TechJeepers Sleeper Build - JeepForum.com
post #1 of 152 Old 04-25-2014, 09:24 PM Thread Starter
TechJeeper
Old build thread covers from my trade of the jeep current. I feel like it's time to start a new chapter in the jeep build. OLD THREAD: http://www.jeepforum.com/forum/f22/t...-fund-1321144/ The jeep has slowly transformed into my jeep from the place the previous owner left off. Feel free to read through old thread if you like or even search college fund for original owners build thread if you want to see all the way back to the beginning. A lot of the basics are still close to the way I got it. Suspension is the same but 3" higher and many heim joints replaced. Axles are pretty much the same 4.88 gears HPD30 out front 8.8 in back I added a Detroit locker to. From this point forward the build is about keeping this thing a jeep but making it utterly bulletproof on 35-37" tires. I already have an ATLAS installed and heavy wall driveshafts, skid plates front to back although my gas tank skid took a beating last trip out and needs a bit of a refurb and reinforcement.
Front axle build is going to be a round housing 609 with all 35 spline internals. I have the round ford 9" hosing and third member and I'm working on sourcing the kingpin outers. Sticking with try jeep fashion it'll be a 5 lug setup with some what period correct to 1998 alloy wheels. The housing will be shaved for max clearance and trussed of course.
EDIT FOR FRONT AXLE BUILD: Going with HD Dana44 parts from the Cees out. 31 spline chromo inners and 19 spline chromo outers with super joints. Later down the road ill get a 35 spline 9" 3rd member and convert over to RCVs. 1 ton stuff and 35" tires on 15" wheels just wasnt working. Something had to give.
The rear axle is already in process of being built. I'm doing it myself and learning as I go. It's a semi float 35 spline Dana 60. I'm building it first because the axles are dual drilled and will allow me to continue I the wheels I he's until the front axle is done also. End of the day goal will be shaved 1 ton running gear and 35" tires.
I'm adding in a weld in sport cage and rear cage pieces from BTF and poison spider. The jeep sits about 3" over stock suspension wise and 1" of body lift. I've got new 12" Bilstein 5125 shocks coming next week. The suspension has travel for days but I have the current shocks. They are doetch tech 8000 and unless the jeep is air born they ride like bricks. Any how here's how the jeep sits and my number 1 hand running the jack.
There won't be any drastic appearance changes or stretched out insane LCG 170" rock bouncer suspension just a bomb proof TJ that works in the rocks and drives great down the road.
TechJeeper is offline
post #2 of 152 Old 04-26-2014, 06:48 AM
Tylers88
Your right front tire is inside out but other than that looking good
Tylers88 is offline
post #3 of 152 Old 04-26-2014, 08:31 AM Thread Starter
TechJeeper
I know and thanks.
post #4 of 152 Old 04-26-2014, 11:13 AM Thread Starter
TechJeeper
I borrowed an open 35 spline diff to layout my rear axle and get the final dimensions for my housing cut down. It should end up at 61" with brake rotors on. Sorry image quality so bad. I have to downgrade the files to post them.
post #5 of 152 Old 04-27-2014, 07:03 PM Thread Starter
TechJeeper
After a little more search I figured out one missing piece to the disc brake setup. I'll do a full write up the entire rear axle build. In short you have take the drum brake backer and cut it down to the size of the housing end to add that extra ~1/8" to the stack of parts going on the end of the housing. I don't have a backer to cut so a couple of plasma cut pieces will have to do the trick.
post #6 of 152 Old 04-28-2014, 05:41 PM Thread Starter
TechJeeper
Finished cutting housing down and test fit the housing ends. Everything looks good so far. Now to finish cutting off old brackets and burn in the housing ends.
post #7 of 152 Old 05-09-2014, 08:04 AM Thread Starter
TechJeeper
4 new Bilstein 5125s installed. Rides like dream now! $84 a piece from 4 wheel parts with free shipping. I'll be back to the axle build in a couple weeks.
post #8 of 152 Old 06-23-2014, 08:35 AM Thread Starter
TechJeeper
Well slight change in plan. Front 9" will be HD Dana44 from the cees out. 31 spline chromo inners and chromo outers with super joints.
Eventually ill upgrade the 3rd member to a 35 spline setup and change over to an RCV setup.
Just some playing around mock up and measuring.
post #9 of 152 Old 06-23-2014, 10:48 PM Thread Starter
TechJeeper
Also I snagged a kilby gas tank mount/skid for next to nothing and found a blue torch fab rear bumper in the old jeep part pile I forgot we had. I love shopping the old jeep part piles around. A good friend has an extensive one and likes to make trades. The other is a combination of my families swapped, removed, out grown parts.
post #10 of 152 Old 09-06-2014, 08:45 AM Thread Starter
TechJeeper
The Kilby gas tank skid was a flop. It was for a YJ so I am back looking at gas tank skids. I should have the rear portion of the cage in and done this weekend. I finally got a soft top frame to make sure it would work with one. I actually drove the jeep to work this week, about a 25 mile commute both ways. Progress is slow but I'm getting stuff knocked out little by little. My PSC steering is back from them rebuilt and installed. No leaks, slop or overflow from the res. I am adding a heim joint front track bar to the list of things to do. The rubber joint just doesn't hold up
post #11 of 152 Old 09-18-2014, 05:35 PM Thread Starter
TechJeeper
Tomorrow my ruff stuff order comes in for my track bar . Should go pretty smooth.
post #12 of 152 Old 09-20-2014, 08:28 AM Thread Starter
TechJeeper
Ruff stuff order didn't make it in on friday
So I put my roll cage in instead. Everything has a 1" weld on top so I can pull it out and fully weld it and paint it. I left the A pillar floor plates to make my own. I'm going through the floor to the mini boat side.
post #13 of 152 Old 09-23-2014, 10:25 AM Thread Starter
TechJeeper
New panhard bar in is done. Made a huge difference.
post #14 of 152 Old 09-23-2014, 06:36 PM Thread Starter
TechJeeper
Well a couple updates. Before moving forward on the axle builds I am going to build a new set of front hi line fenders that will open up the rear of the wheel well so I don't rub there any more. Also in order to keep the jeep drivable I have to install new passenger ball joints.
Also when getting exhaust work done be very specific. Or you mat end up with one of these little beauties.
post #15 of 152 Old 09-26-2014, 07:31 PM Thread Starter
TechJeeper
All hooked ready for the mountains. And view of said mountains from the porch. Just got done grilling meat and watching it rain. Been a good day for no jeeping yet.
