THOR - DD/Weekend Warrior - JeepForum.com
post #1 of 729 Old 03-26-2012, 04:32 PM Thread Starter
Kodiak17
Build plans...
Suspension: Savvy arms, bumpstops, rear shock outboard, Currie steering, Currie trackbars, Currie AR f/r
Axles: HP30 locked and chromos, Locked 8.8, 4.88's
Armor: Rokmen corners, sliders, flattish belly
Drivetrain: 1" MML, SYE and rear DS
Body: 1" BL, Metalcloaks, Rampage frameless top, GR8tops exo-gate
Powertrain: 5.9L Magnum
After a little over a year of having the jeep and being on here, I've decided to start a build. My first goal was to do something different and try to stay lighweight, but the supporting mods for such a thing are out of my budget. Instead im working towards a reliable rig I can wheel on the weekends yet stay comfortable on the road. Saving weight will be taken into consideration, I just can't base my build off it. Brief timeline:
The week I got it.
Playing around in a pit behind my house.
Put in a Pioneer deck.
And some Infinty Kappas in the dash with Nalin Mfg. brackets.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #2 of 729 Old 03-26-2012, 04:37 PM
SonicR1
The great thing about stock Jeeps is that they are very capable!!! I nice small lift and bigger tires make it that much better!!! A little bit of money spent in the right places will get you almost anywhere you want to go!!! Looks like you are on the right track!
... I guess I'm gonna have to fix that too…….
2005 Wrangler X 4.0/6 speed, Dana 30/Ford 8.8--4.88--Eaton E-Lockers, 35" MT/R, Smittybilt bumpers/rockers/winch, SonicFab tire carrier, RE 3.5 springs, Zone 1.25 BL, FullTraction 3 link upper rear, RE super flex lower rears, UCF ultra high skid and lo/pro mount, brown dog mml.
SonicR1 is offline
post #3 of 729 Old 03-26-2012, 05:07 PM Thread Starter
Kodiak17
Thanks, more pics to come. Imgur is being a b**** right now. I'll post future plans as well.
Kodiak17 is offline
post #4 of 729 Old 03-26-2012, 05:22 PM Thread Starter
Kodiak17
Painted and sold my steps.
Sold my carpet.
Painted the wheels Duplicolor Graphite
Birthday presents included a bumper from Smittybilt and some Hella 500's.
Ordered a 2" spring lift from BDS that summer. Searched around for some tires on CL.
Kodiak17 is offline
post #5 of 729 Old 03-26-2012, 05:43 PM Thread Starter
Kodiak17
My grandpa and I took two weekends to install the lift and toss on the bigger tires.
All cleaned up. Picked up a set of BFG 32's for $300.
Kodiak17 is offline
post #6 of 729 Old 03-26-2012, 05:50 PM
Sundowner
Looks good.
Sundowner is offline
post #7 of 729 Old 03-26-2012, 06:07 PM Thread Starter
Kodiak17
Looks good.
As does yours
Kodiak17 is offline
post #8 of 729 Old 03-26-2012, 06:22 PM Thread Starter
Kodiak17
I've had some fun on the 32's from last summer till this winter.
My current project has been building a sub box designed by SirGCal. I'll get some shots of it finished.
Kodiak17 is offline
post #9 of 729 Old 03-26-2012, 06:32 PM Thread Starter
Kodiak17
This past new-years eve, I was on my way from my dads in Jersey to PA when my t-case blew in half at 60 mph. I was getting vibes to and from Jersey. Several weeks before I had a case of the angry sparrows. I was unable to pull off my front driveshaft due to the placement of the bolts. I procrastinated and result was not driving for like 2 months.
Today I scored an NP231 off CL for $70 with 70k miles on it from a 2000 4-cylinder 5 speed. Everything seems to work fine. My next obstacle is ripping off the skidplate since two of the bolts won't budge and the other 4 keep spinning. I've tried the pry-bar trick, the jack lift trick, torching, PB Blaster, impact wrench, and saw-zall.. My last option is to see if I can fit the grinder cutting wheel in between the frame and skid. If not, I have an appointment with the mechanic for Thursday, so he can take care of it. My rear DS is already rebuilt with new Spicer u-joints and the front is waiting to be rebuilt once the skid is off.
Kodiak17 is offline
post #10 of 729 Old 03-26-2012, 06:50 PM Thread Starter
Kodiak17
Future plans list moved to first page...
Kodiak17 is offline
post #11 of 729 Old 03-26-2012, 07:16 PM
Muddy_TSi
Subscribed.
:twothumbsup:
Muddy_TSi is offline
post #12 of 729 Old 03-26-2012, 08:00 PM Thread Starter
Kodiak17
After some poking around I think I might go with:
Rokmen Crossmember Bumper
http://www.rokmen.com/rokmen-rear-bumper.html
TnT Fab. Tire-carrier
http://www.tntcustoms.com/tjljreartirecarrier.aspx
Kodiak17 is offline
post #13 of 729 Old 03-27-2012, 07:03 PM Thread Starter
Kodiak17
Cleaned up the donor t-case today. Noticed some hairline cracks, after a little research, I'm pretty convinced its from the casting process. Also, after tipping upside down, some fluid spilled out of the over flow valve. Was pretty darn brown. I'm debating if I should split this thing open to clean it out before I do the swap... opinions?
Yea.
After a little cleaning.
Main cracks. Few smaller ones elsewhere.
Kodiak17 is offline
post #14 of 729 Old 03-28-2012, 05:05 AM Thread Starter
Kodiak17
Bump on splitting the t-case
Kodiak17 is offline
post #15 of 729 Old 03-28-2012, 06:22 AM
Sundowner
You've got next to no money in it. If you break it...no big deal. I say to open it while it's out and take a look inside. It doesn't take a massive amount of time and you'll feel better knowing that you've got a solid setup once you've had a look inside and fixed anything that's amiss. If not, it's going to bother you...and if it doesn't bother you, then it should.
The cracks you showed look more like flashing lines from the mold casting...they look kind of raised up to me due to the angle of the photo. I'd try taking a file to a small area and seeing if you can polish them down...if they're cracks, you'll know pretty quickly how deep they go.
xj with kj light 89XJ_John Jeep Picture Requests 1 02-21-2010 09:50 AM
Who all has a light bar? lil-jmart13 Jeep Picture Requests 0 02-18-2009 05:44 PM
yj 4d light RedWind Jeep Picture Requests 0 01-19-2009 06:19 PM
your headlights/fog lights/driving lights/light bar light patter MC_NickP Jeep Picture Requests 4 12-29-2008 02:43 AM
Please post your non stock third brake light/license light set up BlueJeepRME Jeep Picture Requests 4 07-22-2006 06:11 PM
