TimV's 2003 Rubicon build - Page 5 - JeepForum.com
post #61 of 443 Old 03-15-2013, 10:58 PM
Jay12
Did you do a body lift for that skid? Or did you have to modify the tub at all with the 241?
He installed the Savvy BL with the skid...
Jay12 is offline
post #62 of 443 Old 03-16-2013, 07:17 AM Thread Starter
TimV
Yes, I did the 1.25" Savvy body lift. I did not have to hammer on the tub at all to make it fit. I was prepared to if necessary though.
It's not an addiction. It's a way of life.
TimV is offline
post #63 of 443 Old 03-16-2013, 08:07 AM
Rubicon0311
Yeah I looked back and found where you did the BL, I'm used to seeing pics of the finished product I guess my question is, would a 1" BL be enough, or would you recommend the 1.25"?
Rubicon0311 is offline
post #64 of 443 Old 03-16-2013, 01:53 PM Thread Starter
TimV
Haha, I need to get someone to take pics for me. I'm really bad about it.
I would go with the Savvy body lift. The pucks are nicely designed to cup the mounts. I would say 1" is enough for a non Rubi. I would go with 1.25" for a Rubi since they have the bigger transfer case.
TimV is offline
post #65 of 443 Old 03-16-2013, 07:58 PM
Rubicon0311
Thanks, the 241 is pretty massive.
post #66 of 443 Old 04-27-2013, 10:18 PM Thread Starter
TimV
So, I went to help out for the Ultra 4 race at Rausch Creek. The jeep held up good for race prep and all that.
Sunday after the race however, we went out wheeling some hard stuff. I ended up breaking both rear shock mounts off the axle tube. Took them out and kept wheeling until I lost a lower control arm bolt. At that point, we called it a day and I loaded the jeep back on the trailer.
Major updates may be coming to this thread. With the damages to the rear, I am strongly considering a mid arm four link conversion for the rear. Along with out boarding the rear shocks. Although I am also looking at in boarding the rear shocks to get more travel out of a shorter shock.
The main goal at the moment is to repair a badly damaged front track bar bracket. The shimmy I have had for a while is getting worse, and should be addressed tomorrow. Maybe I will actually take pictures this time.
TimV is offline
post #67 of 443 Old 04-28-2013, 10:34 AM Thread Starter
TimV
No turning back now. This thing was done. Building a new one from 2x2 tube.
TimV is offline
post #68 of 443 Old 04-28-2013, 11:17 AM Thread Starter
TimV
New bracket is all made up. I plan to pick up a new track bar tomorrow, so I can drill out the hole perfectly. Then I will be picking up some new grade 8 hardware, and welding the nut onto the back of the new bracket. I am very happy I am going this route over welding a washer over the hole.
TimV is offline
post #69 of 443 Old 04-29-2013, 06:55 PM Thread Starter
TimV
New bracket got burned in tonight. Looks to be a lot more solid than the factory sheet metal. I bought a flanged nut and shaved three edges of the flange down and welded it to the back. Should keep it from spinning if I somehow ever break the welds on it.
TimV is offline
post #70 of 443 Old 05-08-2013, 03:16 PM Thread Starter
TimV
The next phase of the build is going underway.
Ordered a bunch of Artec brackets to 4 link the rear. Planning to do a mid arm rear suspension, triangulated uppers. Also planning to replace the front lower control arm brackets on both the axle and frame side. May contemplate a mid arm 3 link for the front.
TimV is offline
post #71 of 443 Old 05-15-2013, 04:50 PM Thread Starter
TimV
Ups dropped off my box of fun today. Of course it looked like they played football with it first though. So almost all of my brackets are here.
TimV is offline
post #72 of 443 Old 05-28-2013, 02:21 PM Thread Starter
TimV
Got it out wheeling one last time before getting ready to do the 4 link. It performed nicely as always.
I'm also going to pick up a new welder this coming weekend. A Hobart 210 MVP. Should make my life a lot easier than the inconsistent one I have now.
TimV is offline
post #73 of 443 Old 05-30-2013, 08:43 PM Thread Starter
TimV
Got my joints in for the 4 link today.
Sent from AutoGuide.com Free App
TimV is offline
post #74 of 443 Old 06-08-2013, 12:14 PM Thread Starter
TimV
Got the Artec 4 link brackets mostly assembled. The frame side top plate is the only thing left to do, but I want to slip the brackets on the frame and then tack them in place. Just so I know they will fit right.
TimV is offline
post #75 of 443 Old 06-08-2013, 08:58 PM Thread Starter
TimV
Got the axle out in about an hour tonight. Getting too good at that.
TimV is offline
EugeneTheTJ's 2003 TJ Build Thread EugeneTheTJ Jeep Builds 1133 02-12-2016 07:20 AM
My 2003 Sahara TJ Build up VTECZILLA Jeep Builds 20 12-11-2011 12:05 AM
KeithKeith's 2003 Silver TJ Build keithkeith Jeep Builds 15 09-22-2011 07:51 PM
2003 Jeep Rubicon sgraham Jeep Builds 4 10-02-2009 07:02 AM
2003 Rubicon Reelm n Rubi Jeep Builds 2 11-23-2006 08:22 AM
