THOR - DD/Weekend Warrior - Page 5 - JeepForum.com
post #61 of 729 Old 04-10-2012, 09:17 PM
Sundowner
Originally Posted by Kodiak17 View Post
When I was pulling the CV joint apart, she helped hammer the socket a little. Didn't have much effect, shes too petite!
Mine's 5'-4" and 120 and likes to forge hot metal so don't give me that "too petite" s***. Hand her a two pound sledge and let her wreck something and she'll be hooked.
Your build looks like it's going well.
Sundowner is offline
post #62 of 729 Old 04-11-2012, 04:58 AM Thread Starter
Kodiak17
Maybe I'll get a BFH from tractor supply today, just for her! After dealing with my jeep addiction for almsot 2 years, I think some rubbed off on her. She told me a few weeks ago that she wants her own wrangler for college. And thanks for the kind words!
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #63 of 729 Old 04-11-2012, 08:27 PM Thread Starter
Kodiak17
Nutserts and bolts acquired. Grade 8 mofo.
Kodiak17 is offline
post #64 of 729 Old 04-11-2012, 08:28 PM Thread Starter
Kodiak17
Are my pics still too big? I just used photobucket instead of imgur and it came out the same
Kodiak17 is offline
post #65 of 729 Old 04-12-2012, 09:17 AM
bobthetj03
Pics are still big, but better.
Bob's boring build:
White Jeep club member #2003
bobthetj03 is offline
post #66 of 729 Old 04-12-2012, 02:59 PM Thread Starter
Kodiak17
My buddy drove me 30 min to the driveline shop. Guy told me it'd be $70. Just like I was quoted on the phone. But I also need the rest of the CV assembly. He also told me that they cut the entire yoke off and weld on a new one, which I wasn't aware of. Wanted to charge me $60. So now I must wait till my CV socket arrives and then I can bring it all there. : For now I'll be shopping around online for a cheaper yoke and cheaper service. I drive 2WD anyways.
Kodiak17 is offline
post #67 of 729 Old 04-13-2012, 11:56 PM Thread Starter
Kodiak17
Got my last pieces for the t-case. A little progress made today. Two other obstacles still remain. Unbolting the old t-cse. And installing new nutserts. Also debating if and what color I should paint the t-case. So im planning what needs to happen after the swap is done. To do list:
- New swaybar links (discos)
- Rear pinion seal
- Patch up some rust ( under tailight, rear rollbar mount, driver fender)
- tune CB
- paint underbody, floor, fenders, rear bumper.
Kodiak17 is offline
post #68 of 729 Old 04-16-2012, 03:03 PM Thread Starter
Kodiak17
Waiting for an extra hand with the tcase, damn retaining rings suck to install. In the mean time, I tried tackling old tcase removal. Spent 30 min getting one nut off. 4 more to go. And they all seem impossible to reach. I lowered the tranny so much that it was hanging for a moment (on accident). Considering mech doing it, would just save time. Depends what he'll charge me. Ahh... its 80 degrees outside and I cant drive. FML.
Kodiak17 is offline
post #69 of 729 Old 04-16-2012, 06:15 PM
Mediokrates
I found that the 2 top nuts were the hardest, with the top passenger being the PITA everyone described... and then some.
Get a breaker bar... or better yet, a hollow metal pipe. That should be all you need to get the leverage to break the others.
Depending on how old the jeep is, the t/c might be rusted in place... mine's a 93, and like I said, it took a 1200lb come-along and 2 pipes to get it off.
I don't expect yours to be as difficult.
Put your jack under the tc to help hold it in place.
Mediokrates is offline
post #70 of 729 Old 04-17-2012, 01:46 PM Thread Starter
Kodiak17
Problem is, I can't even get up there! I lowered the tranny as far as possible and couldn't fit the wrench up top.
Kodiak17 is offline
post #71 of 729 Old 04-17-2012, 05:04 PM Thread Starter
Kodiak17
Anyone know where this goes in t-case? had it all together, then remembered the first snap ring I took off.
Kodiak17 is offline
post #72 of 729 Old 04-17-2012, 05:38 PM
Mediokrates
It's probably the input shaft snap ring, if it's the first one you took off.
Looks strange though.
Depends, how many snap rings did you take off?
Only 1 was needed to crack the case from what I recall.
post #73 of 729 Old 04-17-2012, 07:29 PM Thread Starter
Kodiak17
I only took off 2. But the other one looked different. Sorta like yours... which I can't really see.
Kodiak17 is offline
post #74 of 729 Old 04-17-2012, 10:48 PM
Mediokrates
is it larger or smaller?
what size is it?
There are 2 on the input shaft. 1 holds the input gear in place, the other is the low range gear snap ring.
Looking at my pics from my swap, I see that I removed 2 snap rings, but I can only remember the one. The 2nd is much larger, but doesn't look like yours.
Did you completely remove the rear external housing? I think there's a snap ring there.
post #75 of 729 Old 04-17-2012, 10:55 PM
thirdeye
I remember that when I did my SYE I ended up with an extra snap ring..
So if you got 2 (maybe just one, I dont remember) on, and that t-case shaft doesn't move you should be good
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
xj with kj light 89XJ_John Jeep Picture Requests 1 02-21-2010 09:50 AM
Who all has a light bar? lil-jmart13 Jeep Picture Requests 0 02-18-2009 05:44 PM
yj 4d light RedWind Jeep Picture Requests 0 01-19-2009 06:19 PM
your headlights/fog lights/driving lights/light bar light patter MC_NickP Jeep Picture Requests 4 12-29-2008 02:43 AM
Please post your non stock third brake light/license light set up BlueJeepRME Jeep Picture Requests 4 07-22-2006 06:11 PM
