Tom95YJ's 99 XJ "Black Betty" - Page 20 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > Tom95YJ's 99 XJ "Black Betty"
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-06-2013, 12:24 PM   #286
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
Originally Posted by Steelo805
Do you have a link to where you picked up the catalytic converter. I can't seem to find gone that low profile.
Www.performance-curve.net
It's a thunderbolt spin cat part # 410250
Sent from iPhoneusing JeepForum
'89 YJ The Smurf Build Thread
'99 XJ Black Betty Build Thread
Tom95YJ is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 12:41 PM   #287
Steelo805
Thanks. Did you just drill a hole after it for the o2 sensor
Steelo805 is offline   Reply With Quote Quick reply to this message
Unread 05-06-2013, 12:56 PM   #288
Tom95YJ
Tom95YJ's Avatar
I did not drill a hole but the exhaust shop that did my exhaust installed a bung
Unread 05-06-2013, 01:06 PM   #289
Steelo805
Great. Ill assume mine should be capable of doing the same.
Unread 05-06-2013, 02:11 PM   #290
Tom95YJ
Tom95YJ's Avatar
Unread 06-04-2013, 03:23 PM   #291
Tom95YJ
Tom95YJ's Avatar
Small update I just ordered my. Header (APN) for the Xj. I'll have it installed within the next couple of weeks with a new exhaust video.
Unread 06-04-2013, 09:35 PM   #292
gfox48
I hope you have better luck then I had.
I couldn't get the one from APN to seat right. It was hitting on the intake manifold which I ended up cracking when I bolted everything down. I ended up with one of headers with the expansion joints in it and have had no trouble with it.
Build Thread: http://www.jeepforum.com/forum/f177/zombie-prep-xj-1500071/
gfox48 is offline   Reply With Quote Quick reply to this message
Unread 06-04-2013, 09:45 PM   #293
Tom95YJ
Tom95YJ's Avatar
For 99's you gotta grind the intake a little
Unread 06-09-2013, 09:12 AM   #294
Camfam07
post pics of those headers do they make those for pre 99's? I have a 96
Camfam07 is offline   Reply With Quote Quick reply to this message
Unread 06-09-2013, 10:54 AM   #295
Tom95YJ
Tom95YJ's Avatar
The header is the same for 91-99
Unread 06-09-2013, 01:19 PM   #296
Camfam07
where did you order it from? APN website?
Unread 06-09-2013, 01:47 PM   #297
Tom95YJ
Tom95YJ's Avatar
Ineedparts.com or something like that
Unread 06-09-2013, 01:53 PM   #298
Camfam07
Thanks! I found it was actually an advertisement on the page for it! post info on how it sounds/runs and all that.
Unread 06-11-2013, 06:57 PM   #299
Tom95YJ
Tom95YJ's Avatar
The APN header came today, Overall quality is good. I do wish the runners were fully welded around on the outside but I assume they were not due to excessive heat when welding which could make the material prone to crack. But other then that they seem great ! With my curse of needing to modify everything I own , I couldn't leave well enough alone. I could not resist the urge to Ceramic coat the header .
Unread 06-13-2013, 08:53 AM   #300
Project1
man with your exhaust thats going to sound really nice ...
Project1 is offline   Reply With Quote Quick reply to this message
