TJ 6.0l one tons - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > TJ 6.0l one tons
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits
Unread 09-08-2014, 08:16 PM   #1
helljeep
TJ 6.0l one tons
Here is my junk I have collected over the years.
97 Sahara was going to use my 05 tj but talked out of cuting up a good jeep.
Genright 3 link, double tri rear, 14" kings res, belly skid, alum highline fenders, rockers, corners, comp gas tank.
87 hp dana 60, 80's 14 bolt, Artec trusses rear, front with full hydro mount,high steer arms for solid knuckles, 8" PSC double ended ram. Going for 5 to 6" stretch in the front 6 to 7" rear.(cuting part on rear frame)
06 2500 6.0L vortec Lq4 with the massive 4L80E, 125000 miles.
Sent harness to lsxharness to be rewired and obd2 port. ( very informative)
Debating on having black bear performance tunes and he is able to do deletes for swap(helpful answered lots of questions). I have a autocal (EFI live) for my dodge so it is a bonuses cuz I will be able to use it via obd2 port.
Swag off-road body mounts(beef)
So over the 2 weekends of tear down ready to start the build.
helljeep is offline   Reply With Quote
Unread 09-08-2014, 08:24 PM   #2
helljeep
Have most you you who have put in a ls or motor swap is it just best to move it high and as far to the passenger side? Will be building my own motor mounts.
Not sure how the fitment is going to be with truss and trac bar?
Also trying to find the best way to do the fuel module just put a walbro 255 in the stock one? Or fit a Chevy fuel module? With a adapter like this.
http://www.vetteworksonline.net/cata...roducts_id=174
Unread 09-08-2014, 08:29 PM   #3
helljeep
What I started with.
Unread 09-08-2014, 08:40 PM   #4
helljeep
Can't figure out how to upload more then one pic at a time??
Unread 09-08-2014, 08:43 PM   #5
helljeep
Removing on wanted stuff
Unread 09-08-2014, 08:45 PM   #6
helljeep
Got rear cleaned up
Unread 09-08-2014, 08:46 PM   #7
helljeep
Working on the front
Unread 09-08-2014, 08:47 PM   #8
helljeep
Been looking at moving the genright tank back further to get more clearance from the axle. Thinking about cutting rear cross member And part of the stiffing box of the tub. Anybody try this?
Unread 09-08-2014, 08:57 PM   #9
helljeep
My 05 at the winter on the rock 2014
