A TJ truck build named "Dumpster Dive" - Page 235 - JeepForum.com
 1Likes
post #3511 of 5962 Old 09-19-2013, 10:39 AM
clintrivera
I didn't see turbocharged V8 swap on your list. What's up with that?
clintrivera is offline
post #3512 of 5962 Old 09-19-2013, 11:33 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I thought I had that on there.
The 4.0 will do fine. It's holding 40 psi of oil pressure at idle.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3513 of 5962 Old 09-19-2013, 11:47 AM
ksilovich
Wheres the "Mount sexy a$$ badge on the tailgate"
Jeffery 2.0 : Cummins 4bt, 40's, ORI's, D60, 14B, lots of AL
ksilovich is offline
post #3514 of 5962 Old 09-19-2013, 11:50 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Can't figure out where it put it. Thinking about under the passenger tail light.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3515 of 5962 Old 09-19-2013, 01:11 PM
ksilovich
If you want another one or two. Or in a different size let me know I will cut you out some more this weekend.
post #3516 of 5962 Old 09-19-2013, 01:27 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I will send you my amp mount heat sinks. I have them figured out. You could probably do 2 more tags. I might put one on each side if I take my zombie response team stickers off later on.
Do you still have the tool for harness tabs?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3517 of 5962 Old 09-19-2013, 02:35 PM
ksilovich
I do. Now that I have my table it should be easier to make some of them. I can give it a try if you need some.
Send me the list of what you will need and ill get it done as soon as I can. Ill be home this weekend. And then next weekend I'm going to Indy to have brown work on my s*** for once lol
post #3518 of 5962 Old 09-20-2013, 06:01 AM
IceKnight
What an awesome build, thing looks killer nice job.
IceKnight is offline
post #3519 of 5962 Old 09-22-2013, 10:33 AM
84jeepcj7rock
I haven't heard much this weekend. Hope that means your getting it finished. The trailer looks great as well but don't get too distracted. Wish I had your skills.
84jeepcj7rock is offline
post #3520 of 5962 Old 09-22-2013, 12:20 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks.
Worked all day yesterday on beasleys trailer. Then tinkered with the Jeep for about an hour yesterday night. Got up this morning and reset the distributor to factory spec as the write up said to that I posted earlier last week. The Jeep runs AWESOME now!!
Changing the valve cover gasket this afternoon, then knocking a few more things off the list later on.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3521 of 5962 Old 09-22-2013, 08:39 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Things left to do on Jeep to drive full time:
Remove front exhaust pipe. Add heat wrap
Build inner fenders front and rear. Rokmen front and custom rear
Build cage and harness mounts
Lengthen front drive shaft 2.5 inches
Add diff fluid, fill transfer case. DONE
Time distributor DONE
valve cover gasket DONE
Drill out knuckle for insert
Swap out PCM DONE
Install rear DS
Replace speed sensor
Fix gas gauge
Just need to finish these sometime soon:
Install skid plate
Build front skid
Wire and plumb trans cooler
Install seat heaters and remote start
Install interior led lighting
Build spare mount flange
Build rear cage and resi mounts
Install fire extinguisher mounts
Paint cage gunmetal gray
Repaint bed assembly
Sand and buff paint work
Detail inside out
Touch up chips from assembly
Undercoat inner fenders and rear wheel wells
Get dent pushed out of hood from garage door.
Fill with gas and enjoy.
Edited list:
So today I got to move forward for a little, then take a few steps back. The radiator decided to spring a leak, and the PCM is giving me a Neutral safety switch code. (P0705)
Other than that I spent most of the day cleaning the garage. I just could not work in the mess any longer. So, with a clean garage and a helluva list. I have my work cut out this week.
Should have a video of it on the road later this week, I am itching to drive her down the road.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3522 of 5962 Old 09-22-2013, 09:08 PM
ksilovich
You asked me about my double shear tabs.
I decided to cut some out on the table and see how they turn out.
(100x easier then cutting them by hand like I did for my jeep - before the table)
Do you need a set of 10 still?
post #3523 of 5962 Old 09-22-2013, 09:18 PM
G Beasley
That is great news ... the list is getting smaller each day minus the radiator .
G Beasley is offline
post #3524 of 5962 Old 09-23-2013, 05:27 AM
RockRodHooligan
RockRodHooligan's Avatar
Don't know if you can get it any cheeper than I can, but mine cost me about $200 as an employee. You may want to try this first....
http://jeep-xj.info/HowtoNSSrebuild.htm
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #3525 of 5962 Old 09-23-2013, 07:44 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Yes, 10 will do me.
Think I can fix it.
Thanks, going to try adjusting it first.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
