#1 | |
That's just all wrong.
Well the new junk is coming along. Mostly thanks to dumpster diving, horse trading, freebies, and favors that can't be discussed.
I started with this ![]() It was put together decently for a general purpose trail rig. Super 35 with a Detroit, True track up front. 4.88's & 35's, a beefier belly and tank skids. Not bad, just not my taste. What is my taste is it's a 2.5, 5spd First trip out I spun the rear driveshaft out of it. ![]() well getting off the trail with a truetrack in front and no rear drive sux. Out came the LP30, and the build began..... My philosophy is build as minimally as I think I need, but to the W.E. Rock rules for Modifed Stock class. WE Rock rules I'm shooting to have the rig weigh 2600 lbs when it's done. A friend did a 30 to 44 swap in the front of his JK UNL. I happily removed the 30 from his garage ![]() The JK isn't much of an upgrade from any other HP30. It uses the same crappy 2.5" x .250 wall tubes. It's just their a few inches longer on a JK set up. So ![]() 2.5" ID sch 40 HREW pipe ($1 a pound scrap) and a plasma cutter ![]() test fit ![]() ![]() Left is the new sleeved tube, right is the stock tube in all it's whimpy nakedness. Now the front tubes are 2.9" x .450 wall ![]() short side plugged and seam welded ![]() long side seam welded ![]() Johnny Joint's set. waiting on the lower brackets, track bar mounts. The mounts came in. We haven't had a chance to get them done an make progress. I got a chance to fondle the new Reid JK knuckles. They have made some seriously nice pieces. Lots of reinforcement where it's needed. I just don't think the steering changes will be of benefit to justify using them. I'm going to make a tie rod and draglink using heim joints. The way Reid moved the mounts up for the stock tie rod will cause my contraption to bind. ![]() THE SUPER 35 IS LEAVING THE RIG thought you'd never hear me say that did ya? well, one of those little advantages to the JK30 is 5.13 gears. I fully intend to take advantage of this ![]() This is the start of the rear. ![]() It's a 1979 F250, 3" x .500 wall leaf spring high pinion 44. (what's the name of my build?) This is another one of those trade junk for junk prizes. It's been laying around for a year or so....so.....why not cut it up and make a rear. After surgery it will be a centered rear, semi float HP44 with 30 spline Rubicon shafts at TJ width. After having an Atlas and a STaK in the old rig. The 231 in this gutless wonder wasn't going to cut it for me. Sold the 231 and the front LP30, bought a used 300 with a 4:1 kit and clocking ring. I found a used 21 spline input from a CalRocks guy for next to nothing. Yeah, I'll get pics when I get around to it. Gotta give a thanks to Blaine and Gerald at Savvy ![]() hopefully they'll get the belly skid done soon. I kinda need it to hang everything back up in there. more to come later....got a few more dumpsters to hit this week ![]()
Get Savvy Last edited by never monday; 02-16-2010 at 09:13 PM.. |
#2 |
That's a sweet starting point.
#3 |
Looks good, can't wait to see more
#4 |
My kind of build....sa's? Or don't know yet?
http://www.kifourwheelers.com/ |
#6 |
Savvy Off Road
Pat,
That front axle is nice. I'm going to do the same to mine. Keep it up!
Email me for the fastest response: gman@savvyoffroad.com Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD The ONLY place to get Savvy/Currie Lifts and parts! The best price and support! PM MrBlaine for Black Magic Brakes! http://www.savvyoffroad.com 2006 LJ Unlimited Black Hole 2005 LJ Test Mule 2003 TJ Project Unrolled 2003 TJ Project Click Here |
#7 |
Looks good! Can't wait to see how this rig turns out!
#8 |
I'm a big meanie head
Nice nice bro. But you mentioned not using the JK steering setup? Shoot me a PM when you get it figured out. When are you going to finish so you can come up here and wheel? Or so that I can come down there and wheel?
::SELLING:: Hornblasters Shocker S4 horn set with some extras $210 shipped. (It is not OBA, just an accessory for OBA) "LCOG" isn't cheap and it certainly isn't easy. If you think so, you are doing it wrong. If you aren't willing to put in the effort, don't label your build "LCOG". You are just a cheap ******bag. |
#9 | |
I hope to wheel this summer.
Get Savvy |
#10 |
no whiners!
Wow, never though you would part with the S35. This should be a good re-build.
#11 | |
Well ****, I forgot you've got the Reid knuckles. Did you measure to see how much farther (if any) they stick out at the tie rod mount than the stock JK knuckles?
#12 | |
I don't have Reids. They are a friends for his JK. I just got to fondle them ![]()
Get Savvy |
#13 |
Looking good there NM. I can't wait to see that axle truss. I wonder how long you are going to have to wait to slip that 300 under there
JFI Member #7: Helping out the Scammed 2004 Rubi: Ready to Kill the Chrome! Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s Do the Jeep Wave :D 0|||||||0 Take 95% of what I say as a joke/sarcasm!-Thomas |
#14 | |
Pretty please?
#15 |
played around with the 300 some today
swapped inputs, pulled the clocking ring off. started to pull it down to change the shifter set up. ![]() ![]() ![]() time for a new clocking ring ![]() plenty of depth, maybe too much....
Get Savvy Last edited by never monday; 02-20-2010 at 04:36 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
