A TJ truck build named "Dumpster Dive" - Page 67 - JeepForum.com
 1Likes
post #991 of 5953 Old 09-24-2012, 02:17 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by Hendrix
Here you go guys, I will update,add and repost this list as I go.
Starting from important to least important:
Option 1 Option 2
Currie 4" springs. 12" travel COs or ORI struts
Anti rock or good quick disconnects. CO hoops
Fox resi shocks 12" travel /billstien
__________________________________________________ __
Boomerang shackles
Leaf spring axle mounts, u bolts ,plates
SYE for a 231
4.0L engine harness 97-99. (Jankoid)
6cyl underhood harness 97-99(Jankoid)
4.0L throttle body
Taurus fan assembly (pullapart)
TJ steering column 97-99(Mattam_xp)
2001 XJ center console
99-01 Ram hydro boost set up(pullapart)
Black magic brakes (JK)
2005 fuel pump working or not working.
Spider trax 5 on 5 wheel spacers
Tires, not really wanting to put used on the rig. But, never know when a good deal rolls through.
Full doors, TJ or YJ
Damaged hard top to cut down for a half cab(pending CL find)
Updated list
K.C.C.O.
Carpe Diem
Hendrix is offline
post #992 of 5953 Old 09-24-2012, 03:03 PM
mike_breaker_5
i never thought of this!
i bought 3 hard tops and 2 sets of hard doors for $450. i will have 2 sets of doors/top after i do some extensive repairs. the 3rd top would have been trashed if i hadn't seen this post.
what an amazing idea to chop it down for a half top. i will be following that part of your build with great interest.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #993 of 5953 Old 09-24-2012, 03:14 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I will make you a deal, send me a top and doors, I will make you a half cab for a damaged hard top and doors.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #994 of 5953 Old 09-24-2012, 04:36 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Finally got around to cutting out the passengerside cab close out panel. I think I may weld it in tonight. I have been putting it off forever. With it welded in I can finish the body work on the cab.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #995 of 5953 Old 09-24-2012, 05:12 PM
twinstickd20
1979 CJ7
can't wait to see the tub in paint
My Build Thread
twinstickd20 is offline
post #996 of 5953 Old 09-24-2012, 09:02 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Got it all tacked in tonight along with setting up where the rear frame section will be positioned. I will finish up the welding tomorrow night along with a ton of spot welds in the inside of the tub. Then I need to finish up some filler panels on the inside of the tub. After that it's picture time.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #997 of 5953 Old 09-25-2012, 06:54 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
Awesome man. How is it you have two sweet rides? Skills I guess. My old beater drools everytime I talk to it about what your doing.
Recoil is offline
post #998 of 5953 Old 09-25-2012, 07:58 AM
MountainMan864
Not having kids is the answer recoil.
MountainMan864 is offline
post #999 of 5953 Old 09-25-2012, 10:58 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Little sneak peek of the cab.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1000 of 5953 Old 09-25-2012, 11:21 AM
AustinTexasXJ
1987 MJ Comanche
sweet job on this bud,
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #1001 of 5953 Old 09-25-2012, 12:19 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks, its a long way from finished.
tekeum likes this.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1002 of 5953 Old 09-26-2012, 09:23 PM
kyle_craig
Awesome progress. This build is an inspiration.
kyle_craig is offline
post #1003 of 5953 Old 09-27-2012, 09:50 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Got dibs on a steelhorse 2 piece top that's in bad shape. Freebie.... It will make a great top to cut up and make a half cab. I may attempt to keep the top 2 piece, but my gut is telling me it will probably be better to just make it all one piece.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1004 of 5953 Old 09-27-2012, 10:14 AM
AngryTJ
Great work so far Hendrix. When you painted your wheels what grit sandpaper did you use to prep the wheels?
AngryTJ is offline
post #1005 of 5953 Old 09-27-2012, 11:04 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
400 grit and a red scotchbrite pad.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 11:49 AM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-10-2011 12:18 AM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 07:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 11:11 AM
