A TJ truck build named "Dumpster Dive" - Page 222 - JeepForum.com
 1Likes
post #3316 of 5953 Old 09-09-2013, 02:04 PM
Imped
Imped's Avatar
I hope to get a phone call when you're test driving this thing.....
Looking good buddy.
OlllllllO
IndyORV
Imped is offline
post #3317 of 5953 Old 09-09-2013, 02:56 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Time for a front page update? What is the storage box you had mocked up for behind the seats and did it make it into the final truck? Do you have anymore information on it? Thanks.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #3318 of 5953 Old 09-09-2013, 03:32 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Oh yeah, it's one of my favorite mods. It's on the first page somewhere. I bed lined it to blend in with the cab.
Sent by telegram.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3319 of 5953 Old 09-09-2013, 07:49 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
So I have a tiny issue. I installed the front DS tonight. It's about 2" to short, meaning I don't feel safe with only 2" of engagement in the splines. Anyone know how long of front shaft I can safely run. I need a 44" front shaft.
Thanks I will hang up and listen now.
unno:
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3320 of 5953 Old 09-09-2013, 07:53 PM
jforse
unno:
You should have more spline engagement than that. Didn't you just have that shaft made? Or is that the one setup for the Flop?
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #3321 of 5953 Old 09-09-2013, 08:17 PM
aw12345
With all the work you did extending a driveshaft 2" should be cake, cut right next to the yoke weld add 2" of tube tack, check to see if it's true, then weld in 4 spots 180 degrees across. Shouldn't take you very long. Laying it in some angle iron while tacking help keep the tubes lined up.
If you get the thing retubed have them use 0.120" wall tubing
aw12345 is offline
post #3322 of 5953 Old 09-09-2013, 08:27 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
It's a custom front shaft with 2" 120 wall I had it built for flop and as I was building thought I had measured correctly for it to fit. 450.00 for this and now i need to lengthen. I was mainly asking if its safe to go out to 44" ?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3323 of 5953 Old 09-09-2013, 08:46 PM
aw12345
Sure I Have a pretty long driveshaft in the front, actually helps driveline angles and yoke clearance. With a long enough shaft you could possibly loose the cv joint to boot
aw12345 is offline
post #3324 of 5953 Old 09-09-2013, 08:49 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
That's what I figured, just wanted an honest opinion. thanks Art.
It's actually pretty flat as well as my rear shaft.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3325 of 5953 Old 09-09-2013, 08:51 PM
aw12345
You'r welcome Johnny, we all wanna see this here fine Jeep leave the garage
aw12345 is offline
post #3326 of 5953 Old 09-09-2013, 09:17 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Me to, I am going to ease it out with the front shaft as it sits. Then turn it around and take the shaft down to Dave's d shaft to get him to retube it. My rear yoke will be here Thursday. Then I can take the Jeep for a spin.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3327 of 5953 Old 09-09-2013, 09:52 PM
aw12345
One or two more days and a few bucks doesn't make much difference anymore. So ya have the shaft retubed, fix anything else thagtg needs fixing and enjoy the heck out of your Jeep, it's truly one of a kind
aw12345 is offline
post #3328 of 5953 Old 09-10-2013, 05:10 AM
LilViper95
LilViper95's Avatar
My front drive shaft is 43.5" at ride height after the aw4 swap I had to have it re-tubes.
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
post #3329 of 5953 Old 09-10-2013, 05:55 AM
Imped
Imped's Avatar
The lack of a front drive shaft won't keep you off the road.
OlllllllO
IndyORV
Imped is offline
post #3330 of 5953 Old 09-10-2013, 06:00 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Cool, no vibration issues?
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
