A TJ truck build named "Dumpster Dive" - Page 217 - JeepForum.com
 1Likes
post #3241 of 5962 Old 09-04-2013, 06:55 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
After more testing for leaks on the exhaust another issue has risen. The Jeep will purrr like a kitten, one tap of the throttle and she back fires then returns to a perfect idle. I am thinking 3 things.
1. CPS faulty since I have a code for it.
2. Bad ground likely
3. Dirty IAC valve.
Ideas?
Going to add all the fluids and get her up to a good operating temp tomorrow night.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3242 of 5962 Old 09-04-2013, 08:23 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Here is a quick vid of the Jeep running and the problem i have now.
Acting up
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3243 of 5962 Old 09-04-2013, 08:25 PM
Jeffro06
Jeffro06's Avatar
Acting up
No clue what that is.....good luck man.
Jeffro06 is offline
post #3244 of 5962 Old 09-04-2013, 08:32 PM
twinstickd20
1979 CJ7
What codes is it throwing?
My Build Thread
twinstickd20 is offline
post #3245 of 5962 Old 09-04-2013, 08:39 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
um a CPS and a battery temp.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3246 of 5962 Old 09-04-2013, 09:09 PM
twinstickd20
1979 CJ7
Cps could make it do that
My Build Thread
post #3247 of 5962 Old 09-04-2013, 09:37 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
That's what I am thinking, it reads the signal fine at idle, then loses it at anything above it.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3248 of 5962 Old 09-04-2013, 09:40 PM
twinstickd20
1979 CJ7
Do you have an ohm meter? You can try testing it but it may pass the test but still be bad
My Build Thread
post #3249 of 5962 Old 09-05-2013, 06:31 AM
H3lzsn1p3r
replace cps it should cure the problem don't bother testing it its a cheap part
a ground wont do that and iac would only make it stall when you let off the gas
Hehehe...SoccerLockers. That's what I'm calling Obvious Moms in Rubicons from now on.
91 yj renegade
98 ram 1500
H3lzsn1p3r is offline
post #3250 of 5962 Old 09-05-2013, 08:00 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks, that's why I posted the CPS first.
I figure my cps is covered with tiny metal shavings since there is not a cover, and my motor was exposed through most of the fabrication process.
After some research, the cps also tends to be the culprit in the gauges not working properly in some cases also. How they are related i do not know. But, most of the Cherokee guys said when they replaced the cps there gauges worked correctly also.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3251 of 5962 Old 09-05-2013, 11:50 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Ok so the tera flex yoke conversion is on its way.
Stopping at pick a part on the way home to grab some bolts for the u bolts and out put flange on the t case.
Jeff (NashvilleTJ) stopped by today with my new brake booster. Thanks Again
Hopefully I can get her running tonight with water in her.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3252 of 5962 Old 09-05-2013, 11:53 AM
The_Eng
Hendrix, work has been crazy this week and we just finished moving. I should have measurements on that driveshaft this afternoon
2002 WJ Limited - Stock except for some 245/65R17's
1998 TJ Sport - 285/70R17 on JK Moabs
Colorado Jeep Club Member #272
The_Eng is offline
post #3253 of 5962 Old 09-05-2013, 03:30 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
No problem man.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3254 of 5962 Old 09-05-2013, 05:39 PM
WildBlue
Just as an addition to this, I just replaced my engine in January, I also had CPS/distributor related issues after all was said and done. Come to find out, after taking it to two mechanics and a Jeep dealership, the timing was off by 18 degrees and the check engine light wouldn't go off. It was a Crank Posistion Sensor and Cam Position Sensor problem. The distributor was off by ONE tooth. It idled like a champ though. Hearing that backfire makes me think the timing is off just a touch. Mine did that was well...takes a lot of little fine tuning to get it just right. We farted with mine for two days before taking it to a professional. And in the end a Jeep dealership was the only one who could fix it. Apparently the timing is set different than just TDC and 0 degrees, because that's how we set mine and it was off. We even changed both sensors and nothing changed. So if you change sensors and it still does it, I would look at the timing.
HTH,
Trey
WildBlue is offline
post #3255 of 5962 Old 09-05-2013, 05:53 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
HTH,
Trey
Thanks man, I read the distributor needs to be set just in front of the number 1 post, because of the spiral gear . When the distributor is set in position it will turn the shaft just a little to throw off the timing if not position perfectly. That's why they have a pin that is factory set and removed after the distributor is installed. I will look into it before I buy the $80 CPS.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
