Tomb Raider buildup #1 - Page 10 - JeepForum.com
post #136 of 145 Old 11-25-2007, 07:54 AM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
Originally Posted by 97MilitaryTJ
I am doing a 2.5 to 4.0 swap in a 97 TJ. Will my 2.5/ 3 speed auto bolt up? If not what tranny do I need? Thanks, Kent
Nope. You will need an ax-15, or whatever auto came behind the 4.0L. And with that, you will need the tcase that bolts to the tranny....or change the input gear of your tcase.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #137 of 145 Old 03-04-2008, 04:08 PM
cosminciortan
cosminciortan's Avatar
thanks tombrider for this thread. i'm getting my 4.0L+auto+tcase this weekend. the guy already parted out the alternator and ps pump. can i use the ones on my 2.5?
since i'm not getting the whole car, are there things i should look out for?
how far back your t-case is now as opposed to stock? how did this affect the driveshafts?
and finally, what is "hack-n-tap"ing the tcase?
thanks
'95 2.5l red YJ. 35"BFG MTs on 4.5"SKYJACKER lift+ 5/8"Boomerangs, overhauled AX5 (still sucks)
smittybilt flares, bestop softtop and doors, double core aluminum radiator with Flexalite fan, new brakes allround, all poly bushings, armour
cosminciortan is offline
post #138 of 145 Old 06-07-2011, 08:02 AM
YJames90
YJames90's Avatar
Trying to do the 98 4.0 ZJ into the 90 YJ 2.5. The problem is that the YJ has one big computer plug and the ZJ has 3 plugs, 2 connecting to the motor and the third I dont know where it goes, im guessing to the bulk head?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #139 of 145 Old 12-03-2013, 08:24 PM Thread Starter
Tomb Raider
Addicted...
Pictures fixed...again :-)
post #140 of 145 Old 12-04-2013, 11:37 AM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
Great overall write up.
I wish you had spent more time documenting in images the work you did on the skid plate as well as how you determined the mounting positions of the motor mounts. It seems as if the wiring would need it's own write up, but you make it sound very simple. Like most people, wiring is my weak point.
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 33" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R
YJOTM never
05 LJ Rubicon "Ghost"
Luck Favours The Prepared
Luuca is offline
post #141 of 145 Old 12-04-2013, 06:33 PM
Ironazz
Great write up! Excellent work.
Ironazz is offline
post #142 of 145 Old 12-05-2013, 05:43 AM
tdewit
On the positive side, Great job, well planned and executed. I am drooling over that Jeep. Having said that, looking at some of your photos, I have concerns regarding some of your (non existing) safety practices.
tdewit is offline
post #143 of 145 Old 12-05-2013, 08:20 AM Thread Starter
Tomb Raider
Addicted...
Not one thing of this was "planned" This was the first "major" project on a jeep I had ever done. As for concerns....we all have our opinions and I appreciate yours. Was this done to OSHA standards, of course not. Was I 100% safe all the time...certain I wasn't. However...it was an amazing learning experience of which I could not have paid to get. I now own a shop, and that shop is 100% safe. Cheers to you sir for your comments.
Thank you.
The skid plate holes were determined by where the bolts for the tranny mount were...lol. The engine mounts were placed based on being able to get my hand behind the rear of the engine from the engine bay. There is no exact spot for them. You hoist the engine in the bay (safely of course tdewit) and bolt the mounts to the engine. Move the engine until you have enough room in front for your fan not to eat your radiator and in rear to give enough room to get your hand behind the the head to get those pesky top bolts on the tranny bellhousing. The left to right is set by the mounts. Once the engine is in place.....then I drilled the holes for the tranny mount. Nothing to it
As for wiring....it's usually everyone's scary part. And...it can be a pain. however...my advice on this is, get a subscription to an online manual such as alldatadiy.com They are invaluable and not expensive. The text books you buy at the stores are way to generic and don't show you all the connectors/wire colors etc.
This write-up has been around for many years and have been honored to have helped those who used it as reference. Cheers.
post #144 of 145 Old 12-05-2013, 10:08 AM
Luuca
Luuca's Avatar
Originally Posted by Helldorado Customs
Not one thing of this was "planned" This was the first "major" project on a jeep I had ever done. As for concerns....we all have our opinions and I appreciate yours. Was this done to OSHA standards, of course not. Was I 100% safe all the time...certain I wasn't. However...it was an amazing learning experience of which I could not have paid to get. I now own a shop, and that shop is 100% safe. Cheers to you sir for your comments. Thank you. The skid plate holes were determined by where the bolts for the tranny mount were...lol. The engine mounts were placed based on being able to get my hand behind the rear of the engine from the engine bay. There is no exact spot for them. You hoist the engine in the bay (safely of course tdewit) and bolt the mounts to the engine. Move the engine until you have enough room in front for your fan not to eat your radiator and in rear to give enough room to get your hand behind the the head to get those pesky top bolts on the tranny bellhousing. The left to right is set by the mounts. Once the engine is in place.....then I drilled the holes for the tranny mount. Nothing to it As for wiring....it's usually everyone's scary part. And...it can be a pain. however...my advice on this is, get a subscription to an online manual such as alldatadiy.com They are invaluable and not expensive. The text books you buy at the stores are way to generic and don't show you all the connectors/wire colors etc. This write-up has been around for many years and have been honored to have helped those who used it as reference. Cheers.
I will be using it as a reference and thank you for your time and work documenting the process I will check out the online manuals. With the i6 auto Cherokees so dang cheap out here its a no brainer swap. Thanks again.
Posted via my pretentious iPhone.
YJOTM never
Luuca is offline
post #145 of 145 Old 02-02-2014, 04:59 PM Thread Starter
Tomb Raider
Addicted...
I'mmmmm baaacccckkkk.....
Tomb Raider question floridalawdog Wrangler General Discussion 5 08-13-2008 07:03 AM
Tomb Raider Ad. rubi rubicon1000 TJ Wrangler Technical Forum 4 05-03-2008 01:17 PM
Tomb Raider Look? Rick5150 TJ Wrangler Technical Forum 35 12-13-2004 05:03 PM
tomb raider desertsport TJ Wrangler Technical Forum 11 09-25-2003 01:40 PM
