A TJ truck build named "Dumpster Dive" - Page 261 - JeepForum.com
 1Likes
post #3901 of 5962 Old 10-23-2013, 09:30 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by JJeeper09
I feel your pain. My light rear is too light for my bilstiens 255/70. So I am going with a lighter valving. Try adding a bunch of weight to the rear and just see if it softens it up, then you know what you should do as far as adjustments. The front could be too soft, but the rear seems to be set for a heavier body on the back. Which gives you the kick. Any chance you know the valving?
Yeah, added the weight last week. Got a little better. The shocks are factory set at 40/60
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3902 of 5962 Old 10-23-2013, 10:04 AM
aw12345
Originally Posted by Hendrix View Post
True, but for now I NEED to get it close. It's killing me as it is. This is my ONLY transportation at the moment.
Buy some cheap shocks for the rear, Like Rancho's or something and chuck some weight in the rear and see where that takes you for the time being
aw12345 is offline
post #3903 of 5962 Old 10-23-2013, 10:10 AM
jforse
John I still have the rs9000 that came off the Flop. I can send two of them to you if you want to try.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #3904 of 5962 Old 10-23-2013, 10:15 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Got a set of skyjacker shocks I am going to try for now. If they work ok, I can use them when my shocks are at Alltech.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3905 of 5962 Old 10-23-2013, 10:16 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks, but I got it covered see above.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3906 of 5962 Old 10-23-2013, 11:11 AM
aw12345
Before you send the shocks out and after you have a final weight of the truck have the whole Jeep, then the front and lastly just the rear weight at a truckstop and give those numbers to Wayne, then let him do his thing with the shocks and see if he can recommend some springs for your coilovers up front.
aw12345 is offline
post #3907 of 5962 Old 10-23-2013, 11:24 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Right on Art.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3908 of 5962 Old 10-23-2013, 12:58 PM
aw12345
Actually the r9000's can be dialed, they might make a good stop gap measure for the time being
aw12345 is offline
post #3909 of 5962 Old 10-23-2013, 07:06 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Back on jackstands. I decided to jump right in tonight.
I started by setting her back on jackstands then removing the wheels and tires. Then next up the leafs. There out and ready to pull the second to main stock leaf.
I have the inner fenders trimmed to fit, I will also be bonding and welding them in this weekend.
Tomorrow night: reinstall leafs,shocks and shortend rear DS.
Work for the weekend:
Finish inner fenders, finish cage, fix gear selector, trim center console to fit, wire speakers, install top latches on top behind seats, install tailgate cables.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3910 of 5962 Old 10-23-2013, 07:56 PM
joeyk803c
You going to leave the bed fenders like that (minus paint)? They just look too boring like that, imo.
joeyk803c is offline
post #3911 of 5962 Old 10-23-2013, 08:00 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Recessed tool boxes and flush tie downs later on. Once the cage is in there and the spare mount, there will be storage under the spare also.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3912 of 5962 Old 10-23-2013, 08:00 PM
MO2500
What would make them look "less boring?" I think they look good like that, simple and clean.
Edit: the toolbox idea would be cool and unique.
Instagram: @omsmike
MO2500 is offline
post #3913 of 5962 Old 10-23-2013, 08:03 PM
joeyk803c
Awesome. I was thinking some recessed storage would be awesome.
post #3914 of 5962 Old 10-23-2013, 08:21 PM
G Beasley
The inners look good , are you going the ammo can route for sunken storage ?
G Beasley is offline
post #3915 of 5962 Old 10-23-2013, 08:47 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
No, not enough room. I will just have the shop I used brake me some boxes and put lids on them, then weld them into the tops of the fenders. Not dry storage but added storage.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
