Tax season wrangler rebuild - JeepForum.com
post #1 of 89 Old 02-02-2013, 06:34 PM Thread Starter
bty34
The focal point of this is going to be a frame swap on a TJ. I will be attempting to do the bulk of the work prior to April 16th (my wife is an accountant)
A little backstory, purchased the Jeep back in 2004, was a salvage rebuild.
Over the last 8 years, the Jeep has made it to this. If anyone has any questions about anything in between, let me know, but most of it is normal stuff so I will skip it for now.
Around a year ago I noticed a soft spot in the frame by the rear crossmember. Since the frame is already a little twisted, I figured it was best just to swap it out.
Purchased a frame from Davey's Jeeps. Not sure where it was from, but it has no rust. A little red dirt came out when I washed it the first time.
Plans are:
Swap frame
Raise body mounts 1.25"
Change shock mounting
Detroit in front
Poly Perf cage
Mastercraft seats
Savvy Under Armor if funds allow
While it is apart I'll put some parts of for sale, if they sell plans will change. If not, they will go back on.
bty34 is offline
post #2 of 89 Old 02-02-2013, 06:45 PM Thread Starter
bty34
Frame prep
I got the frame inside and started working on it.
Plugged a couple of extra holes.
Cut off the rear crossmember.
Started moving center body mounts
Cut off rear coil buckets
Little sandblasting.
Primed the bare spots
Coated with Rust-Oleum gloss black
bty34 is offline
post #3 of 89 Old 02-02-2013, 08:00 PM
Moezer
2015 JK Wrangler
looks good why did u cut the back cross member?
Moezer is offline
post #4 of 89 Old 02-03-2013, 04:54 PM Thread Starter
bty34
I'm adding a body lift, and since I already drag the rear bumper more than I like to, I moved the crossmember rather than using lift pucks. I'll be using 3 rather than the normal 11. I thought about moving the crossmember the shocks bolt to, but it doesn't seem like it would gain me much.
bty34 is offline
post #5 of 89 Old 02-03-2013, 09:05 PM
Moezer
2015 JK Wrangler
I see our still going to reinforce it?
Moezer is offline
post #6 of 89 Old 02-03-2013, 10:08 PM
contdevelop
This should be good!
contdevelop is offline
post #7 of 89 Old 02-03-2013, 11:08 PM
kyle_craig
Nice build. I like the frame mods. How do you like your TnT fenders?
kyle_craig is offline
post #8 of 89 Old 02-04-2013, 11:30 AM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
Those front fenders look great with the color match. Good idea about the body lift, without the body lift.
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #9 of 89 Old 02-04-2013, 06:05 PM Thread Starter
bty34
Back when I bought them (2009) there weren't all that many options for full replacement fenders. If I was doing it again I would look elsewhere, probably Poison Spider.
Main reasons are:
They are wide in the front since they don't taper and I have the 4.5" flare version. I occasionally catch the corner on the trail.
It's difficult to keep the rust at bay. There is a section in the middle where two pieces of sheet metal overlap, and the joint with the tube. I would expect it if the Jeep was a daily driver, but anymore it spends winters in the barn. This is the main reason I like the Poison Spider.
Lastly, I feel like they didn't put much thought into the inner fender. The design is simple, but gives up more room than most.
I'd like to replace them some day, but they are pretty far down the list, so it will be awhile.
bty34 is offline
post #10 of 89 Old 02-06-2013, 01:53 PM
MG_salsa
sweet!
MG_salsa is offline
post #11 of 89 Old 02-06-2013, 02:28 PM
flopp00
I need to do this i will be watching this very closely
2015 jku hydro blue daily
2013 chrysler 200 fiances
1994 f150 beater
flopp00 is offline
post #12 of 89 Old 02-10-2013, 02:32 PM Thread Starter
bty34
Got the Jeep out of the barn. Discovered it is worthless in the snow with only 2wd. I had pulled the front driveshaft this fall due to some trail damage.
In the shop waiting.
Took some measurements
Gas tank skid
Rear crossmember
Frame rail and center skid
Front frame rail
Pulled the rear axle. The ebrake cables fought with me a little bit, but otherwise went fairly well.
Needs a little attention
So do the arms
Pulled the joints on the uppers apart. I was surprised to find the bushings were one piece rather than split. Currie sells a rebuild kit for the joint, so I guess you can change the bushing if you ever need to.
http://www.currieenterprises.com/ces...t.aspx?id=3859
Ready to go back in
Pulled the lowers apart, wiped the bushings down and put a thin coat of grease on them and put them back together. The paint is drying on them now.
Cut of the lower shock mounts, they were looking a little rough.
Axle cleaned up and primed
Started bending brake lines
New brake hose and vent line
New trac bar bracket
All done
bty34 is offline
post #13 of 89 Old 02-24-2013, 06:14 PM Thread Starter
bty34
Front axle pulled
It looks like I could use some more clearance under the axle
Had some rust on the stock shock mount
and some debris underneath
All cleaned up
New Currie mounts
I also cut of the Currie mini skids, bent them back into shape and aded them to the new mounts.
bty34 is offline
post #14 of 89 Old 03-04-2013, 08:18 PM Thread Starter
bty34
Overall, my modified stock cover has been holding up pretty well to the abuse
But it is starting to lose some material on the bottom edge. The part that had me a little nervous was the matching gouges in the diff.
I went and grabbed an old LP30 housing I had laying around. I pulled it out a junkyard back during cash for clunkers to get the 3.73 and up carrier
Stole the cover off it and then cut it up for scrap. Saved the cover, cover bolts, and trackbar/ coil mount. If anyone was curious the tube size on a TJ LP30...
I sandblasted the cover before I realized HP and LP covers are not the same.
I put the cover over the housing anyway and noticed my housing is not missing as much material as I originally thought.
I'm leaning towards reworking the cover I was using. I also noticed some damage to my trackbar bracket. I had one situation where I bent the draglink enough that the tierod rubbed the trackbar bolt and allowed it to loosen. I bent the draglink back and replaced the trackbar bolt and it never gave me any trouble, but the damage to the bracket was hidden the the brace I have over top for the ram assist. I may clean up the bracket on the junk housing and see what I have to work with.
Put that on the back burner for now and moved on to installing the detroit. Pulled the open carrier and swapped the ring gear over.
bty34 is offline
post #15 of 89 Old 03-09-2013, 05:04 PM Thread Starter
bty34
Detroit is in. Actually found my notes from when I installed the gears 3 years ago. Went pretty smoothly. I've found it is a little easier when you take your time and have a comfortable working position. Doing differential work with the axle still under the vehicle and it only up on jackstands makes it a lot more frustrating.
Shock tabs for the front lower mounts came from Ruffstuff.
Started back on the cover. I cut some pieces off the LP cover I had blasted.
I didn't have a great way to hold the cover while I was welding, so I cut the tubes of the junk housing I had in the scrap pile.
All welded up with new additions
Painted up and bolted on
bty34 is offline
