02-03-2010, 04:38 PM
#211
ok i just read 14 pages this is the Sh!t....GOOD JOB
4.56 gears, 33" KM2, 4.75" lift, headers, intake, throttle body spacer, super 40 and more to come... http://www.jeepforum.com/forum/f22/my-first-jeep-919474/
02-03-2010, 06:27 PM
#212
Don't beat the censor, it's there for a reason.
NightCrew #125
Why don't they have braille at drive-thru's?
02-11-2010, 06:08 PM
#213
TJ-6 Build:[url]http://www.jeepforum.com/forum/f22/tj-6-a-913143/[/url]
“The harder you work the luckier you become.”
[B]Modern Classic Enterprises, LLC[/B]
Home of the flexible "FLATTY FENDERS"
[url]http://modernclassicenterprises.com/[/url]
02-11-2010, 06:09 PM
#214
Welded existing hoop up.
02-11-2010, 06:12 PM
#215
Got the center console cut and fitted. The cup holders will not work as pictured (to wide). I also made a patch panel.
02-11-2010, 06:16 PM
#216
02-11-2010, 06:19 PM
#217
Added some support to the corners rocker. I used 3/16 plate from the tub tie in to angle on inner side of corner. Should help keep things in place. I also painted the underside and wheel wells.
02-11-2010, 06:22 PM
#218
Lookin good man, keep up the work
02-19-2010, 09:12 AM
#219
02-19-2010, 09:17 AM
#220
I marked 5 clocking options, then installed the box with no studs. I rotated it and decided on option D.
02-19-2010, 09:27 AM
#221
02-19-2010, 09:32 AM
#222
Vent/ fill point. I can fill it through the tub.
03-02-2010, 02:02 PM
#223
any new updates?
03-02-2010, 03:58 PM
#224
Yep, I just got to post up the pictures. Flat skid is built, body is 90% ready for paint. D44 is very close.
I will get on it and post up.
03-06-2010, 09:32 AM
#225
Building the flat skid.
I used ¼” plate with ½” spacers off the bottom of the frame. I then used “C” chanell for the cross and added plate to the bottom to stiffen and protect the needed holes. I also used “C” cannel for the Black Box mounting point.
FYI- It took me 3 to 4 times the amount of time I had planned to build this skid and install the Black box and set up the shifters.
