A TJ truck build named "Dumpster Dive" - Page 117 - JeepForum.com
 1Likes
post #1741 of 5953 Old 02-24-2013, 09:39 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by IEcrawlerTJ01
John. You still need a computer for this rig?
If it's a year 2k motor I have a ECM for it
I actually have the one out of the donor the trans and motor came out of. It was a 2001 XJ.
I need a 97 manual PCM to get it smog checked and to run the AW4.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1742 of 5953 Old 02-24-2013, 10:14 PM
aw12345
Looks like it has coil packs, instead of a distributor, so 1997 ecm no worky
aw12345 is offline
post #1743 of 5953 Old 02-24-2013, 10:25 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Coil packs are going away, along with obda BS. If it will not work I have a spare 4.0 out of s 97 wrangler in the corner.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1744 of 5953 Old 02-25-2013, 08:47 AM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
I'm very excited that you're using the AW4. I can't wait to see this thing roll
My builds:
and
or follow us on
spyder6 is offline
post #1745 of 5953 Old 02-25-2013, 10:06 AM
RockRodHooligan
RockRodHooligan's Avatar
Originally Posted by Hendrix View Post
I have a 97-99 stock manifold hanging on the wall to install on it still. I have no idea if this motor will even run. Time will tell.
Stick with the one you have, better air flow and it fixes the cracked manifold problem that Flop had/has.... I've got the same problem on my XJ, decided to use parts I still have left over from the old XJ and spare parts from the MJ stroker motor.
96 XJ:
89 MJ: Project: Ground up - Sold
01 XJ: Project: Silverback - Totaled
***** inches...
Good god man. Indyorv :rofl: d**k and fart jokes. :rofl:
RockRodHooligan is offline
post #1746 of 5953 Old 02-25-2013, 10:40 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I see, so have the exhaust shop build me a custom 2 in to 1 down pipe and crossover like the TJ has under the oil pan.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1747 of 5953 Old 02-25-2013, 11:19 AM
mcannon111
with the track bar mount on the frame like that how are you planning to run an antirock? Cause i'm in the same predicament, and the mount will get in the way of where the antirock should drop.
no doors, no top, no problems
live in sc? join OffroadSC.com
mcannon111 is offline
post #1748 of 5953 Old 02-25-2013, 12:45 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Bent arms will fix that issue. I will address that when the time comes. I will make sure I post a lot of pictures.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1749 of 5953 Old 02-25-2013, 01:06 PM
RockRodHooligan
Yup, I've had a hell of a time trying to find decent quality after market replacement parts for the exhaust in front of the cat, without the pre-cats, so I'm going to have the shop down the way build me something pimp up front.
96 XJ:
***** inches...
post #1750 of 5953 Old 02-25-2013, 05:32 PM
MO2500
Bent arms x2. I'm working around the same thing on mine.
Instagram: @omsmike
MO2500 is offline
post #1751 of 5953 Old 02-25-2013, 05:36 PM
mcannon111
Cool i will stay tuned to see how y'all do it. I got a good amount of time till I buy an antirock though. Have some more important mods I need to get done.
post #1752 of 5953 Old 02-26-2013, 09:20 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
So I spent about 3 hrs last night in the garage to really accomplish nothing. I started out by cleaning up a piece of tube for the axle side track bar bracket. Then I was just about to start cutting on the inner C brace when I realized I need to finish up the steering first. Going to work on the steering tonight then finish the front suspension later this week.
After that is just a bunch of this.
I hope to be working on the back half of the frame a finishing the trans crossmember on Saturday.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1753 of 5953 Old 02-26-2013, 09:23 AM
spyder6
spyder6's Avatar
2010
Odd question, but after my several hour stint on Saturday of 6 hours straight of welding and cutting in a closed garage so I could keep my pansy *** warm - what do you do for ventilation?
By the time Saturday night ended I had a sore throat, a cough and a serious fume headache and had black as coal snot for a day. I don't want to do that again.
My builds:
and
or follow us on
spyder6 is offline
post #1754 of 5953 Old 02-26-2013, 09:43 AM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Well, I try to work only when there are warm days. It was 60-65 all day Saturday. The only thing you can do is lift the door a little and put a fan right at the door to pull out some fumes. If you have an attic fan you can also do that.
I usually weld a little while then open the doors to let it clear out, then close them and weld for a while longer then repeat.
Here's some pictures of the wheels XJAbuzer.
The overcast sky today really messed with the color. It's a lot darker.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1755 of 5953 Old 02-26-2013, 09:48 AM
Sundowner
Hmm...bent arms...
Sundowner is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 11:49 AM
WeatherWarrior's "you better not call it a build" build thread. WeatherWarrior Jeep Builds 10 12-12-2011 06:31 PM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-10-2011 12:18 AM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 07:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 11:11 AM
