A TJ truck build named "Dumpster Dive" - Page 210 - JeepForum.com
 1Likes
post #3136 of 5962 Old 08-26-2013, 10:06 AM
tyvanwie
Originally Posted by mcannon111
There is actually a good bit of rocks and wheeling to do in central Florida near Ocala. My uncle lives there and wheels there all the time. If and when you move down there I can give you his contact info if you want to do some more with the jeep than cruising Daytona beach and the local malls
Ocala is really nice. My dad and I used to ride dirt bikes there when we lived in Orlando.
tyvanwie is offline
post #3137 of 5962 Old 08-26-2013, 10:13 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by xtreme4li
This tj is beautiful!!! How many hrs do you have in fab work now? Or did you stop keeping track? If I remember correctly you got this tj for 400 bucks? What a project it has become.. Great work
$200.00 actually then sold off some parts to come in even or positive.
I figure a safe bet would be an average of 10 hrs a week for 14 months is a good estimate.
Project has taken 21 months so far.
Thanks, the next week or so is going to be pretty emotional. It finally hit me Saturday how much of a project this is. I was looking at the almost complete Jeep and noticing there is only a handful of things I did not build myself or modify to fit my needs.
Sent from my iPod touch from Top of the World!
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3138 of 5962 Old 08-26-2013, 01:58 PM
Jeffro06
Jeffro06's Avatar
Originally Posted by Hendrix View Post
We lived in Ft Myers for 5 years, so she wants to go back there. If your not familiar its SW about 20 miles north of Naples.
Here's the first photo I found when i Googled Ft.Myers:
How bad can that be?
Jeffro06 is offline
post #3139 of 5962 Old 08-26-2013, 02:08 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
That's probably not ft Myers beach. That's probably the island of sanibel. But really who cares right, lots of sunshine for topless Jeep days.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3140 of 5962 Old 08-26-2013, 02:16 PM
Imped
Imped's Avatar
Fort Myers.
AKA Spring Break for 87% of the midwest.
OlllllllO
IndyORV
Imped is offline
post #3141 of 5962 Old 08-26-2013, 04:24 PM
rjbruzan
Naples is swamp buggy heaven.
Ron
Of all the things Ive lost
The one I miss most is my mind
Its like a fart in a windstorm
It smells good but thats about it
Registered Six Offender
Home of the Buzzin Half Dozen
rjbruzan is offline
post #3142 of 5962 Old 08-26-2013, 08:27 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Things left to do on Jeep:
Check gears and seal up diff
Build spacers for AC compressor DONE
Install belt and pulley DONE
Finish steering shaft DONE
Remove down pipe and build front exhaust pipe
Finish hydro assist / ps cooler
Install spark plugs and cap, wires DONE
Install trans cooler
Build inner fenders front and rear
Build seat mounts and cage
Install all the fender bolts and hood latches DONE
Install transfer case and cable shifter
Install front driveshaft
Install tailgate and tag bracket
Wire up amps for speakers
Build speaker enclosures
Add antifreeze, diff fluid, brake fluid, fill transfer case
Bleed brakes
That's all guys, then she's ready to go.
Updated list
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3143 of 5962 Old 08-26-2013, 08:44 PM
jforse
Sign me up.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #3144 of 5962 Old 08-26-2013, 08:54 PM
aw12345
Originally Posted by jforse View Post
Sign me up.
Florida in winter and spring is the best, summer not so.
Used to spend time in Hollywood FL, 5 mins from the beach, good times during spring break
aw12345 is offline
post #3145 of 5962 Old 08-26-2013, 09:08 PM
jeepwrangler97
I'm in fl...went to school in St. Pete. .. could go topless/doorless September-March...less rain & heat those months & I had a garage to park in.
...downside. ..Ft. Myers is too hot imo, I don't know how people deal with the heat any farther south than St. Pete
Sent by a messenger bird
jeepwrangler97 is offline
post #3146 of 5962 Old 08-27-2013, 07:44 AM
Jeffro06
Jeffro06's Avatar
You're making some good progress on that list.....I think you can do the 14th.
Jeffro06 is offline
post #3147 of 5962 Old 08-27-2013, 08:42 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I finally figured out which accessory brackets are on my 4.0. They are grand cherokee 4.0 brackets, so I picked up a GC AC compressor Saturday and lines from pick a part. I will take the TJ lines I got from Jforse down with the ones off the GC and have custom lines built when its time to get some cold AC blowing. I had the space the AC compressor higher to clear the fitting on the with the CO hoops. Probably have the hose shop put a high side fitting on the hose and eliminate the fill point on the side of the compressor that's giving me the trouble.
Should be able to knock out a few more little items on the list tonight.
Probably going to look into putting the battery back under the hood. I did not factor in high water crossings when I decided on relocating the battery to the underside of the Jeep. As soon as I here from Rokmen on a battery tray I will figure that out.
When my t case gets here I can set it in place and order a rear DS.
Anyone used a teraflex yoke conversion on the jk44s?
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3148 of 5962 Old 08-27-2013, 11:26 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
5 years down there was not so bad. My wife is already looking at homes on Remax. She has found a few with shops already built on 2.5 acre lots and one on 6 acre lot.
It will come down to if I feel like the truck will make the 300+ mile trip.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #3149 of 5962 Old 08-27-2013, 12:35 PM
Jeffro06
Jeffro06's Avatar
I hear ya, the 6 hour round trip is the worst part about going to the Badlands. I usually have to talk myself into it.
Jeffro06 is offline
post #3150 of 5962 Old 08-27-2013, 02:46 PM
bobthetj03
Child's play! I did an 8hr round trip to Hollister last weekend. 460miles, 16hrs in the seat of the jeep! Good times!
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
