A TJ truck build named "Dumpster Dive" - Page 102 - JeepForum.com
 1Likes
post #1516 of 5962 Old 02-03-2013, 04:15 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by crazycollinz
Do you have the material that your makeing the top out of? I have the stock drive shaft off of a rubicon but you prolly need something custom
Yeah, I have a brand new TJ full top to make the custom soft top out of. All I need are the side windows that I can cut up to use the part that fits in the door surrounds. I am going to use the slip yoke style DS. Because of the WB I do not need a SYE.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1517 of 5962 Old 02-03-2013, 04:22 PM
TechJeeper
I have a couple of old slip yoke drive shafts what spline out put do you have?
TechJeeper is offline
post #1518 of 5962 Old 02-03-2013, 04:26 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I need to check the output shaft, but it is from a 231 tcase out of a TJ.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1519 of 5962 Old 02-03-2013, 04:48 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
The TJ fuel pump assembly connections are all the same. The early TJs and the later TJ connections differ from each other. They will all fit, no matter the motor.
Mail crawling.
MisfitSeven is offline
post #1520 of 5962 Old 02-03-2013, 05:40 PM
IEcrawlerTJ01
Xj rear driveshaft might be close to bolt in. You should take a guesstimated measurement and put it up here on the board
SAVVY,CURRIE,GOODYEAR
Nuff said...
IEcrawlerTJ01 is offline
post #1521 of 5962 Old 02-03-2013, 05:45 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
I still have to clock the tcase to the AW4. As soon as I get that done I will.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1522 of 5962 Old 02-03-2013, 07:57 PM
twinstickd20
1979 CJ7
Your hinges are on the way.
My Build Thread
twinstickd20 is offline
post #1523 of 5962 Old 02-03-2013, 08:29 PM
aw12345
Clocking the TC has no effect on the rear driveshaft, now the front that's another matter. For the rear, as long as you stuff it up as high as you want the output shaft, you can get an accurate measurement
aw12345 is offline
post #1524 of 5962 Old 02-03-2013, 08:50 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Didn't think of that. Guess all I need to do is set the transfercase up there and measure then. I will get that up this week. I will be in the garage all week.
Headed to Indy to drop off some sexy parts for my favorite Orange Jeep on Friday.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1525 of 5962 Old 02-04-2013, 09:25 AM
XJAbuzer
FYI, when we put an SYE in our Cherokees, we often use a front XJ driveshaft in the rear. I am at 6.5" with an IRO SYE and I have XJ front drivesahfts both front and rear.
1979 CJ-5 304 V-8, T-150 3 speed, Dana 20, Dana 30 front, AMC 20 rear, Sold
Anyways, I wanna go wheelin'!
XJAbuzer is offline
post #1526 of 5962 Old 02-04-2013, 12:00 PM
Holaday
I have a set of tail lights complete if you want them
Holaday is offline
post #1527 of 5962 Old 02-04-2013, 12:52 PM Thread Starter
Hendrix
TJOTY 2013
Hendrix's Avatar
Lots O blue...
Got to paint the hinges, then I can bolt up the wind shield frame.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #1528 of 5962 Old 02-04-2013, 01:37 PM
Jeffro06
Jeffro06's Avatar
Lots O blue...
Yes, yes it is.
Jeffro06 is offline
post #1529 of 5962 Old 02-04-2013, 03:28 PM
teamgreen666
Lots O blue...
Looks great, so shiny. Will you bedline the interior? I think once its all on the frame with the gray wheels it will look very cool.
One of a kind that's for sure.
teamgreen666 is offline
post #1530 of 5962 Old 02-04-2013, 04:17 PM
chocflip201
Read the posts, yes, the interior is getting bedliner.
chocflip201 is offline
aev , brute , custom , homebrute tj truck , indyorv , rokmen , tnjeeps
The Survivor Project-driveway frame swap/33's "build" EricsGreen98Tj Jeep Builds 75 05-15-2016 10:49 AM
An XJ named "Clotile" tactical40cal Jeep Builds 42 10-09-2011 11:18 PM
1997 TJ "Angry Wolf" Redneck Body Shop Build NorthWhiteWolf Jeep Builds 389 06-17-2010 06:33 PM
98 TJ Build Named Jasper mtflyboy25 Jeep Builds 1 01-23-2010 10:11 AM
