A TJ truck build named "Dumpster Dive" - Page 213 - JeepForum.com
 1Likes
post #3181 of 5962 Old 08-30-2013, 05:35 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by The_Eng View Post
Are you still looking for a driveshaft for the rear? I have a cv shaft I ihad made for my xj a few years ago just taking up space now. I can get measurements for you if you are interested. Dave's Driveshaft in Nashville made it for me before I moved out here to CO
If its a Dave's its a good shaft. Shoot me a price and some specs.
If somehow you figure out how to produce one of these in less then the 23 months its taken you sign me up for one. Normally not a fan of the TJ truck idea but this one looks so so good
Keep in mind I built a whole Jeep. I could do a truck conversion in a couple months tops with a running/driving Jeep
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3182 of 5962 Old 08-30-2013, 06:59 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Alright guys its a three day Dumpster Marathon.
I will hear this thing run by Monday maybe even drive it down the driveway and back.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3183 of 5962 Old 08-30-2013, 07:36 PM
Jeffro06
Jeffro06's Avatar
Jeffro06 is offline
post #3184 of 5962 Old 08-30-2013, 08:01 PM
LilViper95
LilViper95's Avatar
Nice! I'm excited for you!
04 Ram 2500 5.9L 24v HO Cummins
LilViper95 is offline
post #3185 of 5962 Old 08-30-2013, 09:15 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Check gears and seal up diff
Build spacers for AC compressor DONE
Install belt and pulley DONE
Finish steering shaft. DONE
Remove down pipe and build front exhaust pipe
Finish hydro assist / ps cooler
Install spark plugs and cap, wires. DONE
Install trans cooler
Build inner fenders front and rear
Build seat mounts and cage
Install all the fender bolts and hood latches. DONE
Install transfer case and cable shifter. DONE
Install front driveshaft
Install tailgate and tag bracket. DONE
Wire up amps for speakers
Build speaker enclosures
Add antifreeze, diff fluid, brake fluid, fill transfer case
Bleed brakes
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3186 of 5962 Old 08-30-2013, 10:25 PM
Jeffro06
Jeffro06's Avatar
Bleed brakes
The list is getting shorter!
Jeffro06 is offline
post #3187 of 5962 Old 08-30-2013, 11:48 PM
The_Eng
I'll get measurements on it tomorrow.
2002 WJ Limited - Stock except for some 245/65R17's
1998 TJ Sport - 285/70R17 on JK Moabs
Colorado Jeep Club Member #272
The_Eng is offline
post #3188 of 5962 Old 08-31-2013, 06:38 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Check gears and seal up diff. In the AM
Finish hydro assist / ps cooler. DONE
Install trans cooler. NEED fittings from Blaine to finish
Install front driveshaft.
Bleed brakes Gravity bleeding now, will install speed bleeders in the AM to finish.
Looks really close, I may add gas to the tank in the morning and fire her up. Video will be posted.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3189 of 5962 Old 08-31-2013, 06:54 PM
AngryTJ
Ill keep that in mind.
Can't wait to see her run
AngryTJ is offline
post #3190 of 5962 Old 08-31-2013, 07:09 PM
Joshwrench
Man this is an awesome build. The thing is lookin sharp
Joshwrench is offline
post #3191 of 5962 Old 08-31-2013, 08:54 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3192 of 5962 Old 09-01-2013, 02:52 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Soooo, I am now trying to get the jeep to fire on the proper cyclider at the right time.
All the google images look the same, then I find a picture that's a prong off on the distributor cap.
Any suggestions?
Edit: I think I have it 180 degree out? Ideas?
It cranks, fires, puffs, blows fire out the header, and really tries to start. But just seems to be out of time.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3193 of 5962 Old 09-01-2013, 03:54 PM
aw12345
turn engine over slowly with the number 1 sparkplug out and hold your finger of the hole so you can feel when it's on it compression stroke.
Then line up timing mark see where the rotor points that's were the number 1 wire goes then check rotor rotation and use proper firing order 153624
Also did you compare timing notches on the stock flywheel and the flexplate / ring gear you used for the aw4?
aw12345 is offline
post #3194 of 5962 Old 09-01-2013, 04:00 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Check gears and seal up diff. DONE confirmed they are 4:10
Remove down pipe and build front exhaust pipe. In the AM.
Install trans cooler. Waiting on fittings From Blaine
Build inner fenders front and rear. Waiting on metal shop
Build seat mounts and cage.
Install front driveshaft NEED U BOLTS
Add antifreeze, diff fluid, fill transfer case. NEED FLUIDS
Bleed brakes DONE
Updated list.
I have a good pedal, but I have a leak at the booster when my wife compresses the pedal. Once I figure out the firing/timing issue she will be drivable with driveshafts installed.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3195 of 5962 Old 09-01-2013, 04:06 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Got the number 1 up, on TDC. (0) on the timing mark. Problem is I think it's 180 out, soon as I get back out to the garage I am going to check for compression stroke and see where the rotor points on the distributor.
As far as the AW4 it's all the parts from a 2000 model.
Thanks Art.
Found this:
Pull distributor:
Rotate the crank till the timing mark on the harmonic balancer is aligned to the "0" on the timing cover scale on compression stroke.
Take a long reg tip screwdriver and insert it into where the distributor sits, turn the oil pump shaft till the flat edge points to the 11 o'clock position.
Drop the dist in and tighten down.
Install rotor button, it should be pointing to #1 cylinder on cap. Install cap and double check the firing order. 1-5-3-6-2-4 clockwise rotation.
Make sure the hole in the cam sensor lines up with the hole in the distributor
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
