A TJ truck build named "Dumpster Dive" - Page 47 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > A TJ truck build named "Dumpster Dive"
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shippTJ Dana 60 - BOLT IN REAR
Unread 04-19-2012, 07:58 PM   #691
Hendrix
TJ Truck?
Hendrix's Avatar
Updizzle.....I ran into a problem I should have known better...
I cut the back off the frame , not realizing that the frame would twist without a temporary crossmember in place in front of the cut. I did not realize it till it was time to align the body mounts to the frame.
Quick fix though. I brought my porta power home from work and pushed the rails apart to finish the body mounts. I will tack in a scrap to keep the frame in the proper location till I build the back half.
All the body mounts are tacked in location and the tub is bolted and sitting level. I need to clock the transfercase to the AW4 before I can finalize the transmission crossmember and cut the tub out to clear the t-case.
Any ideas on how to clock the tcase to the AW4?
I need to clean off those old Ballistic fab 3 link brackets to make way for my new 5 link brackets.
Hendrix is online now   Reply With Quote
Unread 04-19-2012, 08:04 PM   #692
Imped
Balls
Imped's Avatar
I really need me some of those body mounts.
OlllllllO
Float Test Build
IndyORV
If you see a dead picture link of mine and would like it fixed, please PM me the link to the post and I'll fix it. Thanks
Imped is offline   Reply With Quote
Unread 04-19-2012, 08:08 PM   #693
Hendrix
TJ Truck?
Hendrix's Avatar
Dude, quit saying it and buy some. I had mine in 3 days. You could cut off the old ones and weld those on in a couple hours.
Also, I can't wait to get that tub out of the way so I can put the axles under the frame and build the suspension with nothing in the way. It's going to be so easy.
Unread 04-19-2012, 08:21 PM   #694
aw12345
Attachment 384090
Attachment 384092
Attachment 384096
Attachment 384100
I would make a gasket that fits over the transfercase studs the transfer that to say a 3/8 or half inch thick plate, drill the holes in it and use that as a drill guide to drill a new set of holes, drill a center hole in the plate that fits the output shaft of the transfercase nice and snug to center the plate. Seems to me that would work pretty well. Drill all the holes on a decent drill press. Needs to be pretty accurate, or have a machine shop make you one
Tinkertoy built thread
http://www.jeepforum.com/forum/f22/lil-bit-tinkering-aka-tinker-toc-1194198/
aw12345 is offline   Reply With Quote
Unread 04-21-2012, 12:32 AM   #695
tride000
What rims are those? I luv them!!
tride000 is offline   Reply With Quote
Unread 04-21-2012, 06:49 AM   #696
the_art_of_desi
So how much body lift are you getting with those new mounts?
So, they are stronger, mounted higher and give you a body lift?
1997 TJ SE - Emeral Green Pearl
2.5L : AX-5 : NP231, D30HP : D44 : 4:88 : Front Aussie
2.5" OME lift, OME LT shocks, 2" BL, Currie Control Arms, Currie HD Steering, Currie Trackbars, Warn M8000
Custom Front and Rear Bumpers, Custom Rock Sliders, OBA
33" x 12.5" x 15" Goodyear MTRs, Black Steelies
the_art_of_desi is offline   Reply With Quote
Unread 04-21-2012, 06:57 AM   #697
aw12345
Those six mounts mount 1" higher, so you maintain a 1" body lift, but you use the stock pucks. The main purpose is to raise the mounts so you don't destroy them as easy on rocks
Unread 04-21-2012, 08:26 AM   #698
Hendrix
TJ Truck?
Hendrix's Avatar
Yeah, they lift the main body up an inch also getting the body mounts away from things on the trail. The mounts are stamped out of 1/4 inch also. On a standard TJ you still need the body pucks for the rest of the tub. 1.25 lift pucks work great with the Genright body mounts , I will be using a Savvy body puck under the grill shell, and custom mounts in the rear of the frame on DD.
Going out to finish the welding on the mounts now. Then measure for the rear frame and leaf spring mounts.
Unread 04-21-2012, 08:36 AM   #699
G Beasley
Sawzall Surgeon
G Beasley's Avatar
Next thing up... I am looking for a AEV brute top. I know someone out there has one, or knows someone that wants to sell one. I really to not want to buy a new one. But, I will if I have to. This is one of those things on the Bling-bling list. I am pretty set on the AEV top.
With the skills you have I am surprised you arent going to chop up a TJ or Cj hardtop ? If you get one thats damaged they are cheap and its not a bad material to work with . With your attention to detail I think you would make something nicer than you could buy .
Ball joints are teh debil !
Just another LJ build
June 2013 Moab Trip
Wrangler tub trailer build
G Beasley is online now   Reply With Quote
Unread 04-21-2012, 08:45 AM   #700
Hendrix
TJ Truck?
Hendrix's Avatar
That was the original plan. But the idea faded quick. That may still happen if i find a hard top cheap. I have a "want add " posted in the classifieds.
Unread 04-21-2012, 11:00 AM   #701
Hendrix
TJ Truck?
Hendrix's Avatar
I got a little more done this morning than expected. I did not get to pick up the jk30 today, guy backed out on the truck I was borrowing, and Enterprise did not have one available. Looks like May 5 th is when I can go pick it up.
Anyway, I finished welding in the genright body mounts, then cleaned up the other Fender. It was going so smooth I decided to trim the fronts of the Rokmen sliders to fit and get those ready to mount to the tub.
Passenger side needs some more trimming.
Driver side fits nicely.
Unread 04-21-2012, 12:38 PM   #702
Sgt.Fuzz
That is a nice fit. Good call on going with the tubeless sliders.
[COLOR="Blue"]My build: [url]http://www.jeepforum.com/forum/f22/fuzzbucket-build-1126577/[/url][/COLOR]
Sgt.Fuzz is offline   Reply With Quote
Unread 04-21-2012, 12:51 PM   #703
Danno6102
Danno6102's Avatar
Yea, I'm not a big fan of the tubes either. Love my tubeless Rokmens! When I called & ordered mine, Jeff said that out of every 100 they sell with tubes, they sell 1 without tubes.
Haven't lurked in a while. Coming along pretty nice man!
IndyORV
4 Wheels to Freedom
My Build
"Evolution through carnage, the Jeep will keep what it needs."
Danno6102 is offline   Reply With Quote
Unread 04-21-2012, 02:11 PM   #704
Hendrix
TJ Truck?
Hendrix's Avatar
Thanks Fuzz, I decided to leave the sliders with tubes on the flop project. And put the new ones on DD. I am thinking about body color for the sliders. That way everything just flows.
Thanks, that's the something Jeff said when I ordered these. Now I just have to have some corner bent for the ends of the sliders to make them follow around the cab corner.
I picked up the stuff to make a cart for the bed and the rear axle. The plan is to have the cart support the bed with the axle resting underneath where it's going to ride. This way I can work on the frame, bed mounts, and axle position all at the same time.
The driver side fender is prepped and ready to go back to work for body work.
Unread 04-21-2012, 04:30 PM   #705
MO2500
Fabramicator
MO2500's Avatar
I got the same story from Jeff when I ordered mine, I guess we 3 are the only ones ordering sliders without tubes
My Jeep Build
Useful tech links:
Stu-Offroad - great technical write-ups!
What's a CV shaft and why do I need one?
Driveline 101
TJ Specs
-Mike-
MO2500 is online now   Reply With Quote
