TK's Yellow Krait LJK Buildup - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > TK's Yellow Krait LJK Buildup
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFree Shipping on Soft ShacklesNew! JK/U skid plate system.
Unread 04-18-2014, 03:37 PM   #1
tkfx
CURRENT PICS
________________________________________________
Hello Jeep forum! I have been a long time lurker and a long time user of wranglerforum and I have decided to participate more in this forum as well! So I will start my build thread on here... incoming dump of pictures from the start of this LJ's career with me! Here we go folks, please keep all hands and feet inside your chair at all times, and enjoy the ride!
I just turned 17 and got my license. My parents gave me their yellow jeep. This was little over three years ago.
I really did not like the yellow, I felt like a girl driving this jeep. I was not familiar with the offroad world nor did I care at the time. I took care of my jeep keeping it clean and shiney.
I decided to test its offroad capabilities
Then my Dad asked me if I want a lift kit. I figured why not, not realizing what I was about to get myself into. Here is a stock jeep lifted 4".
Then came the tires and wheels, 33" KM2 and some platidip.
Then came the front bumber customized to my likeing
Then I went on my first wheeling trip with the guys over at wranglerforum. Went to Last Chance Canyon and had a blast. Figured I needed a OBA asap.
With the help from Jerry I was able to piece together a York and get it up and running on my jeep with air outlets in the front and back.
Of course how can you forget the big air horns?!?!?
Then I got myself a smittybilt rear tire carrier and a winch up front, then went wheeling to Calico with wranglerforum.
All of a sudden loss of power. WTF. Drop the cats and discover this.
Went out wheeling with wranglerforum to Miller Trail starting in Frazier Park.
How she sat so far looking clean.
Summer shenanigans.
Then I ordered a set of Metalcloak Fenders because I was rubbing my fender wells in extreme flex. (I should have adjusted my bumpstops, oh well).
I did'nt like my custom smitty front bumper because of the ****ty approach angle and it being full size bumper, so I opted for a Poison Spyder Stubby.
Went out wheeling again to Last Chance Canyon with wranglerforum. The V-Notch was filling in with a bunch of sand and was a cake walk. I took the bypass the first time I went and really wanted to do it the second time, but the second time you didnt even need a spotter.
New addition to the family. Dad dropped a Mercedes diesel in the Willys along with a suzuki samurai transfer case, he is in the process of restoring it still.
tkfx is offline   Reply With Quote Quick reply to this message
Unread 04-18-2014, 03:37 PM   #2
tkfx
Went out to Gorman with some old High school friends who also has a Jeep and a Toyota 4x4. Testing flex on the staircase.
While we were out there, I was stupid and driving too fast on a sandy trail with aired down tires and disconnected swaybars and this happened. Not my favorite moment but a learning experience.
We had 10 people with us that day, so with 10 people we managed to flip over the jeep using just manpower. Only damage I had was my windshield frame got dented. Metalcloak fenders were spotless and the rear plastic fenders were dented. I did not roll, I meerly tipped over. Never doing that again.
Then I found a great deal on a HPD30 off CL. 4.88 gears, Alloy USA Chromo shafts, Alloy USA tube seals, Aussie Locker, Ruff Stuff Diff cover and Ruff Stuff steering kit. All for $500, the catch was that it was setup for coilovers so I had to weld on shock and coil buckets in order to mount everything up.
Well, when I flipped my Jeep, I had to drive it off the trail with a small amount of ATF in the tranny, since it all drained out the dip stick. Turns out a couple months later my tranny died because of my stupidty in trying to drive it off the trail with little ATF. Here is the new 4-speed tranny with only 60k miles on it and here it is being swapped out in the garage. Took me and my Dad 8 hours to get everything to swapped. Those axles on the side are for the willys.
I have a lot of plans for electrical stuff and I didn't want to pay $500+ for a sPod even though I really liked their concept. So I made my own basic "sPod" I call the TKPod I outfitted a box to have 14 fuse holders and 12 relays that will control 12 switches in the cab. All the wires will run as a bundle into the cab including all the power, ground and load wires for each switch. If I want to hook up an accessory to the box, all I do is connect the positive to the appropiate relay wire and connect the ground to the fuse holder ground spots, as well as adding the right fuse to the correct fuse spot and done. Really easy and really simple, it just took a **** load of time to wire everything.
