A TJ truck build named "Dumpster Dive" - Page 272 - JeepForum.com
 1Likes
post #4066 of 5962 Old 11-02-2013, 03:34 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
They will raise it for a little while but will sag in the long run and the ride will get stiffer...
afraid of that
Originally Posted by kyle_craig
Add a leaf on each side and see how it rides. More leafs=firmer ride. You should be able to find a sweet spot balancing desired ride height and a fairly comfortable ride.
They are actually bowed past flat now, hopefully a couple leafs will fix that.
Originally Posted by Imped
Drop the front? It may not be worth messing with the rear much more.
Could do that, but as of now the rear only has 1" of up travel.
Originally Posted by AngryTJ
Convert to links and coils...boom done
Thought about COs already, but then I lose my nice long semi quiet exhaust.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4067 of 5962 Old 11-02-2013, 03:45 PM
jforse
Get some OME leafs or put a small block in the rear or longer shackles.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #4068 of 5962 Old 11-02-2013, 04:13 PM
kyle_craig
Adding some leafs should fix that. Mine have a nice arch to them, but bow past flat when flexing upward. While my wheelbase is considerably shorter than yours, it rides similar to how it was on stock coils.
You should be able to add a leaf or two and get some height out of the rear and still maintain a decent ride, unless the leaf hanger/shackle hanger are just too high .
kyle_craig is offline
post #4069 of 5962 Old 11-02-2013, 04:15 PM
IEcrawlerTJ01
Any aftermarket leaf pack is gonna be stiffer than what he has.
I think you need to quit messing with it until you put some weight in the back that your gonna be hauling. Add a stock main leaf and get some fox shocks tuned
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #4070 of 5962 Old 11-02-2013, 04:23 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Spring under so a block will just lower it. Longer shackles not happening. So leafs or changing suspension.
Adding some leafs should fix that. Mine have a nice arch to them, but bow past flat when flexing upward. While my wheelbase is considerably shorter than yours, it rides similar to how it was on stock coils. You should be able to add a leaf or two and get some height out of the rear and still maintain a decent ride, unless the leaf hanger/shackle hanger are just too high .
Yep, everything is high clearance , so adding leafs is the only option.
Originally Posted by IEcrawlerTJ01
Any aftermarket leaf pack is gonna be stiffer than what he has. I think you need to quit messing with it until you put some weight in the back that your gonna be hauling. Add a stock main leaf and get some fox shocks tuned
I only added the stock packs to see a baseline. I plan on adding leafs tomorrow and report back, the only added weight is a spare. And there is one laying in the bed now. Hopefully I can sort it out tomorrow.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4071 of 5962 Old 11-02-2013, 06:29 PM
RockRodHooligan
RockRodHooligan's Avatar
Originally Posted by jforse View Post
Get some OME leafs
OME makes a 2" light duty, or you can look into doing a bastard pack, rather than adding more leafs, you substitute with leafs with more arch, like leafs from a MJ, S10, Dakota, etc.... Something that is spring under.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #4072 of 5962 Old 11-02-2013, 06:42 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Looking into a 2" OME if this added main leaf does not work.
Going to add a eyeless main leaf, and a second leaf to the pack. Then go for a drive.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4073 of 5962 Old 11-02-2013, 07:17 PM
soonermatt
XJ leafs don't have much arch. I believe you should grab some that had more arch and put those below your mains. I'd give you some old YJ mains you could cut in if you were local. You can also add a little shackle. All this is completely customisable.
soonermatt is offline
post #4074 of 5962 Old 11-02-2013, 09:23 PM
aw12345
You can always add more arch to leaves, pretty simple to do with some patience and a shop press
aw12345 is offline
post #4075 of 5962 Old 11-03-2013, 10:02 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Anyone wondering what Dumpster looks like with 33s.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4076 of 5962 Old 11-03-2013, 12:17 PM
twinstickd20
1979 CJ7
Ewwww!
My Build Thread
twinstickd20 is offline
post #4077 of 5962 Old 11-03-2013, 12:20 PM
Jeffro06
Jeffro06's Avatar
Um, no. Nothing shorter than 35's should ever be on Dumpster.
Jeffro06 is offline
post #4078 of 5962 Old 11-03-2013, 12:21 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by twinstickd20
Ewwww!
Exactly what I thought.
It's gonna get torched if I don't get this suspension figured out soon.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4079 of 5962 Old 11-03-2013, 12:25 PM
BamaJeepman21
Put some 42's on there. :rock2:
-Jack
BamaJeepman21 is offline
post #4080 of 5962 Old 11-03-2013, 12:52 PM
jforse
Try some Dakota leafs in there. They have a higher arch.
jforse is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
