TechJeeper's contiuation build formerly Project College FUNd - Page 9 - JeepForum.com
Go Back JeepForum.com > General Jeep Forums > Jeep Builds > TechJeeper's contiuation build formerly Project College FUNd
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!TJ Wrangler 4" Rough Country Suspension Lift Kits in Engo winches available at www.rockridge4wd.com! Free shipp
Unread 11-28-2013, 05:52 PM   #121
84jeepcj7rock
Nice Jeep. Wish I had a bender and the space to use it.
84jeepcj7rock is offline   Reply With Quote Quick reply to this message
Unread 11-28-2013, 09:41 PM   #122
TechJeeper
Thanks man! I've been following yours quite a while.
The bender probably gets me in more trouble than it is useful but I can't imagine not having it now. I've had it for maybe 8 years now.
TechJeeper is offline   Reply With Quote Quick reply to this message
Unread 12-03-2013, 11:04 AM   #123
TechJeeper
So attack of the death wobble has come! The bushings are shot in the track bar. The spherical end is toast and and the rubber end isn't exactly sturdy. I'm glad JKS sells replacement parts.
Unread 12-08-2013, 10:13 PM   #124
TechJeeper
After a 300 mile work day in my thoughts I remembered that I had a brand new small flex joint from about 8 years ago. I dug it up pulled it apart and it's the same size bushings as my grenades track bar.
FREE JEEP PARTS!!!
Unread 12-17-2013, 06:23 PM   #125
TechJeeper
Finishing up the track bar re install and adjusting steering and track bar tonight hopefully I'll get pictures up later.
Unread 12-17-2013, 06:31 PM   #126
TechJeeper
Unread 12-19-2013, 09:01 PM   #127
TechJeeper
It was too dark for pictures but rebuilding the spherical joint made all the difference. I adjusted it out a little because I never adjusted it after switching or the RC 2.5" springs for the RE 3.5" springs. I netted almost 3" of difference when I installed the new springs so it was definitely in need of adjusting.
In other jeep news I washed my jeep for the first time ever since I've owned it. I don't know if that's a badge of honor or being lazy but the rain always did a pretty good job.
I really enjoyed my last trip out to LC.
The next few things I wasn't really expecting to do and aren't quite necessary are 10 new heim joints and spacers. There's a pretty clunk from worn out heims in the rear suspension. The lowers are all new already so it's got to be the uppers.
Unread 01-05-2014, 01:06 AM   #128
TechJeeper
I got in a new Ruff Stuff Dana30 3/8" diff cover and another set of 4 heims for the rear upper control arms. My awesome wife got me a new radio for Christmas and I got that installed the other day so now I have tunes again. I'm going wheeling again this month at Twin Buttes near San Angelo, TX.
In non jeep news I recently finished a 9mm AR 15 and changed a few things on my standard 5.56 AR 15. Sometimes guns get in the way of wheeling and vice versa.
Unread 01-05-2014, 09:51 AM   #129
TechJeeper
I am very impressed with the Ruff Stuff diff cover. This thing is beefy! 1/2" ring machine flat for sealing and press formed 3/8" face. It looks awesome. Time to shoot it semigloss black put it on!
Unread 01-05-2014, 05:33 PM   #130
Holaday
Changed a lot since it was a MO Jeep. Just curious, why did you lift it so much?
Holaday is offline   Reply With Quote Quick reply to this message
Unread 01-05-2014, 06:02 PM   #131
TechJeeper
Got tired of dragging the belly everywhere. I lost tons belly clearance because the atlas is so big. Probably 1.5-2" worth. I'm working on a way to get Atleast 1" of that back. It had 2.5" RC coils but they were beat so bad the front actually measured stock. I technically added 1" with the RE 3.5" coils but the front had sagged so far it it lifted it 3". The rear wasn't as bad sagging but the RE rear springs are pretty high weight rated so it sits a little butt high. When I add the tire carrier I think that will settle back down some also. 37" tires may be in its future also.
Unread 01-05-2014, 07:24 PM   #132
84jeepcj7rock
That's beefy. Never seen 1/2" plate used for the mounting surface.
Unread 01-05-2014, 09:23 PM   #133
TechJeeper
I was shocked at how thick it was. The holes are all nicely machined, the faces are all nicely machined, welds look good and the plug is big enough to actually fill the diff. It'll be better to hit that than anything else on the front end.
Unread 01-07-2014, 10:20 AM   #134
TechJeeper
After being pregnant and having little kids for the last few years my wife is actually going wheeling again! In a few weeks we are Wheelin' Twin Buttes reservoir in San Angelo, TX.
Unread 01-13-2014, 10:39 PM   #135
TechJeeper
Coming soon to a TJ near me. Roll bent rear tube flares!!! I've decided if I'm going to spend all the time to weld out rear fenders I'm going to do it exactly like I want to. Current flares say bye bye. I like radius cut in the armor way better than the 3 sided flare. That's what I'm going for.
