TexasTJ's Build - Page 53 - JeepForum.com
 2Likes
post #781 of 1338 Old 03-11-2014, 10:35 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
Discount is going to order my tires next week.
Originally Posted by nmtj View Post
I just had a hp built so maybe my opinion is of some value to you.
I did not truss, sleeve or gusset the c's. My reasoning was based on mr. Blaines posts and I couldn't justify the cost for a $100 housing. I will have a lockrite in mine and we'll see how the carrier does. If Imped didn't break his carrier I'll be fine. My plan is to wheel it hard and if it explodes I will upgrade to something else or buy another housing.
Also, I looked over at least 10 hp housings at the junk yard and none of them had the vacuum disconnect. Years ranged from 89-98. I pulled my housing for just over $100, but I'm not sure if you have a self serve junk yard.
I'm probably skipping the truss, sleeve, guesset from what I've heard/read too. I think I've decided on the Detroit for the front too. Honestly I dont think pulling a JY Hp will save much over the ECGS axle.
May TJ of the Month 2015
TexasTJ is online now
post #782 of 1338 Old 03-12-2014, 12:02 AM
Driver831
Full Detroit, or tru trac?
And good call on the skipping. Just don't let your girl see you skip around too much.. She might think ur strange haha
Follow on Instagram kids! @ Driver831 @provinggroundsracing
www.Provinggroundsracing.com
Driver831 is offline
post #783 of 1338 Old 03-12-2014, 04:28 AM
awinski
What are you thinking about for a rear axle? a friend at work just pulled one out of an 09jk. He's selling the housing. Just an fyi. On mobile so I can't see where you're located
The ONLY chlorophyll JK
one more horse power than the average pentastar;
twitter/IG - @Becauseracejeep
awinski is offline
post #784 of 1338 Old 03-12-2014, 07:58 AM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
Originally Posted by Driver831
Full Detroit, or tru trac? And good call on the skipping. Just don't let your girl see you skip around too much.. She might think ur strange haha
Full f/r Detroits
post #785 of 1338 Old 03-12-2014, 07:59 AM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
I just got a 44 in December so it's staying for now. I'm a bit far, College Station TX.
post #786 of 1338 Old 03-12-2014, 03:12 PM
holdren4100@cyb
Two things I would recommend you do before you put the axle in.
TIEROD FLIP
TRE insert to flip the tierod to the top of the knuckle to gain more clearance. The insert will need to be tapped in, and the split in them will ensure that they are tight and do not move. The insert kit comes with a grade 8 flanged lock nut to replace the factory castle nut. This is the same style nut used on newer JK's. The insert is made from cold rolled 1045 steel on a CNC lathe with the correct taper to match and lockup to the tierod just like factory.
All you need to install this TRE insert is a 3/4 drill bit and a 1/2 drill to hold it.
http://www.shop.blackmagicbrakes.com...ts-Gussets.htm
holdren4100@cyb is offline
post #787 of 1338 Old 03-12-2014, 04:28 PM
NYGLT56
Your Local Body Builder
NYGLT56's Avatar
Full f/r Detroits
You may or may not like that setup...I hated my Detroits when I had them..
As for the HP30, I had one, fully built. Beat the crap out of it with 0 issues. Granted I had them less than a year before the JK44s, but in that time frame it went to moab and back, and over 20 Crawling trips including the chili challenge down here.
Id Sleeve, Gusset, Full Case, and chromo it all over again. (My housing did cost 50$ Geared so I spent less) Just my .02
Either way, Sub'd
2014 TJOTY Winner
IG: overlanding_racingdriver_
A Daily Driven Lowrider TJ on 40s.
NYGLT56 is offline
post #788 of 1338 Old 03-12-2014, 10:29 PM
Driver831
Full f/r Detroits
You will like it, just be easy making tight turns in 4low that's all
post #789 of 1338 Old 03-13-2014, 04:13 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
Originally Posted by holdren4100@cyb
Two things I would recommend you do before you put the axle in. TIEROD FLIP TRE insert to flip the tierod to the top of the knuckle to gain more clearance. The insert will need to be tapped in, and the split in them will ensure that they are tight and do not move. The insert kit comes with a grade 8 flanged lock nut to replace the factory castle nut. This is the same style nut used on newer JK's. The insert is made from cold rolled 1045 steel on a CNC lathe with the correct taper to match and lockup to the tierod just like factory. All you need to install this TRE insert is a 3/4 drill bit and a 1/2 drill to hold it. http://www.shop.blackmagicbrakes.com...ts-Gussets.htm
I'll look into the tie rod flip, what is the point of the sway link mounts?
post #790 of 1338 Old 03-13-2014, 04:15 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
Originally Posted by NYGLT56
You may or may not like that setup...I hated my Detroits when I had them.. As for the HP30, I had one, fully built. Beat the crap out of it with 0 issues. Granted I had them less than a year before the JK44s, but in that time frame it went to moab and back, and over 20 Crawling trips including the chili challenge down here. Id Sleeve, Gusset, Full Case, and chromo it all over again. (My housing did cost 50$ Geared so I spent less) Just my .02 Either way, Sub'd
I've heard you just have to get used to the Detroit in the rear and I think I'm pretty tolerant so it shouldn't take long. Sleeve and gussets cost $180 & $150 so I'm still on the fence, leaning away though.
post #791 of 1338 Old 03-13-2014, 05:32 PM
holdren4100@cyb
When you do the tierod flip the tierod will hit the stock brackets. This is the best way to cure that.
I run Detroit's with no problems.
post #792 of 1338 Old 03-13-2014, 06:01 PM
NYGLT56
NYGLT56's Avatar
I had it in the rear for three years. Never got around to liking it. And if you do an inner sleeve (which is what I recommend) it's only $100 from poly.
2014 TJOTY Winner
NYGLT56 is offline
post #793 of 1338 Old 03-13-2014, 06:58 PM
holdren4100@cyb
The sleeves were to help the JK housings from bending. There is no proof that the sleeves do alot good in a tj 30.
There are reports that they really don't do much In the JK.
Once you learn how to drive with a Detroit in the rear you won't even know it's there.
post #794 of 1338 Old 03-13-2014, 08:53 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
When you do the tierod flip the tierod will hit the stock brackets. This is the best way to cure that. I run Detroit's with no problems.
Gotcha, that makes sense.
post #795 of 1338 Old 03-13-2014, 08:54 PM Thread Starter
TexasTJ
No Longer DD
TexasTJ's Avatar
The $180 from ECGS is already welded in though.
