A TJ truck build named "Dumpster Dive" - Page 216 - JeepForum.com
 1Likes
post #3226 of 5953 Old 09-03-2013, 07:46 AM
doublins
Originally Posted by Hendrix View Post
Yeah, the End of this Build and the beginning of an Adventure....
I hope so, it was a random one I had laying around.
Well I got the down pipe all mocked up tonight. I tacked it together and pulled it off to weld up tomorrow with my smaller welder at work. I need to locate a 2.5-3" exhaust pipe that I can make a collector for the "Y" pipe. Then is smooth sailing from there with the exhaust.
I just bought a stainless collector off the net to make mine, worked fine and was quick and dirty. (As if it isn't obvious my y-pipe was for a v8, not an I-6, but you get the idea.) Do you do stainless or mild steel for your exhaust?
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #3227 of 5953 Old 09-03-2013, 08:00 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Can I meet you somewhere downtown tomorrow? I will just come over to you.
I'll be downtown this afternoon. I'll give you a call and we can pick a place to meet.
NashvilleTJ is offline
post #3228 of 5953 Old 09-03-2013, 12:55 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Sent you my number in a pm, didn't know if you had my new one.
Got my down pipe welded up this morning.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3229 of 5953 Old 09-03-2013, 05:30 PM
mike_breaker_5
is that a jegs or summit stamped "Y"? i used the same one on my 5.2 after i was defeated on trying to stuff true duals under the yj. easy to work with and are available with sensor bungs.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #3230 of 5953 Old 09-03-2013, 06:36 PM
doublins
I used a magnaflow #10758 2x2.25" --> 1x2.5" stainless Y
doublins is offline
post #3231 of 5953 Old 09-03-2013, 07:16 PM
G Beasley
That is awesome to hear ... so close now to driving it that it must be motivating the heck out of you .
G Beasley is offline
post #3232 of 5953 Old 09-03-2013, 09:33 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Sorry I missed you today Jeff. I got off early today and rushed home to finish the exhaust. I will call you tomorrow.
You do not even know.
So I have a grand total of 12 dollars in my complete exhaust system. I made the entire thing out of scrap exhaust pipes from work.
Starting with a custom down pipe welded together to turn forward into a $3.00 collector I made out of a 3" to 2.5" reducer, then a custom 90 degree through the upper and lower front control arm mounts, into a V6 Camry cat and resonator, finally passing through a salvaged flowmaster off of the Flop Project and finishing with a tail pipe custom cut from a FJ cruiser with stainless tip. two O2 bungs from ebay for $2.75 and a can of high temp paint for $6.25.
Sounds like a BOSS.
I will post a better video with better sound later on. My fan was causing a lot of back ground noise.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3233 of 5953 Old 09-03-2013, 09:47 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Click here
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3234 of 5953 Old 09-03-2013, 09:54 PM
michigan37
2010 JK Wrangler
Sounds fricking smooth! Can't wait to see a test drive video.
michigan37 is offline
post #3235 of 5953 Old 09-03-2013, 09:56 PM
kyle_craig
Sounds badass. That's 12 bucks well spent!
kyle_craig is offline
post #3236 of 5953 Old 09-04-2013, 09:03 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks, there will be a first drive video soon.
I think so, I will post up some pictures when I remove it to paint.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3237 of 5953 Old 09-04-2013, 09:29 AM
AngryTJ
Sounds great
AngryTJ is offline
post #3238 of 5953 Old 09-04-2013, 10:50 AM
Imped
Imped's Avatar
I'm liking that exhaust man.
OlllllllO
IndyORV
Imped is offline
post #3239 of 5953 Old 09-04-2013, 11:29 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Well guys. IT RUNS.
I have a video of start up and it running. But, my laptop does not support windows movie maker. I will see if I can update something and get a video posted sometime today.
List of final prep before driving.
Finish front section of exhaust. Done
Add fluids
Shorten rear DS. Done
Install JK yoke conversion
Replace brake booster
Diagnose NO oil pressure at the gauge. New sending unit. Done
Build seat mounts. Found some trooper seat sliders at pick a part that will work great.
Edited list.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3240 of 5953 Old 09-04-2013, 01:45 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Cut down the drive shaft for the rear today. Just need the Tera flex yoke to hook it together.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 11:49 AM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-10-2011 12:18 AM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 07:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 11:11 AM
