50-75 bucks.
I like to build stuff. Want to know what I build, you can google it
post #37 of 145 Old 04-22-2006, 12:59 PM
phlex234
phlex234's Avatar
just of pure curiosity what are the benefits of the 242 over the 231? or did you keep the 242,, cuz it would be easier, than finding and buying a 231 with 23 splines?
HI, my name is phlex234 and i approve this message because it's my destiny
Jeep 2.5 Low Output club member #2
92 Red YJ, 3.5 Bds lift, 1" body lift, 1" motor mount lift, 33 in tires, long travel DT3000 shocks, m.o.r.e. 3/8 boomerang shackels, 4:56 gears, Tj flares, rock-it man front and rear bumper, Terraflex SYE and Tom Woods CV driveshaft, herculined tub, custom homemade rocker panels, powered by the almighty 4 cylinder
phlex234 is offline
post #38 of 145 Old 04-22-2006, 01:45 PM
jeepin1995
jeepin1995's Avatar
i'm almost 100% sure i can handle this swap, i have the donor vehicle, all wries and everything are still in it. the electronics are the only thing that worry me. i also gotta find a manual trans. can my 231 t-case be used (outta a 95 4 cyl yj)? what changes need to be made? thanks for the help and i'm sure i'll ask many more questions as i prepare for this more.
post #39 of 145 Old 04-22-2006, 05:12 PM Thread Starter
Tomb Raider
Addicted...
The difference in durability is slim to none. The one thing that interested me about the 242 is the parttime 4wd. The 231 has either fulltime, or none. I did find a 23 spline input shaft for the 231, and I will probably keep it for a backup. The other reason.....the 242 was already attached
Your tcase will not work as it stands. You can change the input shaft to 23 splines on the tcase tho, and it will bolt up to the ax-15 just fine.
post #40 of 145 Old 04-22-2006, 06:37 PM
Rodeo1488
By These Things I Stand !
Rodeo1488's Avatar
Scott, what a great write up!!! I sent you a PM about coming and getting the 2.5L from you on Sat. Let me know what you think. Too bad you can't bring that beast to STL so I can see it.
White Jeep Club Member #1488
"Sometimes, there's Justice.......Sometimes, there's Just Us. "
- Living my life on a Thin Blue Line -
Originally Posted by HolidayJeep
If that doesn't work, here's what you do. Buy a bunch of burritos and tie them to pieces of string. Then tie the strings to your Jeep. Then, when the meskins come out of the house drawn by the smell, you drive away. The meskins will chase burritos for miles and miles.
Rodeo1488 is offline
post #41 of 145 Old 04-22-2006, 07:20 PM
jeepin1995
jeepin1995's Avatar
where's a good place to find a 23 spline input shaft for the 231? and how hard was the electronics to get hooked up?
post #42 of 145 Old 04-22-2006, 07:32 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
you've obviously got the skills to fabricate and weld...
time to get started on an anti-wrap bar. a little searching on the forums and you shoudl find plenty of write-ups. that'll eliminate the axle wrap you'll have that will lead to a sagging rear passenger side leaf.
looks great man.
congrats
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #43 of 145 Old 04-22-2006, 10:50 PM Thread Starter
Tomb Raider
Addicted...
Nothing major done today.....but lots of little things.
Pretty much finished up the engine bay wiring. Still a few wires that I haven't mated up, but mostly done. That freggin E fan sucks. I mean sucks alot of air! Nice fan for a 95 By the way, soldering sucks!
Wired the fan to a switch in the event I need to turn it off in high waters. Also got a new transmission cooler mounted and hooked up. I think the radiator would have worked, but I thought this would be added security for keeping the tranny cool. Few other minor things. Mostly poking around and getting the small stuff done and double checked.
Next weekend should be very busy. Front axle install, rear axle burn in, Hopefully the crossmember fabbed up. Only a few pics this time. More next weekend!
post #44 of 145 Old 04-22-2006, 11:21 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
you installed the switch on the 12v signal wire of the relay and not the 12v power source or supply wire going from the battery or to the fan, correct
i don't know how you have your fan wired but IF you don't have a relay picked out yet, SPAL makes a very nice heavy duty and WATERPROOF relay with plenty of wire for the install.... cost is about $40 or so and it comes with a thermoswitch, i chose 180degrees.... i got mine from http://www.turbotime.us/
soldering some heavier wires does suck... i find the 100watt autozonbe soldering gun to do the best job for under $17.... fyi
post #45 of 145 Old 04-22-2006, 11:23 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
SPAL relay kit with thermoswitch
http://www.turbotime.us/ProductDetai...000-1115603199
SPAL relay kit without switch
http://www.turbotime.us/ProductDetai...000-1115606188
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 07:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 01:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 05:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 01:40 PM
