A TJ LCG build with lofty aspirations. - JeepForum.com
post #1 of 6 Old 11-13-2015, 09:10 AM Thread Starter
psyviperx
Heres how it looked when i got it. (246271)
It came with lots of extras and a few to do's.
Extras:
Highlift jack
2.5" Heavy OME Lift; used, not installed
1.25" BL; used, not installed
Jeep Add-a-Trunk
Trail Cover
Dust Cover
Bikini Top
2 Soft top frames.
To do:
Front brakes (done)
Transmission output seal
Drivers seat back
Preliminary Build Plans:
Engine
Cowl intake
2k+ Header
2.5" header back
Highflow Cat
Undecided Muffler
Update Ignition
Drive line
MML
TT
Lockers
Stretch (maybe)
Suspension
Refresh bushings
HD Control arms, most likely adjustable
New stock height springs
Body
1.25" BL
New Paint
Highline
Dropdown Tailgate
Armor
Skids
Bumpers
Interior
Dual stock switch panel
Bedliner
Fix/New front seats
New roll bar pads
Electrical/Other
Upgrade Soundbar
Upgrade HU
120v Power
Lights
OBA
Other supporting mods as needed.
This is going to be primarily a DD with the occasional Weekend trip so, i want to keep the road manners as nice as possible. I also like the look of an LCG build and it should be able to handle anything i ask it to do. It's a rather lofty build on my budjet so, it will be a little slow and subject to change.
04 Overland | K&N Intake | Kumho AT51
(Hers)
97 TJ Sport | D30/35 | Mods incoming...
(His)
psyviperx is offline
post #2 of 6 Old 11-13-2015, 09:15 AM Thread Starter
psyviperx
Brakes (246396)
When i picked it up the left front brake was worn down to the steel on both pads and the rotor had been taking a beating.
After pulling the wheel off i noticed that the sway link was broken as well.
Luckily, in one of my bags of goodies that came with it was a new link (a new set od pads was also included).
Back to the brakes, i got the caliper pulled off without incident and fitted into a hoby vise to compress the piston. The piston was seized enough that it bent the arm on my vise. Nuts. I stepped areount to the right side and checked it out.
It wasn't quite as bad as the left....
I decided that i didn't want to deal with rebuilding the calipers and since i would have to make an unplanned trip to the parts store any way i bought two new calipers and another sway link.
While digging through the bags i also found a bushing kit for the front sway bar. They got installed as well.
(Hers)
(His)
post #3 of 6 Old 11-13-2015, 09:18 AM Thread Starter
psyviperx
Tool Box
I have had this Craftsman Rally Box taking up space under my work bench for a couple years now. Someone was tossing it so i rescued it from the scrap bin. I finally found a use for it.
I'm thinking i want to mount it like this.
This would allow it to be mounted facing the interioir or exterior and its out of the way of the seat movement.
(Hers)
(His)
post #4 of 6 Old 11-13-2015, 01:58 PM Thread Starter
psyviperx
A little front yard flexing just for s&g's.
I also picked up some of the wipe new as seen on tv stuff too try out. I find it entertaining that they use TJ flares on their box.
(Hers)
(His)
post #5 of 6 Old 01-04-2016, 03:21 AM Thread Starter
psyviperx
Floofing the Soundbar
I had a couple 6" alpine speakers laying around from an older project so, i decided to upgrade the 5.25s in the soundbar.
When i pulled the factory speakers out i realized just how bad off they were.
Once i had the speakers out i stuffed the soundbar with a generous amount of floof.
After stuffing the soundbar i returned my attention to the speakers. I decided, because i had the time mostly, that i wanted to use the stock speaker plugs with the new speakers.
I unsoldered the leads and removed the plugs. There's little clip that fits into the speaker frame and locks them on. Don't just yank them off.
I had to file the frame of the Alpines to accept the plug and drill a small hole for the retention clip. If the clip doesn't get seated correctly the male ends wont plug in.
After i got it all buttoned back up i went for a drive. The sound was much better. I did create a problem though. The sound from the sound bar now overwhelms the single 4x6 i have in the front. My next project is to try and stuff some 5x7s in the dash.
(Hers)
(His)
post #6 of 6 Old 03-16-2016, 10:54 AM Thread Starter
psyviperx
Replaced the worn serpentine belt the other day. I stopped by the parts store and grabbed the belt and headed home to dive in to the engine compartment.
Got the old belt off, loosened the tensioner to what i thought should be enough and started routing the new belt. I needed another 1" or to to get it on so loosened the tensioner some more. It didn't help. I double checked the belt p/n on Google, it was correct but, there was no way that belt was going to fit.
I grabbed both the old and new belts and headed back to the parts store. We measured the old belt. Which is becoming a lost art apparently. We decided that the belt I needed was a Dayco 5060940, which is not listed for any Jeep engines and only one Chrysler. Not sure whats funky with my setup but, it definitely isn't "stock."
(Hers)
(His)