In all I spend around $300 for everything + labor to set it up. In the end I have 12 switches that are independent of the Jeeps electrical system that so far has worked without any problems. Also if I ever get into an accident the switches will be imprinted in my passengers face
Bumpstop, locker and flex test to make sure its all working.
Picked up some rocklights that I found people at pirate raving about. Spend $40 and got 25 LED pods in the mail. Also ordered a 10" light bar from lifetimeleds.
Went out to Calico again with the wranglerforum. It was a Meet N Greet so we had close to 80 jeeps at the meetup. We broke off into several groups and started hitting the trails. My passenger side coil kept falling off, so in the third picture I was going into the obstacle with a coil sitting in my passenger seat, and because of that I blew that shock out.
Got myself a new sound system along with a Sony headunit with bluetooth and Sirus radio.
How she sits now.
Hope you guys enjoyed reading the history of me and my Jeep. There were a couple mods that I did add but didnt have the pictures for and had no idea where it went in chronological order from oldest to newest. I will document my build jeep in this thread from here on out. Thank you for reading!
(Sorry if I spelled something wrong, I was trying to type all this out as fast as I could)
Unread 04-18-2014, 03:45 PM   #3
tkfx
So I have big plans coming up this summer. I wanted to go to 37s and bigger in the future but I didn't really know when. So I finally decided that I will save up my money and do it all at once during the summer when I have no college. My jeep is my DD so I can't have the jeep sitting in the garage everyday.
Here are my plans for summer:
- JKRubi Dana 44 front and rear
- Front Axle Beef Kit (Gussets, Clamshell, Clayton Bridge)
- Ruffstuff Panhard Kit
- Ruffstuff 1 Ton Steering Kit
- Clayton Long arm 3 Link Front
- Clayton Long arm 4 Link Rear
- 1.5" stretch in the front
- 1" Stretch in the back
- 37" MTR/K
- Coilovers
- Currie AntiRocks
So as of now I have the Rubi JK axles being shipped to me now from a doner rubi that was burnt. That I picked up for so cheap that it might be considered stealing.
Couple days ago I picked up 4 remote resi 14" King Coilovers for $1500. Person I bought it from bought these brand new but never got a chance to use it on his YJ. He had a pretty neat YJ project going in his garage that he was parting out.
I plan to use the Ruffstuff coilover tower front and rear and outboard my coilovers at the same time in the rear. With the width of the JK axles I should have enough room to squeeze everything in.
I think Ill run out of funds by the time summer comes trying to pick everything up, I might have to roll with stock JK wheels/tires until I can pickup a set of 37 MTR/ks.
Unread 04-18-2014, 05:28 PM   #4
tkfx
During the summer I'll have my front axle and rear dana 44 with limited slip up for sale. Great time to upgrade the front LP30 and D35 all at once!
Unread 04-22-2014, 09:45 PM   #5
tkfx
Today my windshield light mounts arrived in the mail. I purchased two 6 LED flood lights....made in china... from a local swap meet for $30 each a week prior.
Unread 04-22-2014, 09:46 PM   #6
tkfx
I ran into a little problem with fitment. The side bolts lined up just right. But the bolt in the front would not line up. The bolt kept going in at an angle and not catching any thread. So i had to wallow out the hole and repaint so it doesn't rust....
Unread 04-22-2014, 09:46 PM   #7
tkfx
Got the light mounted
Unread 04-22-2014, 09:47 PM   #8
tkfx
and some shots of my "TKpod" with 12 accessory spots. Look at the size of those horns...
Unread 04-27-2014, 03:42 PM   #9
tkfx
So a very unfortunate turn of events... Unbolted the donor Rubi D44s and found out they were both bent. The rear axle has a nice smiley face and the front only has a bent long side tube. Also the axle shafts in the rear were bent a long with the front driver side shaft. All the ujoints, unit bearing, balljoints and calipers were toast.
Also, the stock lockers on the front and rear are toast. The solenoid on the rear locker has broken and the wires have vanished. The front locker still has its wires and solenoid but the locker will not lock or unlock when given power. Seems like a simple locker design, give the elctromagnet power and it pushes a ring that forces the locker to lock, turn it off and it pushes the ring away, however I don't seem to get any power to the locker magnet. Basically the rear axle is trash, and the front axle is rebuildable.
