A TJ truck build named "Dumpster Dive" - Page 292 - JeepForum.com
 1Likes
post #4366 of 5962 Old 12-03-2013, 03:31 PM
TechJeeper
Link to kit please^^^
Edit: found it!
TechJeeper is offline
post #4367 of 5962 Old 12-04-2013, 06:17 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Ok guys, here is the low down.
Jacked up the Jeep from the receiver hitch tonight. Then measured the top of the bed at the cab on both sides. Then rested the Jeep back on its weight. Then jacked the Jeep up and put jack stands in the middle of the Jeep and measured.
Yes, the frame is flexing about a 1/4 at the cab. That means the difference is a lot more from center of the Jeep to the rear bumper.
My professional side says, preload the frame just a little at the section just below the cab in front of the leaf mounts. To do this I need to place 2 floor jacks. One for each rail, some floor anchors or a frame rack to tie the back end at the bumper down. Then weld in the gussets we posted about earlier from just above the leaf eye bolt back about 2" in front of the axle on the frame making a nice triangle.
Am I on the right track?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4368 of 5962 Old 12-04-2013, 08:03 PM
aw12345
If the frame isn't bowed now, you should be able to weld as is. Little bit of preload wouldn't hurt provided you brace it where it flexes. I would, just put some weight in the back after you set the frame on jack stands just behind or under the cab and just let the back dangle in the air. That's probably all the preload it needs. That's how I stiffened my trailer let it bow one way welded my stiffners in and then took it of the stands fixed it up nice and strong with preload
aw12345 is offline
post #4369 of 5962 Old 12-04-2013, 08:24 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
That sounds easy enough. Looks like I have a little project for Saturday.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4370 of 5962 Old 12-05-2013, 12:27 AM
ashland82391
You think your bad ride is from a little frame flex?
ashland82391 is offline
post #4371 of 5962 Old 12-05-2013, 04:41 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
The ride is not all that bad, it's what happens when I hit larger bumps. It's hard to explain I explained it a few pages back and uploaded a few videos. There is a shake or bouncing effect that follows after hitting anything in the road other than smooth asphalt.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4372 of 5962 Old 12-05-2013, 08:55 AM
JJeeper09
Like whiplash. I think I kinda understand what you mean. Thst would be most annoying.
JJeeper09 is offline
post #4373 of 5962 Old 12-05-2013, 09:24 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Yeah, more annoying than anything.
Example: take a coil spring and hold it by one end and hit it on the ground. The vibration is what I am talking about, just on a much larger scale.
Example 2: a tuning fork. One made out of 2x3 box tubing . That's basically what I have. I just need to stop it from vibrating.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4374 of 5962 Old 12-05-2013, 10:30 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
The cab cage tied into the bed cage should help with the vibration just like preloading the frame that you mentioned. X under the bed and cage, I bet it is a whole new jeep pick up after that.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #4375 of 5962 Old 12-05-2013, 07:15 PM
Imped
Imped's Avatar
I definitely like the preload idea. I preloaded my frame before finish welding it and it doesn't budge when I perform the same test as you just did.
OlllllllO
IndyORV
Imped is offline
post #4376 of 5962 Old 12-05-2013, 07:45 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I believe I am on the right track now.
Live by our mistakes. I have learned a ton on both my last two projects.
I finally ordered my Chromo shafts today for the rear today.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4377 of 5962 Old 12-07-2013, 10:47 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I have one frame stiffener cut out and fit.
Think this will work Art? Going to fill in the triangle with plate after the tube is fully welded.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4378 of 5962 Old 12-07-2013, 02:19 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Got the frame stiffeners welded in, I still need to box them in. I took the Jeep for a drive just now, feels tighter and less bounce. I still think it needs the X in the frame. That will be next, when I can get help removing the bed.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4379 of 5962 Old 12-07-2013, 03:23 PM
jforse
I was thinking the same. Get a good solid x brace with those frame stiffeners. Get a little more beef back there.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #4380 of 5962 Old 12-07-2013, 04:38 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Got enough DOM to build the X left over from the cage. I think that will work good. Just found enough plate to fill in the triangle on the stiffeners. Might be able to do that tomorrow.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
