A TJ truck build named "Dumpster Dive" - Page 271 - JeepForum.com
 1Likes
post #4051 of 5953 Old 10-31-2013, 06:36 PM
G Beasley
You know, you're one of only four or five people that can even verify the existence of that particular unicorn. As far as the chop is concerned, I have to actually get out and wheel her enough to break her before I can start hacking sheet metal apart and then begging Hendrix to fix her for me.
No need to beg , he accepts multiple forms of payment .
G Beasley is offline
post #4052 of 5953 Old 10-31-2013, 06:51 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
No need to beg.
Yes I do, I can even get the square card reader. And I love the green stuff. :shh:
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4053 of 5953 Old 10-31-2013, 07:00 PM
Jankoid
Jankoid is offline
post #4054 of 5953 Old 10-31-2013, 07:07 PM
Sundowner
I'll see what I can do to earn some of it, then, and when the time is right we'll hack a pretty white Jeep apart and see what comes of it.
Sundowner is offline
post #4055 of 5953 Old 10-31-2013, 07:39 PM
twinstickd20
1979 CJ7
He can also fix a rusty rocker on a Chevy truck real well
My Build Thread
twinstickd20 is offline
post #4056 of 5953 Old 11-01-2013, 08:37 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Third week update
Jeep drives great. Especially after fixing the steering sector shaft and centering the steering wheel. Needs a regear in a bad way , OD sucks with 4:10 and 37s.
Couple little issues that have been there since start up. The gauge cluster, the amp gauge and gas gauge park like normal when shut off but go straight to the half way mark and never move when the key is on. The gas light works, so I figure the cluster is the issue. Any thoughts?
Also, the exhaust rattles I will fix this tomorrow along with the XJ spring packs.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4057 of 5953 Old 11-01-2013, 02:52 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Gave the COs 1.5" preload today. It only raised the jeep about a half inch. So, once I make the bastard packs for the rear maybe she will sit level. Off to the junkyard to look for parts.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4058 of 5953 Old 11-01-2013, 03:07 PM
gspup
I saw the drawings for the greta chop in the girly things bag ?
The girly things bag made it all the way over to this thread
gspup is offline
post #4059 of 5953 Old 11-01-2013, 04:22 PM
jforse
I have a gauge cluster you can borrow to troubleshoot.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #4060 of 5953 Old 11-02-2013, 12:25 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I will let you know. Thanks
New leaf springs have been acquired
2001 XJ rust free springs good bushings.
I have also been collecting AW4 harness parts. If you are looking to do the swap I have the plugs and TCM for 2 swaps.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4061 of 5953 Old 11-02-2013, 02:55 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
So new 2001XJ leafs are in, desired ride quality improved, but ride height is less than desirable. Do I just start adding leafs to get height. Or us that a waste of time?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #4062 of 5953 Old 11-02-2013, 02:58 PM
ashland82391
They will raise it for a little while but will sag in the long run and the ride will get stiffer...
ashland82391 is offline
post #4063 of 5953 Old 11-02-2013, 03:00 PM
kyle_craig
Add a leaf on each side and see how it rides. More leafs=firmer ride. You should be able to find a sweet spot balancing desired ride height and a fairly comfortable ride.
kyle_craig is offline
post #4064 of 5953 Old 11-02-2013, 03:08 PM
Imped
Imped's Avatar
Drop the front? It may not be worth messing with the rear much more.
OlllllllO
IndyORV
Imped is offline
post #4065 of 5953 Old 11-02-2013, 03:13 PM
AngryTJ
Convert to links and coils...boom done
AngryTJ is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
