A TJ truck build named "Dumpster Dive" - Page 179 - JeepForum.com
 1Likes
post #2671 of 5953 Old 05-28-2013, 06:13 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by spyder6
that has to be one of the most unique track bar placements ive seen
Same set up I used on Flop, borrowed the idea from Blaine. It works well, but is hard to package on a JK axle with the draglink set up.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2672 of 5953 Old 05-29-2013, 07:02 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Going to finish the sleeves on the front axle tonight, then paint it at work tomorrow sometime. Finish painting the frame and coil over hoops up front this weekend. Then it's reassembly time for the front.
New calipers, rotors, JK factory brake hoses, synergy ball joints, new master cylinder , all new steel brake lines. I have a BTF diffcover coming for the front and rear to protect the gears, and some Yukon 5:13s.
I would like to have the front assembled and sitting on its own weight by Sunday so I can start tearing down the rear axle for final welding and paint next week.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2673 of 5953 Old 05-30-2013, 08:19 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Worked on the front axle a little tonight. Finally made the decision to cut the tubes, rotate the C for Great castor. The difference in TJ and JK axles is the fact you have to point the pinion down a little to correctly add enough caster to get the thing to drive right.
Cut off the tube about 8" in then rotated it, used the inner sleeve to keep it all straight then tacked back in place.
Aligning the pinion and the Inner C.
Some outer sleeves would have really tightened it all up. But, I have all the bracket already on the 30. If this Jeep ever gets another axle I will do both to it.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2674 of 5953 Old 05-30-2013, 09:40 PM
PurpleZJ
I love your build man. As for the outer sleeve, IIRC they are usually two pieces? I'm sure you could work around the brackets if you really wanted to outer sleeve it
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #2675 of 5953 Old 05-31-2013, 06:28 AM
chocflip201
I loved everything about the build until that… :/
chocflip201 is offline
post #2676 of 5953 Old 05-31-2013, 06:34 AM
Imped
Imped's Avatar
Originally Posted by chocflip201 View Post
I loved everything about the build until thatů :/
Why? Do you understand why it's needed with these axles?
OlllllllO
IndyORV
Imped is offline
post #2677 of 5953 Old 05-31-2013, 07:05 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
See why I was sceptic for sharing. Some people just don't get it.
And don't explain why they don't.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2678 of 5953 Old 05-31-2013, 07:09 AM
Imped
Imped's Avatar
Nah man, I'm glad you did. You obviously know I'll be doing the same thing and in my head, it really was that easy. Glad to see it worked out as we thought it would.
OlllllllO
IndyORV
Imped is offline
post #2679 of 5953 Old 05-31-2013, 07:38 AM
Zjones1994
Honestly why the hate? Hendrix has proven over and over that he knows what he's doing.
Sent from my DROID RAZR HD using JeepForum
1998 Chili Pepper Red Jeep
USN Hull #233
Check out my build!
Zjones1994 is offline
post #2680 of 5953 Old 05-31-2013, 07:42 AM
Bong_Holyeo
Please keep sharing everything, i live for updates from this work of art...
Bong_Holyeo is offline
post #2681 of 5953 Old 05-31-2013, 07:53 AM
Sundowner
I've got an unrelated question referencing those pics you posted a few days ago: where'd you pick up that door hinge hardware? Sorry for the derail...
Sundowner is offline
post #2682 of 5953 Old 05-31-2013, 07:54 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Which door hinges, the black powder coated ones?
Edit: The stainless hardware came from a local bolt and screw vendor. Every exposed bolt on the Jeep has the same hardware now.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2683 of 5953 Old 05-31-2013, 08:11 AM
monsonman
monsonman's Avatar
i didnt realize JK castor was less than TJs. how much did you have to rotate? and do you see there being any issue with shock mounts since they will be pointed a wee bit back now?
'05 LJ Rubicon Build:
'98 TJ- build:
instagram: @vohnsonthemonson
monsonman is offline
post #2684 of 5953 Old 05-31-2013, 08:12 AM
Sundowner
Thank you. I'm trying to get find some stainless stuff that will match the countersunk recess on my hinge plates; hopefully one of the local people in my area will have it. Black/stainless looks nice.
Oh, good work on the axle, too.
post #2685 of 5953 Old 05-31-2013, 08:15 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I dialed the shock mounts in with the caster setting. The only thing that changed is the pinion will face the transfer case better.
Thanks!
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