So today I went and picked up a JK Dana 44 rear with 5.13 gearing and a 1310 yoke installed already for $350. SO my rear axle is set, all I need are calipers.
For the front axle, I plan on retubing it in to get rid of the bent tube and to put in a much thicker tube. I will source a used OEM e locker for cheap and add that in along with 5.13 gearing. I will find or order a set of driver side axle shafts, and I plan on buying a used JK Dana 30 and taking all the balljoints, unit bearings, calipers and rotors and swamping them onto my housing. It will be cheaper for me to rebuild it that way then to purchase new everything. Then I will start replacing things that break with new parts as time goes on. And pictures:
So what do I gain and what do I lose from switching to a JK Dana 44 rear instead of a Rubi JK D44 rear? What I lose is the strength of a 8.8" ring gear and a pinion almost comparable to a D60, along with 32 spline axle shafts. What do I gain? I gain a axle that is a lot cheaper, stronger then a TJ D44, a wider selection of lockers, and an option to do a 35 spline upgrade like the Rubi44 in the future. I don't lose much except for strength, which quite frankly, I am not too worried with these axles under a LJ.
Unread 05-15-2014, 12:19 PM   #10
tkfx
Placed my order with Ruff Stuff on Monday using their Mothers Day sale code of 20% off. All my coilover brackets, steering, and panhard kits come tomorrow!
Unread 05-15-2014, 12:41 PM   #11
ben_badassjeeps
Great build so far, your dad must be so proud of the work you've put in! Still can't believe you scored a set of 4 king coilovers for 1500 bucks. That's an incredible deal! A single pair of those brand new is about $1200. Great work!
Ben Whitney, Owner
Boss Research Inc.
Phone: 778-435-2169
E-mail: [email]ben@badassjeeps.com[/email]
Website: [url]www.badassjeeps.com[/url]
Use the coupon code: "jeepforum2014" for a 5% discount on all of our Currie Enterprises, Genright Offroad, RiverRaider Offroad and RCV Performance Gear!
ben_badassjeeps is offline   Reply With Quote Quick reply to this message
Unread 05-15-2014, 12:45 PM   #12
Tonellin
Awesome work man, this LJ build is coming along nicely
I like how the first thing you did after lift and tires was OBA. Have you found it to be worth while?
06 LJ Rubicon
http://www.jeepforum.com/forum/f22/lj-rubicon-build-1481013/
Tonellin is offline   Reply With Quote Quick reply to this message
Unread 05-15-2014, 06:00 PM   #13
tkfx
I can't thank my dad enough, I am a little guy myself so he has helped me a lot with the heavy lifting and such. I was pretty suprised when the guy selling them for over 2000 immediately accepted my offer of 1500!
Thanks a lot! The York OBA has really been my most favorite upgrade. It airs up my tires super fast and has the power to run air tools... which I need to slowely start buying
My Build Thread:
http://www.jeepforum.com/forum/f22/tks-yellow-krait-ljk-buildup-2337401
Unread 05-16-2014, 09:50 PM   #14
tkfx
Ruff Stuff package came in, 100 LB shipment! Thats a lot of metal! So I got my coilover towers, coilover axle side brackets, GM 1-ton steering kit with the high angle draglink ends, and the panhard kit for the 3 link. Those TRE's and tubes are BEEF, I dont see much that will bend those!
My Build Thread:
Unread 05-17-2014, 07:50 PM   #15
tkfx
Today, my Dad and I decided to try and straighten the bent long side tube on the D44. We went to our metal warehouse and bought 3"x.25" Steel tubing to retube the long side and create a clamshell for the shortside. Here are some pictures of the results and how straight it looks.
We cut the bent section off and left some tubes on the ends. Here is the bent section.. it was really crazy bent.
Axle tubes cut with around 3" of tube left and grinded down.
My Dad is in the process of grinding down the tube on the inner C.
The DOM tubing we used.
Using some heat and a BMFHammer we pressed the tube into the stub.
Same concept for the other side.
Made sure the inner C on the long side was at the same angle as the inner C on the short side. We only retubed the long side, the short side will get a clamshell.
Visual check and it is straight.
My Build Thread:
