A TJ truck build named "Dumpster Dive" - Page 177 - JeepForum.com
 1Likes
post #2641 of 5962 Old 05-24-2013, 12:58 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Great start to a long weekend. I have lots I want to finish this weekend.
Started off with my double shear pitman arm.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2642 of 5962 Old 05-24-2013, 01:25 PM
jrallen
You made that?
jrallen is offline
post #2643 of 5962 Old 05-24-2013, 01:56 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
That is really cool, John.
Build Thread:
Swing Away / Swing Down Tire Carrier:
NashvilleTJ is offline
post #2644 of 5962 Old 05-24-2013, 03:08 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by jrallen
You made that?
Thanks guys, it's not real pretty but it's solid as hell.
It's ready to index tomorrow and burn in the splined slug.
image-922796853.jpg   image-3689528912.jpg   image-3508892251.jpg   image-3610959411.jpg
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2645 of 5962 Old 05-25-2013, 11:32 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Pitman arm works perfect, full range of steering and no binding at all. The front axle is out and finishing the welding today.
Sleeves, new lower CA bracket 10 degree, reinforced the CO mounts, passenger JJ tower, AR tabs and track bar bracket. Then load it on the trailer to take to work for Paint and then regear to 5:13.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2646 of 5962 Old 05-25-2013, 01:25 PM
jforse
I wish i was this close!
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #2647 of 5962 Old 05-25-2013, 01:36 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Stuffed a tire before pulling the axle out. I have some good pictures to post later after I clean them up.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2648 of 5962 Old 05-25-2013, 01:45 PM
tyvanwie
Are you leaving the jeep letters blue, or doing something with them?
Sent from my iForum using JeepPhone
tyvanwie is offline
post #2649 of 5962 Old 05-25-2013, 01:58 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
They will be black like the other side. I just have not stuck the decals on that side yet.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2650 of 5962 Old 05-25-2013, 02:02 PM
tyvanwie
Ah, okay. Didn't realize the other side was black. I was gonna suggest that but ya beat me to it
tyvanwie is offline
post #2651 of 5962 Old 05-25-2013, 02:28 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
what?
NOT A PRETTY PITMAN ARM? ARE YOU ****ING CRAZY??
you are an artistè
My builds:
and
or follow us on
spyder6 is offline
post #2652 of 5962 Old 05-25-2013, 02:30 PM
semistocker
1996 FSJ Cherokee
i dont really like TJs but this build is sick!
semistocker is offline
post #2653 of 5962 Old 05-25-2013, 02:36 PM
tyvanwie
Originally Posted by spyder6
what?
you are an artistè
This.
tyvanwie is offline
post #2654 of 5962 Old 05-25-2013, 03:22 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
No problem.
what?
you are an artistè
Thanks, the pitman arm will look tits once the slug is welded in and a fresh coat of black on it.
Thanks!
This.
:thank you:
Guys I have a little problem. When I flex out the front with the passenger upper arm in it binds, I remove the arm and the front axle movement is so fluid. My fix would be to remove the passenger arm completely and just run a 3 link. My only problem with that is I am using 2" JJs. Should I replace the inner ball with the bigger inserts currie sells or and I just over thinking it?
Btw, the only binding is when the passenger droops out and the driver is all the way at bump. For normal driving and light trail use there would never be an issue.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #2655 of 5962 Old 05-25-2013, 03:28 PM
bobthetj03
What's it hitting? I'm guessing if you let it go, it's just gonna bug the crap out of you.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
