A TJ truck build named "Dumpster Dive" - Page 17 - JeepForum.com
 1Likes
post #241 of 5962 Old 02-01-2012, 02:19 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Here is another. I really need to get back to work. I am taking pictures along the way. So full update on page one later tonight.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #242 of 5962 Old 02-01-2012, 02:39 PM
kyle_craig
This is REALLY moving along nicely. Was the inner box already the right width or what? Looks bomb.
kyle_craig is offline
post #243 of 5962 Old 02-01-2012, 02:46 PM
MO2500
Looks great John It's really coming together well.
Instagram: @omsmike
MO2500 is offline
post #244 of 5962 Old 02-01-2012, 04:20 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Nope, I had to cut the top down to get the proper height for the sides. In doing so removed about 2 1/2 inches of width also. This allowed me to get the proper width needed for the 36 inch wide CJ tail gate. There is still a ton of work to be done. But, by using the Taco box I can trim off a lot of time.
I will probably get the whole body done and painted. Then have to wait for the funds to do the LS powertrain.
It will all come in time. I am in no hurry.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #245 of 5962 Old 02-01-2012, 06:42 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Pictures updated on page 1 with description.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #246 of 5962 Old 02-01-2012, 09:09 PM
aw12345
That worked out sweet, now how is the frame height versus bedheight and mounting of the bed going to work out? Going to have to flatten the frame some like a CJ or YJ frame?
aw12345 is offline
post #247 of 5962 Old 02-02-2012, 06:40 AM
jpin86
Are you going to use stock TJ fender flares? If so you might want to check the height of those inner fenders. They don't look like they will be high enough for the stock TJ wheel cutouts.
jpin86 is offline
post #248 of 5962 Old 02-02-2012, 06:41 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Yes sir, flatten the frame out more like a YJ or CJ. Running leafs so up travel and coil bind are not key issues.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #249 of 5962 Old 02-02-2012, 05:07 PM
aw12345
Figures as much, or the flat floor would not work
aw12345 is offline
post #250 of 5962 Old 02-02-2012, 07:32 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Should be fine, I had Gribbles measure his TJ with leafs and the top of the axle tube to bottom of the frame is 8 inches. I was planning on 5 and 5 rear travel anyway. He uses 6 and 6 rear travel and never hits the frame. I am using JK 44s with stock jk moab wheels also.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #251 of 5962 Old 02-02-2012, 07:35 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Yeah, I have the stock wheel arches traced out on the inside of the panels. Looking through the holes in the panel they will get close to the upper part of the arch. But, with the wider axles it should be fine. And yes, plan is to run stock Rubi flares in the rear.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #252 of 5962 Old 02-02-2012, 07:47 PM
kyle_craig
Jk Moabs give me a chub....can't wait to have a set for myself.
post #253 of 5962 Old 02-02-2012, 08:59 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Man I have found 3 sets of 4 or 5 in the last week or so. For 200-300. I just have not had the extra coin to drop on them.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #254 of 5962 Old 02-03-2012, 07:58 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Just so there is no confusion. The Toyota Taco box I am using for the bed on Dumpster Dive is a solid unit. Made of some kind of space age material. We have tried to bust the floor with a 10lb sledge and was unsuccessful.
Here is the bottom of the Taco box.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #255 of 5962 Old 02-05-2012, 11:52 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Rethinking powertrain already. I have a AW4 that I pulled from a XJ I am working on for a guy. I may rebuild it, then rebuild the 4.0 sitting in the garage on the engine stand. Mate those together with the spare 231 I have sitting in the garage floor. And Boom she has a powertrain.
Any thoughts. Sounds cheaper than a LS swap. Not as cool though.
Going next Saturday to pick up the JK44 for the rear. He says he also has a JK30. I may see about picking that up as well.
K.C.C.O.
Carpe Diem
Hendrix is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
