A TJ truck build named "Dumpster Dive" - Page 15 - JeepForum.com
 1Likes
post #211 of 5962 Old 01-26-2012, 04:42 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Teaser shot....
K.C.C.O.
Carpe Diem
Hendrix is offline
post #212 of 5962 Old 01-26-2012, 05:42 PM
twinstickd20
1979 CJ7
Originally Posted by Hendrix
Teaser shot....
Dang you fixed that fast.
My Build Thread
twinstickd20 is offline
post #213 of 5962 Old 01-26-2012, 05:54 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Yep, I speedy gonzalass.... fast. It's ready to break out the Uni spot welder to button all of it up.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #214 of 5962 Old 01-26-2012, 06:12 PM
twinstickd20
1979 CJ7
Lol
My Build Thread
post #215 of 5962 Old 01-28-2012, 09:56 AM
Recoil
Recoil's Avatar
1988 MJ Comanche
Drool.
Speed makes money.
I still wish you had moved up here. We could start a Euker night.
Recoil is offline
post #216 of 5962 Old 01-28-2012, 12:03 PM
AngryTJ
Def moving quick, nice work man
AngryTJ is offline
post #217 of 5962 Old 01-28-2012, 12:54 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
That's how I roll.
I am working on the cab at home and the bed at work. I should be able to get the bed all welded together at work. Then carry it home to fit it to the back of the cab within the next few weeks.
I am trying to locate a shop in or around Nashville that can E-coat the bed assembly. E-coating is a process used by car manufactures to coat all sides of a bare metal part. I want the bed to be dipped so the corrosion protection can get in all the crossmembers and places I cannot get with a primer gun.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #218 of 5962 Old 01-29-2012, 06:34 AM
jpin86
The 2 different sheet metal shops I went to said they couldn't make the small bend/joggle near the top of the panel. Maybe because I am using 16ga steel.
Your bed sides look good.
jpin86 is offline
post #219 of 5962 Old 01-29-2012, 08:38 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I took them a test piece to compare to from the leftover section of tub. He said no at first. But, 20ga is a bit easier to mess with. I used 16ga on the cab panel. I do not see how they could have bent it out of that. I wanted 18ga, but he did not have it on hand. So, 20ga it is. If it dents to easy I will just bolt on some Aluminum armor.
Thanks, I really want this dude to look like Jeep built it.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #220 of 5962 Old 01-29-2012, 08:45 AM
jpin86
What are you going to use for the floor and inner fenders?
jpin86 is offline
post #221 of 5962 Old 01-29-2012, 10:29 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Bed floor will be a cut down floor out of a full size donor of some kind. And the wheel tubs I will order from LMC. I plan on cutting down a set of 74-87 Chevy truck wheel tubs. They were bolt in and are only 50 each. They have a pretty good look to them. And with JK axles I will not need as much inner wheel house clearance. Therefore gaining bed space.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #222 of 5962 Old 01-31-2012, 05:12 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Updizzle....
Here is a sneak peek of the bed.
Pay no attention to the shelf between the sides holding the bed together. That's temporary in the tail gate opening to get some rough measurements. The wheel openings will also be determined after the bed is mated to the cab and frame.
All the rest of the pictures are being uploaded now. I will post them on page one for easier viewing .
K.C.C.O.
Carpe Diem
Hendrix is offline
post #223 of 5962 Old 01-31-2012, 06:12 PM
Cotton
Looks great Hendrix!!
Cotton is offline
post #224 of 5962 Old 01-31-2012, 06:55 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Thanks man,
pictures are up on page one.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #225 of 5962 Old 01-31-2012, 07:24 PM
REDLYNER
REDLYNER's Avatar
This thing will be a one of a kind. Very cool.
REDLYNER Racing #4410
Rugged Radios * Raceline Wheels * DynoMax Exhaust * Motor Trenz * Polar Bear Coolers
Instagram/Facebook/Twitter: redlynerracing
REDLYNER is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
