A Teenager with a Dream - Page 47 - JeepForum.com
post #691 of 1654 Old 02-21-2013, 01:59 AM Thread Starter
Carlos14
Originally Posted by Moose340 View Post
Moose wants to see it all together!
Oh and moose will message you back about the mags when he has them in his hand
Moose need to hurry up! What if I need to shoot but can't because I don't have them. What shall I do? Throw bullets?
Luck Favours The Prepared
Carlos14 is offline
post #692 of 1654 Old 02-21-2013, 02:05 AM
Moose340
You can put one in the chamber! Jezz how many shots do you need?!
Non timebo mala
Check out my build
Moose340 is offline
post #693 of 1654 Old 02-21-2013, 09:19 AM Thread Starter
Carlos14
100. Bad aim.
Carlos14 is offline
post #694 of 1654 Old 02-21-2013, 09:28 AM
Moose340
Originally Posted by Carlos14
100. Bad aim.
Dead. If it takes more then two its time to leave.
Non timebo mala
Check out my build
Moose340 is offline
post #695 of 1654 Old 02-21-2013, 09:37 AM
8pitcher
8pitcher's Avatar
1) Beware of the man with one gun.
2) Fancy guns, sights, and gadgetry do not make up for a lack of marksmanship. (This thought applies to a lot of other activities too.)
3) If you can't do it with a .30-06 you probably can't do it with anything else.
4) If you can't do it with a 2 MOA firearm you probably can't do it with anything else.
5) Sight picture and trigger control are life. If you mess up either you'll miss.
6) Practice, practice, practice!
7) A close miss is still a miss.
8) Smoothness first, the speed will come.
9) Inconsequential increments are meaningless.
10) Most gun writers are pathological liars.
1) There ain't no magic powders!
2) There are no magic cartridge cases!
3) Details! It's in the details.
4) Inconsequential increments are meaningless.
5) Most gun writers are pathological liars.
External Ballistics
1) There ain't no magic bullets!
2) Divide the range at which someone claims to have shot their deer by 4 to get (close to) the real range.
3) Always get as close as possible.
4) Don't believe manufacturer's claims.
5) Velocity erodes, mass doesn't
6) In the battle between velocity and accuracy, accuracy always wins.
7) Inconsequential increments are meaningless.
8) Most gun writers are pathological liars.
Terminal Ballistics
2) Only center hits count
3) Make the biggest diameter hole you can to let blood out, air in, and destroy as much stuff as you can with each hit
4) Small bullets may expand, but big bullets never shrink.
5) Make the deepest hole you can to insure that vital organs and nerve centers can be reached and destroyed from all impact angles.
6) "Service" your target until it is no longer a threat or capable of any response you don't want.
7) No small arm can guarantee 100% instant incapacitation of a determined adversary--man or beast.
8) Don't believe manufacturer's claims.
Terminal Ballistics
Gunfighting
1) Bring a gun. Preferably, bring at least two guns. Bring all of your friends who have guns. Bring your brain.
2) Anything worth shooting is worth shooting at least twice. Ammo is cheap. Life is expensive.
3) If your shooting stance is good, you're probably not moving fast enough nor using cover correctly.
4) Move away from your attacker. Distance is your friend. (Lateral and diagonal movements are preferred.)
5) If you can choose what to bring to a gunfight, bring a long gun and a friend with a long gun.
6) In ten years nobody will remember the details of caliber, stance, or tactics. They will only remember who lived.
7) If you are not shooting, you should be communicating, reloading, and running.
8) Accuracy is relative: most combat shooting standards will be more dependent on "pucker factor" than the inherent accuracy of the gun.
9) Use a gun that works EVERY TIME. Don't trust an untested gun.
10) Someday someone may kill you with your own gun, but they should have to beat you to death with it because it is empty.
11) Always cheat = always win. The only unfair fight is the one you lose.
12) Have a plan. A bad plan quickly executed is better than no plan.
13) Have a back-up plan, because the first one probably won't work.
14) If your attack is going according to plan, it's probably an ambush.
15) Use cover and concealment as much as possible.
16) Flank your adversary when possible. Protect yours.
17) Always tactically reload and threat scan 360 degrees at the conclusion of the action.
18) Watch their hands. Hands kill. (In God I trust. Everyone else, keep your hands where I can see them).
19) Decide to be AGGRESSIVE enough, QUICKLY enough.
