TimV's 2003 Rubicon build - Page 6 - JeepForum.com
post #76 of 443 Old 06-08-2013, 08:00 PM Thread Starter
TimV
Here's one of the four reasons I'm doing all this. The other three reasons are the other frame side lower control arm brackets. The bracket was literally folded around until it was touching the joint.
Sent from AutoGuide.com Free App
It's not an addiction. It's a way of life.
TimV is offline
post #77 of 443 Old 06-09-2013, 07:13 AM Thread Starter
TimV
No turning back now. All the brackets are off the axle.
TimV is offline
post #78 of 443 Old 06-10-2013, 04:59 PM Thread Starter
TimV
After my last update, I got the frame side control arm brackets cut off. Today, I relocated the frame side coil buckets so the springs will sit straight up and down. It should also drop the rear down half an inch or so, which I wanted to do anyway. Out of curiosity, is anyone following this at all now that I am actually updating as I go? I feel like I'm posting just for the sake of posting.
TimV is offline
post #79 of 443 Old 06-10-2013, 05:09 PM
2000GrayTJ
I'm definitely tuned in, I plan on doing something very similar in the near future
good from far, far from good.
'99 TJ frame-off rebuild: http://jeepforum.com/forum/f22/99-tj-frame-off-rolled-bold-1199954/
2000GrayTJ is offline
post #80 of 443 Old 06-13-2013, 05:06 PM Thread Starter
TimV
Truss burned on tonight. Its starting to come together now. Picking up the steel for links Saturday. Once I get that, it should be just a matter of time before I get it done.
The thing I'm trying to figure out now is where to put the axle vent. It would have been directly under the truss, so I welded the hole up. I'll have to drill and tap a new one.
TimV is offline
post #81 of 443 Old 06-13-2013, 05:58 PM Thread Starter
TimV
Started putting in the frame brackets tonight as well. If my calculations are correct, I should end up around 23" for the lowers.
TimV is offline
post #82 of 443 Old 06-13-2013, 10:57 PM
Jay12
Nice work!
Jay12 is offline
post #83 of 443 Old 06-14-2013, 05:21 PM Thread Starter
TimV
Bracket number two is on. Which means it is time to start making links. Glad I'm going for steel tomorrow.
TimV is offline
post #84 of 443 Old 06-14-2013, 05:23 PM Thread Starter
TimV
Forgot the picture. Oops.
TimV is offline
post #85 of 443 Old 06-14-2013, 10:44 PM
Jay12
Where are you going to reroute the brake and gas lines? Top of the frame rail?
Jay12 is offline
post #86 of 443 Old 06-15-2013, 05:18 AM Thread Starter
TimV
Yes, they will be placed on top of the frame rail. I have a 1.25" body lift, so there is plenty of room.
On a side note, I'm not sure the Artec frame brackets would work without a body lift. I will measure later, but they are fairly close to the tub.
TimV is offline
post #87 of 443 Old 06-15-2013, 12:00 PM Thread Starter
TimV
Burning in the lower control arm brackets today. Hoping to get all 4 links in today so I can cycle the suspension and check clearances.
Still to go:
Lower coil buckets
Swap calipers around to front of axle
Outboard rear shocks
Shorten up exhaust for upper link clearance
TimV is offline
post #88 of 443 Old 06-15-2013, 12:27 PM
jeepinhokie
I recently mid arm 4 linked my TJ. Looks like your off to a good start.
Any reason you didn't cut off the track bar mount when you rotated the spring perch?
HOKIES UNITED!
jeepinhokie is offline
post #89 of 443 Old 06-15-2013, 12:36 PM Thread Starter
TimV
I thought about cutting the track bar mount off, but decided against it. I couldn't think of a good enough reason to cut it off. It made a perfect stop for rotating the spring perch. With my current plans, it should not be in the way of my outboard either. Plus, if I ever decide to take it back to a stock style suspension to sell, I won't have to put a new one on.
That said, I may cut it off yet. Not sure.
TimV is offline
post #90 of 443 Old 06-15-2013, 12:42 PM Thread Starter
TimV
Just finished getting the lower links in place. Very happy so far with how its all looking.
TimV is offline
EugeneTheTJ's 2003 TJ Build Thread EugeneTheTJ Jeep Builds 1133 02-12-2016 06:20 AM
My 2003 Sahara TJ Build up VTECZILLA Jeep Builds 20 12-10-2011 11:05 PM
KeithKeith's 2003 Silver TJ Build keithkeith Jeep Builds 15 09-22-2011 06:51 PM
2003 Jeep Rubicon sgraham Jeep Builds 4 10-02-2009 06:02 AM
2003 Rubicon Reelm n Rubi Jeep Builds 2 11-23-2006 07:22 AM
