Tj-6 - Page 5 - JeepForum.com
post #61 of 397 Old 12-10-2009, 02:22 PM Thread Starter
Ziptie
For all that are interested/ inquiring about the Spyder Lock wheels, I got a great source. Rimrock Mountain Supply, ask for Scott (Great guy).
(425-430-1445)
TJ-6 Build:
“The harder you work the luckier you become.”
Modern Classic Enterprises, LLC
Home of the flexible "FLATTY FENDERS"
Ziptie is offline
post #62 of 397 Old 12-10-2009, 04:11 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Originally Posted by Ziptie View Post
Thanks of the complement.
I am adding length similar to what jeep did to make the CJ-6. I just figured without the rear overhang it is more like the 6 than the 8.
I guess it could be a “bobbed” TJ-8…….
Makes sense. I just was looking at the door design.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #63 of 397 Old 12-11-2009, 12:40 AM
kdub0013
Frame work looks great! Crawling this one for sure. Keep up the good work!
kdub0013 is offline
post #64 of 397 Old 12-11-2009, 07:42 PM
bfr
bfr's Avatar
Very nice. Have you planned how the rear seat(s) will be arranged? The M170 (what the CJ6 was based on) could be set up so the rear passengers sat on cushions attached to the fenderwells facing each other. Lots of seating with nothing to remove in order to use the whole rear floor, on the other hand it also had no roll bar or seatbelts, so that would have to be addressed.
bfr is offline
post #65 of 397 Old 12-12-2009, 03:53 PM
toddwill74
Great job! Looks like you are moving along pretty quick. I looked at a post yesterday where a guy stretched a YJ and it took him like 4 months to get what you have done so far. Good luck! And gonna crawl this one too.
toddwill74 is offline
post #66 of 397 Old 12-13-2009, 03:38 PM
zeke6785
wow looks great crawled this one for sure. cant wait to get another jeep
2012 Wrangler
35" Pro-Comp Xtreme M/T
3" Full Traction Lift
Smittybilt Stinger
zeke6785 is offline
post #67 of 397 Old 12-13-2009, 05:11 PM
Idaho-Jeep
Looking good - anxious to see how the build progresses.
Idaho-Jeep Build =
Idaho-Jeep is offline
post #68 of 397 Old 12-13-2009, 08:47 PM
briguy3030
Hey Ziptie,
I noticed in your Wheel'n pics that your signal lights on the front fenders are relocated under/inside the fenders themselves--seeing as you have substantially trimmed/eliminated your fender flares. How did you do this? Are they the OEM siganl lights remounted or are they aftermarket products? Thanks.
RUBICON
"You miss 100 percent of the shots you never take."
-Wayne Gretzky
briguy3030 is offline
post #69 of 397 Old 12-13-2009, 09:00 PM
SuperWade2
More Money than Brains
SuperWade2's Avatar
I am not going to lie, I dig the Spyderlocks. They are also very stout! Great guys and great wheels. Spyderlock beadlock home
Note: I sold my hard top for $900 and my 33-10.50’s for $600 to get these wheels.
I've always liked the Spyderlocks as well...will be interested in seeing this mounted and rolling and you feedback on how you like them...
Nice build!
2014 WK2 Overland 5.7L - LEASE TURN IN
2017 WK2 Overland
SuperWade2 is offline
post #70 of 397 Old 12-13-2009, 11:39 PM Thread Starter
Ziptie
Originally Posted by briguy3030 View Post
Hey Ziptie,
I used the factory turns attached w/ zip ties. I then modified them more and mounted LED’s in grill and wheel well.
TJ-6 Build:
Ziptie is offline
post #71 of 397 Old 12-13-2009, 11:43 PM Thread Starter
Ziptie
Fish Plating:
I welded it all up then fish plated it. I used some extended plates so I could mount the body mounts cleaner.
TJ-6 Build:
Ziptie is offline
post #72 of 397 Old 12-13-2009, 11:52 PM Thread Starter
Ziptie
Raising the body mounts 1”:
I installed a 1" body lift for the flat skid and the 35's. I decided to cut the body mounts off under the doors and re-weld them without the 1" BL pucks. This will help my ground clearance.
TJ-6 Build:
Ziptie is offline
post #73 of 397 Old 12-13-2009, 11:56 PM Thread Starter
Ziptie
Upper rear control arm mounts:
Mine are starting to crack, so I beefed them up. I think this is a common problem with a short arm lift. I tried to get a good shot of the crack but my camera was not doing it, first picture.
TJ-6 Build:
Ziptie is offline
post #74 of 397 Old 12-14-2009, 12:23 AM
WILLTAKE
Awesome job so far- I can't wait to see it with the wheels all mounted up.
As for painting the rims...I think you should keep them the way they are now.
WILLTAKE is offline
post #75 of 397 Old 12-14-2009, 11:23 AM Thread Starter
Ziptie
Some more weld pictures with better light, they are less chunky in real life…
TJ-6 Build:
Ziptie is offline