20) The faster you finish the fight, the less shot up you will get.
21) Do not deliberately attend a gunfight with a handgun, the caliber of which does not start with a "4."
22) Anyone who claims they know everything about gunfighting is a jerk.
23) Don't rely on a single weapon system. Know how to efficiently use all kinds of different weapons.
24) Remember that after your assailant is down that most likely one of his friends is waiting to kill you.
25) The only thing you ALWAYS know, is you NEVER know!
26) When you least expect it, EXPECT IT.
27) If there is any doubt, there is NO doubt.
28) The are few interpersonal relationship problems that cannot be solved by the judicious use of high explosives or napalm.
29) Remember that tracers work both ways.
30) It never hurts to have too much ammo and loaded magazines. Running out of ammo sucks.
31) "Don't stop shooting when you think he's dead; keep shooting until he thinks he's dead. Dead men sometimes come back to life and shoot you or your buddies."
32) Never leave a place over which you have gained dominance without all your weapons full.
Gunsmithing
1) All you really need are a good trigger and good sights.
2) You can remove metal but it's hard to put it back.
3) Sharp edges belong on a knife.
4) Better too loose than too tight.
5) You won't find an Allen wrench or a Torx driver in the boonies.
6) Better a stock too short than too long.
7) "Kool" won't save your life or bring down a game animal.
8) Don't over lubricate.
9) There are no magic lubricants.
10) There are no magic cleaners
11) Not all professional gunsmiths (even some big name ones) know what they are doing.
Life in General
1) Good manners are always in good taste. Treat others the way you want them to treat you.
2) Better to be over-dressed than under-dressed.
3) Be kind and courteous to everyone you meet but have a plan to kill them quickly if necessary.
4) One cannot have too many good books, to much good wine, or too much ammo.
5) Cats are a good judge of character.
6) Learn something new every day.
7) Good grammar is a sign of a sharp mind.
8) Your word must be your bond.
9) Stay alert!
10) True friends that will stick by you no matter what are a rarity. Cherish them.
11) YOU are responsible for what happens to you.
12) You are NOT entitled to an easy life and luxuries.
13) Always do the right thing. This will gratify some people and astonish the rest.
14) Flowers say "I'm sorry," chocolate says "I love you."
15) Don't do stupid things, don't associate with stupid people, don't go to stupid places, and don't live in stupid areas.
16) Do not rely on the government for anything, especially your survival. Anyone who says, "I'm from the government and I'm going to help you" is NOT your friend, and is NOT interested in your welfare..
17) Don't be upset by people who don't like you or who speak ill of you. They are the ones who will never know the pleasure of your friendship.
18) Don't throw rocks at people with guns. Don't stand next to people who throw rocks at people with guns.
19) Enjoy the little things in life too.
20) Better to remain silent and be thought a fool than to open one's mouth and confirm it.
21) Money doesn't make you better than someone else. It is just a convenience on the road of life.
22) You won't have trouble if you are prepared for it.
23) You cannot personally solve everyone's problems, nor should you feel that you have to. You need to take care of yourself too.
24) The magnitude of one's stupidity is amplified by one's position in society. "
25) Morons are equally distributed among time and space, so it does not matter where you go. You are very likely to find at least one in a location where you least expect it."
26) It's not what you look like nor what people think of you that defines you, but rather what you do.
27) Pay close attention to everything, notice what no one else notices. Then you will know what no one else knows and that's always useful.
28) What a person may or may not have done in the past should have no bearing on their reputation or desirability as a friend, employee, or colleague. It is what they are doing now that is important.
29) Agents of the government and politicians all lie to you and are not your friends. Never trust them.
30) Real men know how to cook, sew, and clean.
31) Don't stand out or call attention to yourself. The squeaky wheel get close attention and the nail that is standing up gets hammered, and those who are paying attention will note you as a potential subject of interest.
32) If you think you need a hand, look first at the end of your own arms.
33) You are the first responder to your emergency.
34) Never underestimate the power of large groups of stupid people.
35) If you are good, everything will be assigned to you. If you're really good, you'll get out of it.
26) According to Markell's Rule things will always take longer than expected, even after you take Markell's Rule into account.
27) Higginbothams Universal Rule - The is no universal rule.
28) The dumber people think you are, the more surprised they are going to be when you kill them.
Life in General
9) Stay alert!
