Tom95YJ's "The Smurf" Build. - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Tom95YJ's "The Smurf" Build.
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 05-23-2013, 10:14 PM   #1
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Last Sunday, I had traded my Auto-X Project/DD Miata for a Pretty clean '89 Wrangler Islander . After looking for someone to trade for almost 2 years I found someone was willing to trade.
Specs on the YJ :
1989 Islander Edition (Pacfic Blue A.K.A. Smurf Blue )
4.2Lw/ Ba10 (works for now)
Hardtop with Full steel doors
208,000 miles
RUST FREE minus the P/S front fender
The Bad : Jeep would not idle on its own, and front axle would not engauge in 4 wheel drive. Minor repairs that would scare away most who are not too knowledge able with Jeeps .
My Plan for this Jeep is to keep it small yet capable for a DD/Light duty trail rig
Mods I intend on doing will be
2.5" Old Man Emu Springs (36R's)
Bilstein 5100 Shocks
TJ Grizzly wheels
31x10.50 Tires Probably a set of BFG KM2's
Take off Axles from a 4 Banger YJ for the 4.10 gears ( YJ has 3.07's)
Front and Rear Spartan Lockers
Front and rear bumpers most likely from Eddie (Beserk on here ) he did a Phenomenal job on the ones on my Last YJ !
Rock Sliders with a Tube on them I had PSC Rocker Knockers on my last YJ I may fab some for this one.
4 Hid Offroad lights like I have on the XJ (2 on bumper, 2 on Windshield frame )
8,000 lb Winch Either a Warn VR8000, or another Smittybilt XRC8 comp like I have on the XJ .
Spray bed-liner inside the entire tub.
Here are some pics from the first day once I got home with it.
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 10:25 PM   #2
Tom95YJ
Tom95YJ's Avatar
On Monday after work I had to take advantage of the Beautiful weather outside .
So the obvious thing to do was to remove the Hardtop and Doors, Then I had worked on the interior a little. I had replaced the stock shift knobs with the ones I had in my last YJ, Rewired the head unit so it worked, I had also installed my son's car seat so he could enjoy the Jeep with me . After I was finished with that I went back to working on the exterior and Bedlined the T-case skid, Frame, Front bumper, Rear crossmember, and Hitch.
After I was done doing my projects TJohnson88 came over to check out "The Smurf" We started talking about the running issue so we popped the hood and started to tinker with the carb. We had found a broken Vaccum line under the carb. So we took some extra line off another hose and cut a small peice to install on the bad line. After that it wanted to idle but the Idle set screw was set to like 300 rpm so it died. Tyler had started it up and I had adjusted the screw a little and have it Idling at 750-800 rpm and it runs on its own now. But it has a slight stumble while Idling but when driving its smooth as silk so I am sure the timing is off. I'll address that over the weekend.
Unread 05-23-2013, 10:36 PM   #3
Tom95YJ
Tom95YJ's Avatar
Today I had Ziptied up all the wires under the dash to get rid of the ratsnest of wires . My Neighbors Brother in law sold me his stock TJ Grizzly wheels so I threw them on the YJ today Which makes it look much better !
Unread 05-23-2013, 11:00 PM   #4
ashland82391
Out of money yet...Yup!
ashland82391's Avatar
Subbed
ashland82391 is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 11:03 PM   #5
95YamJam
Looks like a solid rig to start with!
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline   Reply With Quote Quick reply to this message
Unread 05-23-2013, 11:24 PM   #6
Tom95YJ
Tom95YJ's Avatar
Yes is it a solid rig. It has lived in Southern California for 22 years the last 2 have been here in Utah. It is rust free minus the p/s front fender. Which will be replaced soon.
Sent from iPhoneusing JeepForum
Unread 05-23-2013, 11:31 PM   #7
ashland82391
Sounds like a good opportunity to build some tubes! :-)
Unread 05-23-2013, 11:40 PM   #8
Tom95YJ
Tom95YJ's Avatar
Tube fenders may be In the works down the road But for now I'm just gonna get another stock one.
Unread 05-23-2013, 11:57 PM   #9
zte87
GIVE IT THE ONION
zte87's Avatar
Subscribed!
zte87 is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 05:01 AM   #10
Kdeome
In
Kdeome is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 08:07 AM   #11
DNFJ
Wannabe Desert Rat
DNFJ's Avatar
Oh god another build thread of yours to follow.
Project Leviathan
'00 XJ 8.5" on 35s
Previous:
'00 TJ 2" on 33" Grabbers
'00 XJ 6.5" on 35" KM2s
'96 ZJ 2" on 31" Baja Claws
'93 ZJ - Stock, Totaled
DNFJ is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 09:53 AM   #12
RobzRidez
Following my big blue brother!
90 YJ Islander*Nuttered4.2*MC2150*4" RE Lift*BESRK 1" Boom Shackles*33x12.5x15 BF MTs*Spyder bumper*
RobzRidez is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 07:15 PM   #13
Sparrows
Sub'd!
I just read through your XJ build the other day. Excited to see what you do with the YJ.
Welcome back to the cool table!
Cheers
[URL="http://www.jeepforum.com/forum/f22/warbird-2-a-2242713/"][size=3][b]WARBIRD 2[/size][/b][/URL]
[URL="www.exiledoffroad.com"][size=2][b]EXILED OFFROAD[/size][/b][/URL]
[size=2][b]June '13 YJOTM[/size][/b]
Sparrows is offline   Reply With Quote Quick reply to this message
Unread 05-24-2013, 07:26 PM   #14
Tom95YJ
Tom95YJ's Avatar
Originally Posted by Sparrows
Sub'd!
Cheers
Thanks.
Unread 05-24-2013, 07:37 PM   #15
lawndog21
Iv always like the islanders
lawndog21 is offline   Reply With Quote Quick reply to this message
