A TJ truck build named "Dumpster Dive" - Page 56 - JeepForum.com
 1Likes
post #826 of 5962 Old 07-17-2012, 08:41 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Yeah, the cab to bed transition is fugly. But, the Jeep as a whole looks close to what I imagined. I have a plan to add a permanent roll bar with some clean lines in the bed. And a hard top would be muey bueno.
My design has about 4 inches longer bed also.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #827 of 5962 Old 07-21-2012, 02:02 PM
B2CARPEN
You mentioned you are in need of JK coils?
JF Classified - JK stock suspension
Founder of
B2CARPEN is offline
post #828 of 5962 Old 07-27-2012, 03:51 PM
mjb5738
this project is AWESOME. been following it for a few months now. you've hit the nail on the head as far as fabrication goes.
mjb5738 is offline
post #829 of 5962 Old 07-28-2012, 10:52 AM
djflyy
I'll be interested to see what you do for the roll bar. Your eye for detail and clean appearance is almost unparalleled, so I'm sure it will be as attractive and complimentary as it will be functional.
djflyy is offline
post #830 of 5962 Old 07-28-2012, 08:34 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Look for simple roll bent tubing for the cage sweeping back like a fast back, double tube over head in the cab with roll bent spreaders. Lots of simple clean lines. Nothing real cluttered.
Not returning to work on this Jeep till Sept or Oct. then it will be a 3-4 day a week till the deadline. Should go pretty quick I have most of the parts to get her rolling.
Parts left to buy:
Rebuild kit and SYE for the 231
Rear DS
Front Fox resi shocks
Fuel pump
Fuel lines
Brake lines
Tube for the track bar
Boomerang shackles
Hydro boost brakes (99-01 ram truck ) pull a part
Seats
Tube for cage
Poly lower CA frame brackets
Truck lights
Savvy tail lights
Xenon rear flares
33-35 inch tires
Source from Jeep junk yard:
Dash pieces (located) barrows
Column (located) barrows
Dash wire harness (located) jankoid
Cluster (located) Art
01 XJ console pull a part
engine harness (located) jankoid
AC compressor(located) barrows
Condenser (located) barrows
Under hood harness (located) jankoid
E brake handle and cables. Davey's jeeps
And the list of Fabrication is way longer........
K.C.C.O.
Carpe Diem
Hendrix is offline
post #831 of 5962 Old 07-28-2012, 08:40 PM
Jeffro06
Jeffro06's Avatar
I'm distracted by your new avatar....no clue what your status with dumpster is.
Jeffro06 is offline
post #832 of 5962 Old 07-28-2012, 09:17 PM
G Beasley
Your building a double B hoop like Harold Off used in his Scramblers ?
G Beasley is offline
post #833 of 5962 Old 07-28-2012, 09:17 PM
aw12345
Parts left to buy:
Rear DS
Fuel pump
Fuel lines
Brake lines
Boomerang shackles
Seats
Tube for cage
Truck lights
Savvy tail lights
Xenon rear flares
33-35 inch tires
Dash pieces
Column
Dash wire harness
Cluster
01 XJ console
engine harness
AC compressor
Condenser
Under hood harness
I got a good cluster you can have out of a 1997 tj, sold all the dash wiring harness. You can have it for whatever shipping is
Have a center bezel out of an 04 also
aw12345 is offline
post #834 of 5962 Old 07-28-2012, 09:22 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
More like a modern version. Kinda buggy style. I will see if I can find a picture.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #835 of 5962 Old 07-28-2012, 09:23 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks Art, I can check that off then.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #836 of 5962 Old 07-28-2012, 09:27 PM
Barrows
I have a compete dash out of a 97 I will sell really cheap....
Barrows is offline
post #837 of 5962 Old 07-28-2012, 09:30 PM
G Beasley
I will be curious to what you come up with . I hate bending B hoops ... much less two of them .
post #838 of 5962 Old 07-28-2012, 09:34 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thinking it will actually be one halo hoop from the windshield uprights, then 2 straight B hoops kicked back a little. Just depends on if I can fit it all under the custom half cab.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #839 of 5962 Old 07-28-2012, 09:38 PM
G Beasley
If I was bending that I would figure in one stick of tubing ....
As waste
post #840 of 5962 Old 07-28-2012, 10:17 PM
Jankoid
What year model you need the harnesses for? Got most of the other stuff I think.
Jankoid is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