Faith
1) God is the one in charge, but don't expect him to just do everything for you. He gave you a brain and muscles for a reason.
2) Pray daily. (Yes, He wants you to pray for yourself too.)
3) Showing Christ's love does not mean you have to accept as "OK" every behavior of every person. It just means that you have to treat everyone with respect and compassion.
4) You will be a better witness by example than by bible thumping. The best sermons are lived, not spoken.
5) God doesn't care if you are Baptist, Catholic, Episcopalian, or whatever. He cares about how well you follow his directions.
6) When you talk to God, remember to listen.
7) God doesn't expect you to walk on water. He just wants you to get out of the boat.
8) Don't ask God to do difficult things FOR you, ask Him to help you find the strength to do difficult things for yourself.
9) The harder you push against life, the harder it pushes back.
Cooking
1) Don't overdo the seasonings.
2) An unwatched pot usually boils over.
3) Simple, hearty food, is the best--especially when shared with friends.
4) A day without red wine is not a complete day.
5) Fresh baked bread negates the cholesterol in butter.
6) Use fresh ingredients.
7) The most critical ingredient in a recipe you are working on is the one you ran out of last week.
8) Electric stoves keep cooking once the burner is turned off.
9) Homemade cinnamon buns are considered a health food.
10) Use real butter.
11) Use REAL vanilla, almond extract, and other flavorings and spices.
Woodworking
1) Don't buy cheap cutting tools.
2) Measure 3 times, cut once.
3) You can make a board shorter, you can't make it longer.
4) A properly aligned table saw will get out of alignment at the most critical cut of the project.
5) Don't believe dimensions given in a project's plans until you have checked them.
6) A sharp pencil will always be on the other side of your work area.
7) Before beginning to screw and glue check the fit of all pieces.
8) A dull cutting tool is worse than having no tool.
8pitcher is offline
post #696 of 1654 Old 02-21-2013, 09:40 AM Thread Starter
Carlos14
I'm not reading all of that.
Carlos14 is offline
post #697 of 1654 Old 02-21-2013, 09:40 AM
sjones26573
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #698 of 1654 Old 02-21-2013, 09:42 AM
8pitcher
8pitcher's Avatar
It's how to gun fight.
8pitcher is offline
post #699 of 1654 Old 02-21-2013, 09:45 AM
Moose340
Moose read most of it and get the point
Non timebo mala
Check out my build
Moose340 is offline
post #700 of 1654 Old 02-21-2013, 09:56 AM
8pitcher
8pitcher's Avatar
I enjoy it.
8pitcher is offline
post #701 of 1654 Old 02-21-2013, 02:18 PM Thread Starter
Carlos14
My mounting brackets arrived today. I'll have a few final bends to make when the light bar arrives and after that, it's all good to go! Still have to drill out the mounting holes and paint it. I'm thinking white to match the paint but not sure yet.
Carlos14 is offline
post #702 of 1654 Old 02-21-2013, 02:19 PM
sjones26573
Why did you buy a lightbar?
Jeep-Owner.com
post #703 of 1654 Old 02-21-2013, 02:24 PM Thread Starter
Carlos14
The club I run with here in Fl. does mostly night wheeling because they all have LEDs of some sort. I'm tired of not being able to see what's in front of me. Even with my KCs and Hellas, there are still a ton of dead spots and this will resolve that.
Carlos14 is offline
post #704 of 1654 Old 02-21-2013, 02:28 PM
sjones26573
Ok, well at least if you have a decent reason.
Jeep-Owner.com
post #705 of 1654 Old 02-21-2013, 02:31 PM Thread Starter
Carlos14
It definitely will get used for its purpose. Sure I could have done with a smaller one, but I'd rather just aim high the first time.
Carlos14 is offline
build , highschool , nc guys , one bright yj , orange wrangler , YJ
Building a teenage dream Jeep, on a teenage budget - My YJ Build nathanninja Jeep Builds 152 09-16-2014 12:45 PM
My Dream Vehicle dayriesw Jeep Builds 111 07-18-2014 10:52 AM
A 14 year old boys dream!!! matt2299 Jeep Builds 34 05-25-2012 10:02 PM
17 Year Old Dream marzcap328 Jeep Builds 52 04-09-2012 12:21 PM
My dream build! 99 xj foxrider12390 Jeep Builds 2 02-07-2012 03:32 PM
