A TJ truck build named "Dumpster Dive" - Page 89 - JeepForum.com
 1Likes
post #1321 of 5953 Old 12-21-2012, 05:26 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
That top looks sick. Keep up the great work.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #1322 of 5953 Old 12-21-2012, 06:46 PM
twinstickd20
1979 CJ7
If only you guys could see this top in person then you could really see how awesome it is!
My Build Thread
twinstickd20 is offline
post #1323 of 5953 Old 12-21-2012, 07:56 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks man, you are the only one that has seen it from the day we pulled the headliner material off the TJ hardtop and started cutting the top into pieces.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1324 of 5953 Old 12-21-2012, 08:20 PM
TrailJ
'06 lj
TrailJ is offline
post #1325 of 5953 Old 12-21-2012, 09:01 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by TrailJ
'06 lj
Out to all my subscribers... Vote TJ of the year.....
http://www.jeepforum.com/forum/f9/tj...arted-1450155/
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1326 of 5953 Old 12-22-2012, 02:09 AM
TrailJ
Oops, mobile app fail... Was supposed to say something like:
How about a short. HD video walk around to commemorate the half way point?
'06 LJ
TrailJ is offline
post #1327 of 5953 Old 12-22-2012, 08:06 AM
oalali
Done ! Those rigs are sick !
oalali is offline
post #1328 of 5953 Old 12-23-2012, 12:51 PM
rs4race
I like the 3rd brake light! I should have put one on mine...
My Build
http://www.jeepforum.com/forum/f22/rs4races-build-957569/
rs4race is offline
post #1329 of 5953 Old 12-23-2012, 01:34 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Dude, its so freaking bright to....
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1330 of 5953 Old 12-24-2012, 05:20 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I can't wait to see everything coated in cosmos, its the best color
On a side note, how much do you think it costs the average customer to have a hood professionally painted with 2 colors?
My builds:
and
or follow us on
spyder6 is offline
post #1331 of 5953 Old 12-24-2012, 08:12 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I am itching to see the whole Jeep Cosmos Blue also.
You could probably expect to pay ~320 + tax for a 2 tone job at just about any shop.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1332 of 5953 Old 12-27-2012, 07:51 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I am back to working on this Project again. It's freezing cold out there and all I have is a space heater right now. I got the rear axle under the Jeep and the pinion angle set. I will tack both the spring pads tomorrow night and sit the Jeep down on its own weight in the rear to see how the springs are going to act. If they are good then I can figure out where the shackle bushings will be placed in the frame. I also plan on tacking the bed mounts on the frame so I can remove the bed till final assembly. Once the bed is removed I can remove the tub and take it to work where it's 70 degrees and finish the body work.
I also moved the front axle out where I want it positioned WB set at 116. I need to pick up some 2x3 box tubing because the front frame section from the motor mounts forward is going away. I refuse to lift the Jeep any higher, so I need to build in some up travel up front. If I replace the frame up front with 2x3 I can keep the Jeep really low and still have 5" of usable up travel and the ballistic coil spring mounts will not give me any troubles. I am going to move the steering box up and back towards the tub because of the Astro steering box. It is reversed to the TJ box, meaning the pit man arm points forward. This is perfect for the 4" stretch up front.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1333 of 5953 Old 12-27-2012, 11:59 PM
Bennettj13
Just watch where you have to put those coil buckets. They hang out there a good bit.
::SELLING HALF OF MY JEEP::
Bennettj13 is offline
post #1334 of 5953 Old 12-28-2012, 07:32 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Jimmy, I noticed that last night. Part of it will be addressed with straightening the frame out, the rest will have to be modified like you did. I am guessing they are designed for the CJ frame and to be used with full width axles. Either way I believe they will work once I get them burned in.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1335 of 5953 Old 12-28-2012, 07:46 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Didn't want to get all dirty tonight so I passed on tack welding the bed mounts and axle brackets. I did spend about an hour bonding the 2 piece top together. I have to work tomorrow, maybe I can find time to finish the body work where the 2 pieces go together on the hard top. The bonding compound should be dry by morning. Should have some pictures by Sunday. Maybe even that HD walk around video.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
