Tomb Raider buildup #1 - Page 2 - JeepForum.com
post #16 of 145 Old 03-27-2006, 02:46 PM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Update......
Just found an 8.8 axle for the jeep. I pick it up thursday. $150 bucks wheel to wheel. 4.10's, disc's and the limited slip. Woot! Just thought I would share my excitement.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #17 of 145 Old 03-31-2006, 07:48 PM Thread Starter
Tomb Raider
Addicted...
Got the mounts welded up and the engine is now in the bay under its own two feet! Tomorrow I start tackling the tranny crossmember.
post #18 of 145 Old 04-01-2006, 07:25 PM Thread Starter
Tomb Raider
Addicted...
Well....plans changed a bit today. I am also going SOA and putting an 8.8 in the rear, so I decided to get the springs out and remove the D35. Was a long day. Even got my wife in on the fun. She actually grinded all the mounts off the 8.8 while I wrenched on the jeep! Gotta love a good wife.
post #19 of 145 Old 04-02-2006, 05:28 AM
brundz
haha wow thats a pretty big sudden change of plans...didn't you just put on that lift you had on it? what are you doing with the old leafs?
brundz is offline
post #20 of 145 Old 04-02-2006, 07:11 AM
akjmax
Man, you are a glutton for punishment. Good luck.
akjmax is offline
post #21 of 145 Old 04-02-2006, 08:19 AM Thread Starter
Tomb Raider
Addicted...
Well...not really a sudden change. I knew this is where i was going with it...just didn't plan on doing this part of it that day. I just recently put on the body lift, but the spring lift was there when I bought the jeep. As for the leafs, I'm actually trading with someone who has 2" leafs so I can do the SOA. Mine were 4", and just to big for my SOA project.
akjmax, my wife says the same thing every day she glances out back and looks at me wrenching on it....lol
post #22 of 145 Old 04-02-2006, 08:27 AM
brundz
wow that things gonna be massive...good luck with the motor swap. i've always wanted to do it but with my luck i'll never get it running right so i'll just stick with the 4 crazy squirrels
brundz is offline
post #23 of 145 Old 04-02-2006, 08:20 PM
crb577
awesome work with everything. Can't wait to see it with the SOA. I'm doing the I6 swap but with the AX15 tranny should be interesting. I'm planning on a week with a couple buddies to get the old 4 banger out and the already pulled 6 in and wired. But that won't be until sometime this summer. but this thread definately helped a lot. so hard to work on the jeep while going to school and working full time. so the summer when i only have to work fulltime is nice. I have everything i need except for my CV shaft which i have to wait to measure for anyway. I'm putting a stage 1 clutch , full tune up, already have the exhaust, and an SYE kit in all at the same time should be fun...
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,SOA xj rear 100" wheelbase, homemade greasable boomerang shackles, SS braided lines, 1" prothane body lift, 35" TrXus M/T, smitty built XRC.
lots of gen right armor and rear stinger.
crb577 is offline
post #24 of 145 Old 04-02-2006, 09:05 PM
TellyDSP
Poland and PPV!!!!
Good stuff
Originally Posted by Tomb Raider
I'd be frightened to crawl around under there. Cinderblocks are not the best choice for jack stand bases. Even worse when they're standing.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #25 of 145 Old 04-02-2006, 09:08 PM Thread Starter
Tomb Raider
Addicted...
Originally Posted by TellyDSP
Good stuff
I'd be frightened to crawl around under there. Cenderblocks are not the best choice for jack stand bases. Even worse when they're standing.
I only have it on those for "storage." When i'm working on it, whichever end im on, it is supported by the hoist.
post #26 of 145 Old 04-02-2006, 09:12 PM
bobbert350
bobbert350's Avatar
looking good let me no how everything turns out.. im curious..
bobbert350 is offline
post #27 of 145 Old 04-03-2006, 10:14 PM
crb577
have you done any of the wiring for the 4.0 at all... is it fairly easy cause last minute changes and i think i may be pulling this swap off in a weekend.. call me crazy it'll be nuts but i think the guys and i can pull it off... just wanted to know how the wiring was pm me.
thanks, chris
1993 Jeep Wrangler
crb577 is offline
post #28 of 145 Old 04-14-2006, 12:44 PM Thread Starter
Tomb Raider
Addicted...
Update.....
She's alive! Finally got her wired and she fires right up! Man that was a good feeling. Although...I did run into one glitch that slowed me for awhile. Some cherokees came with an antitheft security system. Well....it's a PITA. Lets you crank and turn the engine over....but won't fire up for more than a second before it dies. Sooo....found a local autoshop that had a 95 cherokee without the security system in it sittin out back. $50 bucks for the PCM and I was rockin!
Few things of note for ppl interested in this. Literally......five wires from your wrangler will run the cherokee engine.
1. Yellow ignition wire (start)
2. Red +B 12v wire to ignition
3. White/yellow wire for the fuel and ASD relays
4. Black ground wire
5. Wire from PDC to fuel pump.
Fire.
The one thing that is great about this swap....if you have a complete donor, meaning the entire harness and all accessories...you can basically just plug and play. It sounds over simplified...but it's almost that easy. Just make sure, as I noted.....that the PCM(computer) does not have the security system.
As you can tell...im a bit excited today. Now I can start puttin her back together!!!
post #29 of 145 Old 04-15-2006, 04:14 PM
crb577
My donor is a 91 Renegade that the body was shot so I pulled the 6 cylinder out and have everything to go with it so hopefully it'll be that easy. About a week during the summer is what i'm hoping on for a SYE kit, complete 6 cylinder swap, and i'm going to put a stage 1 clutch in, in the process.
1993 Jeep Wrangler
crb577 is offline
post #30 of 145 Old 04-15-2006, 04:43 PM Thread Starter
Tomb Raider
Addicted...
Small update,
Started in a bit on the 8.8
Removed everything, and welded the tubes.
As I had read previously.....weld one side, the flip and weld other...back and forth...to keep from warping the tube. Not the prettiest welds...but I think they will hold.
Tack...
And weld....
Also got tired of having to go inside to look up something or find an answer while working....so had an old Pentium 3 pc I got for 75 bucks awhile back. Brought it out in the garage...lol. Has wireless connection to net...works awesome. Much better than running inside all the time.
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 07:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 01:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 05:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 01:40 PM
